The 1.5.1 prerequisites page lists worker GPUs as RTX 6000 Blackwell, GB10 Grace Blackwell Superchip, RTX 6000 Ada, L40 and L40S. Two things changed from the earlier list and I need to understand both before I buy hardware.
RTX 5090. In April, kpasad1 said in “Is it possible to install AODT on the 4090 or 5090?” that the backend supports RTX 6000 Ada, L40, A100 and H100, and not the 4090 or 5090. That was before Blackwell support landed. RTX 6000 Blackwell is on the list now, and it is the same sm_120 target as the 5090. So the solver binaries presumably carry sm_120.
Does the 5090 work as a 1.5.1 worker on native Ubuntu 22.04? Or is GeForce excluded regardless of compute capability, either by a device check, by the 48 GB VRAM guidance (5090 has 32 GB), or by policy? A plain no is useful. I would rather know before buying a drive and spending a day on the install.
H100 and A100. Both were on the old list. Neither is on the 1.5.1 one. Is that a real support change or just a rewrite? We have an 8x H100 node with fixed credits and a launch procedure we only get to rehearse once, so I want this confirmed before spending it.
Context on why I think sm_120 is present: on our 5090 the worker starts with no SM architecture complaint, the Tokyo scene loads at 5,342 buildings, Warp kernels compile on cuda:0, and the six setup tables export to Iceberg. It fails only at EM solver creation. That is under WSL2, which I know is not a supported worker platform, and I am not asking you to support it. I mention it only because the absence of an arch rejection at startup is what makes me think the binaries changed.
@aditya.chaudhuri1 We have not qualified AODT 1.5.1 with 5090. That means that we will not support any issues steming because of the particular GPU. 32gb is on lower side of 48gb guidance. While feasible, this will constraint your simulation size.
Same with A100/H100. While both will work with AODT 1.5.1, we will not support any issues that are these GPU specific.
One follow-up while the thread is open. Is there a documented way to predict what fits in a given VRAM budget, so I can size scenes for 32 GB rather than finding the ceiling by trial and error? The capacity anchor I’ve seen quoted is 40M rays per RU over up to 25 km² on an L40S at 48 GB. If memory scales roughly with rays × RUs × interaction depth, or with triangle count, even a rough rule would help me decide what to run locally versus on the H100 node.
Concrete case: central Kochi, 4.4 × 4.4 km, 13,896 buildings, 5.86M triangles, 9 cells. That loads fine on the 5090 (I get to EM solver creation). If there’s a rule of thumb for whether a scene that size will fit through the solve at 32 GB, that would save me a lot of guessing.
Understood on the unsupported status for both. The plan is to develop on the 5090 and run anything large on the H100 node, so the constraint is workable.
Got the exact AODT launch command or config you’re using for the Kochi scene?
Send it over and I can help turn it into a quick fit check so you can tell whether to keep it on the 5090 or push it to the H100 node before burning a full run.
@aditya.chaudhuri1 There is no documented way, but the emsolver will estimate the memory and signal if the scenario will or will not fit. The difficulty with providing this kind of guidance is that diffrent use case will use diffrent levers to reduce the footprint. E.g. Would you rather use a smaller map or reduce the antenna count? Or reduce the number of rays? Our upcoming 1.6 release should further reduce the memory foot print.
Thanks, that settles it. I’ll let the emsolver estimate be the fit check and trade map size against ray count per scene rather than look for a general rule. The 1.6 memory reduction is good to know. For the Kochi scene, the working assumption remains: iterate on the 5090 and run full solves on the H100 node. Appreciate the clear answers on support status.
