Hi community:
I am deploying AODT with Ubuntu 22.04.4. The nvidia-smi is:
| NVIDIA-SMI 550.78 Driver Version: 550.78 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A6000 Off | 00000000:04:00.0 Off | Off |
| 56% 81C P2 253W / 300W | 5011MiB / 49140MiB | 86% Default |
| | | N/A |
| 1 NVIDIA RTX A6000 Off | 00000000:82:00.0 Off | Off |
| 30% 35C P8 27W / 300W | 3712MiB / 49140MiB | 38% Default |
| | | N/A |
| 2 NVIDIA RTX A6000 Off | 00000000:83:00.0 Off | Off |
| 30% 34C P8 19W / 300W | 3716MiB / 49140MiB | 41% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1392248 C+G ...cal/share/ov/pkg/asim-1.0.0/kit/kit 4726MiB |
| 0 N/A N/A 1415868 C ./aodt_sim 260MiB |
| 1 N/A N/A 1392248 C+G ...cal/share/ov/pkg/asim-1.0.0/kit/kit 3692MiB |
| 2 N/A N/A 1392248 C+G ...cal/share/ov/pkg/asim-1.0.0/kit/kit 3696MiB |
I trIed to validate EM simulation with Kyoto_flat.usd, which is illustrated in the figure below:
Then, I changed the scenario setting to RAN:
The error message was:
Therefore, I modified the configuration like:
As soon as I start UE mobility, the worker lost connection.
Any idea about the problem? Could you please show me the correct configuration about panel, and the reason that worker lost connection since I encounter the same problem when I use Tokyo.usd for EM simulaion.
