Hi Nvidia Teams,
With AGX Orin devkit, we could read phy LED by phytool and get these values.
Would like to know where is the 10G phy LED config setting stored?
Please kindly to provide this information.
Regards
Hi Nvidia Teams,
Regards
it is located here
kernel/3rdparty/canonical/linux-jammy/kernel-source/drivers/net/phy/aquantia_main.c
Hi WayneWWW,
I know the source code is in aquantia_main.c
The source code indicate the value is from devicetree property > “aquantia,led-mode”
But I can not find keywork(aquantia,led-mode) in nvidia devicetree folder hardware/
Regards
Then we are not setting that. You could contact Aquantia for more detail.
Hi WayneWWW,
Aquantia said that their firmware didn’t have led config included.
So it make me confused that where is the led config settging in nvidia AGX orin devkit??
Regards
There should be still some default LED mode there. We didn’t configure that part explicitly.
PHY data sheet should provide more info.
