Anyone got Unreal Engine 5 working on their Spark?
Has anyone else managed to get it working on their Spark? I’m trying to stream it to my Windows Laptop but having real issues.
First I tried building the package from source but it didn’t like my ARM version. Then I tried building a project on windows with Linux ARM64 as a plugin, then transfering to my Spark
I wasn’t sure if i instead need to use a docker?
I only saw a thread regarding a build script for Blender: Blender 5.0 (and 5.1.0) running on GB10 with CUDA, OptiX, & Vulkan!
Maybe the author has some helpful tips.
Forgive me for asking but why would you want UE5 running on your spark?
The only interesting use case I considered until now was running UE5 (actually 5.8) on a Desktop, integrated with an AI agent through the MCP endpoint. That’s where the spark would come into play, as serving the LLM…
I think I am missing your point ?
Hi @davidbarnesguildford,
Is your goal to (1) run Unreal Engine itself on Spark? Or are you trying to (b) run Unreal on the Windows machine and compile an app/game that you can then run on Spark?
Docker probably won’t do what you’re looking for.
For (2), I imagine that’s probably do-able.
For (1), part of the challenge is if you download Unreal Engine 5, you can get it for Windows x86-64 or Linux x86-64. Spark is Linux aarch64 (a.k.a. arm64). The short answer is “no, there’s not a good way to do that to my knowledge”.
The longer answer is you may or may not be able to use some combination of FEX and Proton to do it, but it might work poorly or simply not at all. Specifically:
If you just want to stream your Spark display out to a Windows machine, that should totally be possible, so if you’re having trouble, if you post some more details, that’s probably fixable.
