I have downloaded the pruned resnet34-peoplenet model from ngc. After setting the tlt-encoded-model
path to the downloaded etlt file, in the config_infer_primary_peoplnet.txt
file, I am running the following command deepstream-app -c deepstream_app_source1_peoplenet.txt
** ERROR: <main:655>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Configuration file parsing failed
Debug info: gstnvinfer.cpp(769): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
Config file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/tlt_pretrained_models/config_infer_primary_peoplenet.txt
App run failed
config_infer_primary_peoplenet.txt (2.1 KB)
deepstream_app_source1_peoplenet.txt (3.3 KB)
why am I getting this error, how can I fix it?
• gtx 1660
• DeepStream 5.1
