Appear errors when install sdkmanager
sdk start well but then appear an error in CUD dependency error
There is a “EXPORT LOGS” button on your sdkm GUI. Press it and share the file here.
21:37:35 INFO: CUDA Toolkit for L4T - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb to /home/marcos/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
21:42:40 ERROR: CUDA Toolkit for L4T - target: Download request timed out after 60 seconds. Closing connections
21:42:40 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
21:42:40 ERROR: CUDA Toolkit for L4T - target: download failed
21:42:40 : CUDA Toolkit for L4T - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb failed, retrying 1…
21:42:40 INFO: CUDA Toolkit for L4T - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb to /home/marcos/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
21:46:43 ERROR: CUDA Toolkit for L4T - target: Download request timed out after 60 seconds. Closing connections
21:46:43 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
21:46:43 ERROR: CUDA Toolkit for L4T - target: download failed
21:46:43 : CUDA Toolkit for L4T - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb failed, retrying 2…
21:46:44 INFO: CUDA Toolkit for L4T - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb to /home/marcos/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
21:48:48 ERROR: CUDA Toolkit for L4T - target: Download request timed out after 60 seconds. Closing connections
21:48:48 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
21:48:48 ERROR: CUDA Toolkit for L4T - target: download failed
21:48:48 : CUDA Toolkit for L4T - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb failed, retrying 3…
21:48:49 INFO: CUDA Toolkit for L4T - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb to /home/marcos/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
21:48:57 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
21:50:51 ERROR: CUDA Toolkit for L4T - target: Download request timed out after 60 seconds. Closing connections
21:50:51 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
21:50:51 ERROR: CUDA Toolkit for L4T - target: download failed
21:50:51 : CUDA Toolkit for L4T - target: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb failed, retrying 4…
21:50:52 INFO: CUDA Toolkit for L4T - target: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.6.2/Jetson_462_b5/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb to /home/marcos/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb
21:52:54 ERROR: CUDA Toolkit for L4T - target: Download request timed out after 60 seconds. Closing connections
21:52:54 ERROR: CUDA Toolkit for L4T - target: Download ‘CUDA Toolkit for L4T’ failure
21:52:54 ERROR: CUDA Toolkit for L4T - target: download failed
This looks like a server problem, but nit srue if any network connetion problme.
Are you able to download this from browser? If you can, could you check if the account you are using to login sdkmanager is same as that one you are using to login the website?
