Hi everyone,
I’m working on a custom carrier board for the Jetson AGX Orin, based on the NVIDIA AGX Orin DevKit reference design. The board uses the same AQR113C 10GbE PHY and W25Q40EWUXIE SPI NOR Flash.
I understand that the AQR113C needs firmware in the external Flash to work correctly. I have the firmware and programming tools from Marvell, but I’m wondering if there is a faster way to bring up the PHY.
For example, if I take the W25Q40EWUXIE from a working AGX Orin DevKit and install it on my custom board, would the AQR113C work directly?
Are there any risks or board-specific configurations stored in the DevKit Flash that could cause problems on a custom carrier board?
Any advice or recommended procedure would be appreciated.
Thank you!
