I am keep trying to use the can bus in the tx2 but I keep fail to get the data from the usb to serial device
I want to try the can bus in TX2.
It should be able to access from J26 pin
If I get the can bus rx,tx from the radio harness and connect to the right pin in the J26
Can I use can-utils to get the data?
Can you see can0 and can1 using ifconfig -a command?
Because the can driver is not activated by default on the jetpack 3.0 as mentioned here:
https://devtalk.nvidia.com/default/topic/1006762/jetson-tx2/how-can-i-use-can-bus-in-tx2-/
If not, you can activate it by using this trend’s procedure:
https://devtalk.nvidia.com/default/topic/1011148/jetson-tx2/enable-can-bus-on-jetson-tx2/
For the can-utils part I cannot answer at the moment.
Best of luck!
