I have a server with windows server 2019 with a Tesla, I am wondering if it is ok to run Clara with it or should I use Linux instead, if using Linux, any suggestions for the version?
Hi
Thanks for your interest in Clara Train.
Clara train SDK is a docker image that we have tested mainly on Ubuntu 18. It should work with Ubuntu 20 (although we haven’t tested it yet). I am not sure how much / If Docker is supported under windows. If you are able to run a basic docker image and expose the GPU into the docker then Clara train/AIAA should work.
