I plan on setting up an HPC/slurm cluster.
I am just looking to stream line things
with a dedicated switch and normal power
supply. The 3 standalone nodes I have
seem to work fine.
Chris
seem to work fine.
Chris
Make sure you have enough power for all the loads at the same time.
Make sure each of the wires/cables are short (less than a foot if you can!)
Put a de-coupling capacitor right before the connector for the power input – 220 uF is a start, more is better.
You can also try powering through the GPIO connector rather than the barrel connector; each pin is rated for 2 (or 3?) Amps, so you’d want two 5V pins and 2 GND pins connected to your power rail.
You would not happen to have a part number , would you ?
Chris
The 40 pin GPIO connector is simply a “dupont” style 100 mil spacing double-row header – there are tons of options there.
For a good de-coupling capacitor, I’m partial to Nichicon long-term-rated capacitors for long lifetime. Try the UPJ1E221MPD6TD perhaps? I think that’s what I have in my parts bin for simple radial capacitors with leads.
