Appending Cnfigauration files for optimized USB Performance
Hello Guys,
I hope you all are doing well.
I am working with the Nvidia Jetson Xavier NX and I wish to use USB3 based CMOS cameras for a project and the necessary requirement for the camera to work is thet the usbcore.usbfs memory should be 256 mb. By default it is 16 mb. I tried to change it once by adding “usbcore.usbfs_memory_mb=256” to the APPEND line in the “/boot/extlinux/extlinux.conf” file. Also the line was hashed out before and it did not make any changes so I unhashed it and then the system crashed (on boot it would stop at black screen with a blinking cursor) and my memory card was corrupted and had to buy a new one. Please suggest a safe and releiable way of doing this.
Many thanks in advance.
What does that mean “Also the line was hashed out before and it did not make any changes so I unhashed it”?
Which release are you using?
Hey Wayne. Thanks for the reply !
By hashed out i ment to say commented out.
But anyways I found my mistake and problem is solved.
