Apt install cuda-profiler-api-11-4 failed
Oh… this is so exceptionally dirty…
I went and edited /var/lib/apt/lists/repo.download.nvidia.com_jetson_common_dists_r34.1_main_binary-arm64_Packages and removed the cuda-profiler-api-11-4 dependency from cuda-libraries-dev-11-4. apt install nvidia-jetpack seems to be proceeding as expected… we’ll see if it it works when I’m done.
Ohhhh that didn’t work.
 cuda-libraries-dev-11-4 depends on cuda-profiler-api-11-4 (>= 11.4.239); however:
  Package cuda-profiler-api-11-4 is not installed.
dpkg: error processing package cuda-libraries-dev-11-4 (--configure):
 dependency problems - leaving unconfigured
Edit: As far as using the container goes, our system also relies on getting images from a camera that’s attached to a Mellanox NIC that does RDMA. I suspect that won’t work from inside a container.
Really thanks for this information.
We are checking this issue internally.
The issue is fixed.
Please try the CUDA installation again.
Worked great! Thanks!
I am also getting this error.
This is on a fresh install with SDKManager on the ODIN. if you then do an apt upgrade, you get the following:
root@ubuntu:/home/aerium# apt-upgrade
bash: apt-upgrade: command not found
root@ubuntu:/home/aerium# apt upgrade
Reading package lists... Done
Building dependency tree
![Screenshot from 2022-06-28 12-15-33|690x388](upload://syaX34SfcDKW6QtP6byI0jiWXWc.jpeg)
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
 cuda-libraries-dev-11-4 : Depends: cuda-profiler-api-11-4 (>= 11.4.239) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
also to note, the Ubuntu Software Updater also returns a broken status:
see uploaded file
also to note apt install is now no longer working because of this issue.
This is probably going to be resolved by someone who is in control of the .deb packages. However, I have found a solution.
There was a similar issue on stack overflow for fixing an old cuda instillation on x86 I found a while back but lost the link :(
Try this:
sudo apt --fix-broken install -o Dpkg::Options::="--force-overwrite"
Hi, d.petkovsek
Thanks for this information.
Hi, bbullas
Please let us know if the issue remains after applying the fix-broken command.
thanks for your comment, it works !
not fixed for Xavier NX Dev Kit.
Hi, bob3u3p3
Could you share the log about the failure?
Yes the following command has fixed the issue :)
Steps:
Loaded new image and upgraded the OS to make sure it is up to date. Also removed clutter.
Loaded the CUDA utilities using SDKManager
executed sudo apt-upgrade.
Log File:
Script started on 2022-06-30 13:59:09-06:00 [TERM=“xterm-256color” TTY=“/dev/pts/0” COLUMNS=“108” LINES=“78”]
sudo apt update
0% [Working]e[0m
Hit:1 https://repo.download.nvidia.com/jetson/common r34.1 InRelease
Hit:2 Index of /ubuntu-ports focal InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t194 r34.1 InRelease
Hit:4 Index of /ubuntu-ports focal-updates InRelease
Hit:5 Index of /ubuntu-ports focal-backports InRelease
Hit:6 Index of /ubuntu-ports focal-security InRelease
Reading package lists… Done
Reading state information… Done
6 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
apt upgrade
Calculating upgrade… Done
The following package was automatically installed and is no longer required:
cuda-nvprof-11-4
Use ‘sudo apt autoremove’ to remove it.
The following NEW packages will be installed:
The following packages will be upgraded:
cuda-command-line-tools-11-4 cuda-compiler-11-4 cuda-libraries-11-4 cuda-libraries-dev-11-4
cuda-toolkit-11-4 cuda-visual-tools-11-4
6 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 34.6 kB of archives.
