AODT 1.5.1 : RU antenna height applied at half the configured value, and LoS ray path missing from raypaths/CFR/CIR for a clear indoor link
yaml_example.txt (4.8 KB)
I’m running AODT 1.5.1 (Worker + GIS Worker on Singularity, Windows client) on a small custom indoor scene (GIS-converted from a CityGML meeting room model, approx 7m x 4.8m x 2.7m). I’ve found two issues that I can reproduce consistently and would like to report.
ISSUE 1 – RU antenna height is applied at exactly half the configured value
- I set the RU height via the official API (ru.set_height(height_m), which serializes to sim.RUs.update[].attributes.aerial_gnb_height in the YAML) to 1.2 m, alt = 0.0 m.
- I set the UE height via config.set_ues_height(height_m, ids=[…]) (serializes to sim.UEs.update[].attributes.height_m) to the same 1.2 m, alt = 0.0 m.
- Both rus/ues result tables report height = 1.2 for both nodes.
- However, when I inspect the actual raypaths result (ray start/end Z coordinates), the RU’s ray-launch height is consistently exactly half the configured value (0.6 m instead of 1.2 m), while the UE’s ray-reception height is correct (1.2 m).
- I confirmed this is a clean 2x relationship: when I doubled the RU’s configured height to 2.4 m as a workaround, the actual simulated RU height came out at exactly 1.2 m – matching what I originally intended.
- This is reproducible across multiple scenes/placements. It only affects RU height, never UE height (UE always applies at the exact configured value).
- Attached side_view.png shows this clearly: RU (red marker, right) sits visibly lower than UE (cyan marker, left) even though both were configured with height_m = 1.2 in this run.
ISSUE 2 – No line-of-sight (LoS) path is ever generated for a confirmed unobstructed RU-UE link
- For the same scene, I confirmed via direct ray-casting against the exported master.usd building mesh (all walls + furniture, since GIS bakes everything into one mesh) that the straight line between the RU and UE positions has zero geometric intersections – the link is fully unobstructed. I verified this for multiple RU/UE placements in two different scenes.
- Despite this, the raypaths table never contains a pure 2-point LoS row (interaction_types == [0, 4], i.e. emission to reception with no bounce). Every returned path has at least one reflection/diffraction interaction.
- The cirs table is also consistent with this: for a link at approx 4.52 m separation (expected direct-path delay approx 15.05 ns), the shortest delay bin present is 17.636 ns (approx 5.29 m) – matching the reflected path from raypaths, not a direct path. No LoS contribution appears in the channel either.
- I ruled out several possible causes before reporting:
  • Antenna pattern: RU uses the built-in threeGPP_38901 element pointed (via aerial_gnb_mech_azimuth) almost exactly at the UE with mech_tilt = 0, i.e. the LoS direction is at the pattern’s peak-gain boresight (theta’=90 deg, phi’=0 deg), not a null.
  • sim_em_sphere_radius (receiver sphere radius): tested both the default 2.0 m and 0.5 m – no change in behavior.
  • Visualization-side filtering: confirmed by reading the raw raypaths parquet directly, bypassing any post-processing/dB thresholding.
  • I checked test_emsolver.py – with empty geometry (no buildings), the solver does return a proper 2-point LoS RayPath, so architecturally LoS should be emitted; it also doesn’t appear to be dropped by insertRaypaths() (which writes every returned path unconditionally, filtered only by an antenna-pair option).
- So this looks like the emsolver failing to find/return the direct path specifically once real building/furniture geometry is present in a small-scale indoor scene, even when that geometry doesn’t actually block the direct line.
@minh.yang
The antenna height is defined as below. Essentially, it is the height of the antenna panel, and the ray centroid is assumed to be at the height/2. We will change this definition in 1.6.
The missing LoS will be fixed in 1.6 as well.
