I tried installing “NVIDIA-Linux-x86_64-367.27”
But it gives out this error
PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Unable to load: nvidia-installer ncurses user interface
Using built-in stream user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
WARNING: You do not appear to have an NVIDIA GPU supported by the 375.20 NVIDIA Linux graphics driver installed in this system. For further details, please see the appendix SUPPORTED NVIDIA GRAPHICS CHIPS in the README available on the Linux driver download page at www.nvidia.com.
-> License accepted.
-> Installing NVIDIA driver version 375.20.
-> Performing CC sanity check with CC="/usr/bin/cc".
ERROR: The kernel header file '/lib/modules/4.8.4-1-ARCH/build/include/linux/kernel.h' does not exist. The most likely reason for this is that the kernel source path '/lib/modules/4.8.4-1-ARCH/build' is incorrect. Please make sure you have installed the kernel source files for your kernel and that they are properly configured; on Red Hat Linux systems, for example, be sure you have the 'kernel-source' or 'kernel-devel' RPM installed. If you know the correct kernel source files are installed, you may specify the kernel source path with the '--kernel-source-path' command line option.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
I don’t understand why I’m getting this warning
WARNING: You do not appear to have an NVIDIA GPU supported by the 367.27 NVIDIA Linux graphics driver installed in this system.
That GPU was purchesed directly from MSI.
Any help at all would be appreciated.