After this operation, 90.1 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-command-line-tools-11-4 arm64 11.4.14-1 [2,478 B]
Get:2 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-compiler-11-4 arm64 11.4.14-1 [2,440 B]
Get:3 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-libraries-11-4 arm64 11.4.14-1 [2,512 B]
Get:4 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-profiler-api-11-4 arm64 11.4.239-1 [18.6 kB]
Get:5 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-libraries-dev-11-4 arm64 11.4.14-1 [2,552 B]
Get:6 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-toolkit-11-4 arm64 11.4.14-1 [3,204 B]
Get:7 https://repo.download.nvidia.com/jetson/common r34.1/main arm64 cuda-visual-tools-11-4 arm64 11.4.14-1 [2,856 B]
100% [Working]e[0m
Fetched 34.6 kB in 0s (92.5 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 100%
(Reading database … 159428 files and directories currently installed.)
Preparing to unpack …/0-cuda-command-line-tools-11-4_11.4.14-1_arm64.deb …
Unpacking cuda-command-line-tools-11-4 (11.4.14-1) over (11.4.14-1) …
Unpacking cuda-compiler-11-4 (11.4.14-1) over (11.4.14-1) …
Unpacking cuda-libraries-11-4 (11.4.14-1) over (11.4.14-1) …
Unpacking cuda-profiler-api-11-4 (11.4.239-1) …
e[1mdpkg:e[0m error processing archive /tmp/apt-dpkg-install-Dmtuud/3-cuda-profiler-api-11-4_11.4.239-1_arm64.deb (–unpack):
trying to overwrite ‘/usr/local/cuda-11.4/targets/aarch64-linux/include/cudaProfiler.h’, which is also in package cuda-nvprof-11-4 11.4.166-1
Unpacking cuda-libraries-dev-11-4 (11.4.14-1) over (11.4.14-1) …
Unpacking cuda-toolkit-11-4 (11.4.14-1) over (11.4.14-1) …
Unpacking cuda-visual-tools-11-4 (11.4.14-1) over (11.4.14-1) …
Errors were encountered while processing:
Sub-process /usr/bin/dpkg returned an error code (1)e[0m
exit
Script done on 2022-06-30 14:00:11-06:00 [COMMAND_EXIT_CODE=“100”]
Also, apt update says all packages are up to date
apt upgrade returns this error:
bob@ubuntu:~/Desktop$ sudo apt upgrade
You might want to run ‘apt --fix-broken install’ to correct these.
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
bob@ubuntu:~/Desktop$ exit
–fix-broken install does not fix the error
Also, the update built into the OS reports the same error
Seems some issues occur in the cache .deb file below:
Could you go to the folder and delete the package manually and try it again?
file does not exist.
I deleted /usr/local/cuda-11.4/ to get rid of everything, and redownload, no help
bottom line, if I can’t run apt upgrade, I cannot install the packages I need.
IMHO this is the same problem described by bbullas, but I am trying to point out the root problem, which is the fact that the file write failure of :
Preparing to unpack …/cuda-profiler-api-11-4_11.4.239-1_arm64.deb …
dpkg: error processing archive /var/cache/apt/archives/cuda-profiler-api-11-4_11.4.239-1_arm64.deb (–unpa
ck):
E: Sub-process /usr/bin/dpkg returned an error code (1)
Yep, this one fixed it for me too: sudo apt --fix-broken install -o Dpkg::Options::="--force-overwrite".
I was getting the following error for a $ sudo apt --fix-broken install:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 0 B/18.6 kB of archives.
(Reading database ... 161620 files and directories currently installed.)
Preparing to unpack .../cuda-profiler-api-11-4_11.4.239-1_arm64.deb ...
Unpacking cuda-profiler-api-11-4 (11.4.239-1) ...
dpkg: error processing archive /var/cache/apt/archives/cuda-profiler-api-11-4_11.4.239-1_arm64.deb (--un
pack):
 trying to overwrite '/usr/local/cuda-11.4/targets/aarch64-linux/include/cudaProfiler.h', which is also
Thanks @d.petkovsek !
Hi, bob3u3p3
It looks like the previous broken package still causes some errors in your environment.
Is reflashing an option for you?
If yes, could you give it a try?
It works for me.
