Hello All
I am attempting to time the nppiLabelMarkers_16u_C1IR label marking function from this example:
https://stackoverflow.com/a/57487119/647236
I have surrounded the function with some event timing, but otherwise not changed the example (copied below). The problem is, the reported time is about 100ms which seems several orders too long compared with the paper the documentation cites:
https://arxiv.org/pdf/1708.08180.pdf
I am using Visual Studio 2019. I tried changing from Debug to Release mode:
but, it didn’t seem to make any difference.
In Nsight, in “Cuda Launch Summary”, there is a function “labelMarkers8WayConverge” which takes about 0.1ms. That seems to suggest I am not really timing the labeling function.
Could someone please tell me how to properly time the function?
Cheers
Gary
#include <stdio.h>
#include <nppi_filtering_functions.h>
#include <assert.h>
#define WIDTH 16
#define HEIGHT 16
void my_print(Npp16u *data, int w, int h){
for (int i = 0; i < h; i++)
for (int j = 0; j < w; j++)
if (data[i*w+j] == 255) printf(" *");
else printf("%3hd", data[i * w + j]);
printf("\n");
template <typename T>
__global__ void bb(const T * __restrict__ i, int * __restrict__ maxh, int * __restrict__ minh, int * __restrict__ maxw, int * __restrict__ minw, int height, int width){
int idx = threadIdx.x+blockDim.x*blockIdx.x;
int idy = threadIdx.y+blockDim.y*blockIdx.y;
if ((idx < width) && (idy < height)){
T myval = i[idy*width+idx];
if (myval > 0){
atomicMax(maxw+myval-1, idx);
atomicMin(minw+myval-1, idx);
atomicMax(maxh+myval-1, idy);
atomicMin(minh+myval-1, idy);}
int main(){
Npp16u host_src[WIDTH * HEIGHT] =
0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0,
0, 255,255,255, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0, 0,
0, 255,255,255, 0, 0,255,255,255,255, 0, 0,255, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0,255,255,255, 0, 0, 0,255,255,255,
0, 0, 0, 0, 0, 0, 0, 0,255, 0, 0, 0, 0,255,255,255,
0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,255,255,
0, 255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 255,255,255, 0, 0, 0, 0,255, 0, 0, 0, 0, 0, 0, 0,
0, 255,255,255,255, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0,
0, 0,255,255,255, 0,255,255,255,255,255, 0, 0, 0, 0, 0,
0, 0, 0,255, 0, 0, 0,255,255,255, 0, 0, 0, 0, 0, 0,
0, 255,255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,255,255,
0, 255,255,255, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
Npp16u * device_src;
cudaMalloc((void**)&device_src, sizeof(Npp16u) * WIDTH * HEIGHT);
cudaMemcpy(device_src, host_src, sizeof(Npp16u) * WIDTH * HEIGHT, cudaMemcpyHostToDevice);
int buffer_size;
NppiSize source_roi = { WIDTH, HEIGHT };
NppStatus e = nppiLabelMarkersGetBufferSize_16u_C1R(source_roi, &buffer_size);
assert(e == NPP_NO_ERROR);
Npp8u * buffer;
cudaMalloc((void**)&buffer, buffer_size);
int max;
cudaEvent_t startEvent, stopEvent;
cudaEventCreate(&startEvent);
cudaEventCreate(&stopEvent);
cudaEventRecord(startEvent, 0);
e = nppiLabelMarkers_16u_C1IR(device_src, sizeof(Npp16u) * WIDTH, source_roi, (Npp16u)1, nppiNormInf, &max, buffer);
cudaEventRecord(stopEvent, 0);
cudaEventSynchronize(stopEvent);
float ms;
cudaEventElapsedTime(&ms, startEvent, stopEvent);
printf("\nelapsed time: %f ms", ms);
printf("initial max: %d\n", max);
int bs;
e = nppiCompressMarkerLabelsGetBufferSize_16u_C1R (1, &bs);
if (bs>buffer_size){
buffer_size = bs;
cudaFree(buffer);
cudaMalloc(&buffer, buffer_size);}
e = nppiCompressMarkerLabels_16u_C1IR(device_src, sizeof(Npp16u)*WIDTH, source_roi, max, &max, buffer);
int *maxw, *maxh, *minw, *minh, *d_maxw, *d_maxh, *d_minw, *d_minh;
maxw = new int[max];
maxh = new int[max];
minw = new int[max];
minh = new int[max];
cudaMalloc(&d_maxw, max*sizeof(int));
cudaMalloc(&d_maxh, max*sizeof(int));
cudaMalloc(&d_minw, max*sizeof(int));
cudaMalloc(&d_minh, max*sizeof(int));
for (int i = 0; i < max; i++){
maxw[i] = 0;
maxh[i] = 0;
minw[i] = WIDTH;
minh[i] = HEIGHT;}
cudaMemcpy(d_maxw, maxw, max*sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(d_maxh, maxh, max*sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(d_minw, minw, max*sizeof(int), cudaMemcpyHostToDevice);
cudaMemcpy(d_minh, minh, max*sizeof(int), cudaMemcpyHostToDevice);
dim3 block(32,32);
dim3 grid((WIDTH+block.x-1)/block.x, (HEIGHT+block.y-1)/block.y);
bb<<<grid, block>>>(device_src, d_maxh, d_minh, d_maxw, d_minw, HEIGHT, WIDTH);
cudaMemcpy(maxw, d_maxw, max*sizeof(int), cudaMemcpyDeviceToHost);
cudaMemcpy(maxh, d_maxh, max*sizeof(int), cudaMemcpyDeviceToHost);
cudaMemcpy(minw, d_minw, max*sizeof(int), cudaMemcpyDeviceToHost);
cudaMemcpy(minh, d_minh, max*sizeof(int), cudaMemcpyDeviceToHost);
Npp16u *dst = new Npp16u[WIDTH * HEIGHT];
cudaMemcpy(dst, device_src, sizeof(Npp16u) * WIDTH * HEIGHT, cudaMemcpyDeviceToHost);
printf("*******INPUT************\n");
my_print(host_src, WIDTH, HEIGHT);
printf("******OUTPUT************\n");
my_print(dst, WIDTH,HEIGHT);
printf("compressed max: %d\n", max);
printf("bounding boxes:\n");
printf("label %d, maxh: %d, minh: %d, maxw: %d, minw: %d\n", i+1, maxh[i], minh[i], maxw[i], minw[i]);
