Hello Jerry.
The AR0144 can prepend 2 lines of “embedded data” before the pixel data. It can also append 2 lines of “embedded statistics” after the pixel data. On the last post, I had disabled the embedded statistics but the embedded_metadata_heigth parameter was still set to 4.
I tried out various combinations meanwhile. In all traces I got at least one line with “tag:CSIMUX_FRAME…data:0x00400060”. Where is this data value 0x00400060 coming from? Can I look up its meaning myself somewhere in nvidias documentation?
With embedded_metadata_height = 2 and only “embedded data” I get a trace without the EMBED_INCOMPLETE entry. With embedded_metadata_height = 4 and both “embedded data” and “embedded statistics” enabled I get a similar trace, differing only in timestamp values. Every now and then yavta produces a whole RAW frame, often it creates an empty file.
4 lines of metadata: embedded data and statistics. yavta + trace + syslog. Empty file output.
logger '=== yavta + trace a ===' ; ~/soft/yavta/yavta-master/yavta /dev/video0 -c10 -n1 -Fdata.ar0144a
Device /dev/video0 opened: vi-output, ar0144 30-0010 (platform:15700000.vi:0).
Video format: RG12 (32314752) 1280x720
3 buffers requested.
length: 1843200 offset: 0
Buffer 0 mapped at address 0x7f9cec3000.
length: 1843200 offset: 1843200
Buffer 1 mapped at address 0x7f9cd01000.
length: 1843200 offset: 3686400
Buffer 2 mapped at address 0x7f9cb3f000.
Warning: bytes used 0 != image size 1843200
0 (0) [-] 0 0 bytes 0.000000 1540908633.784294
Unable to queue buffer (22).
Unable to requeue buffer (22).
Unable to release buffers: 16.
Oct 30 15:10:33 tegra-ubuntu nvidia: === yavta + trace a ===
Oct 30 15:10:33 tegra-ubuntu rsyslogd-2007: action 'action 9' suspended, next retry is Tue Oct 30 15:11:03 2018 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.844747] ar0144 30-0010: ar0144_power_on: power on
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.857981] nvcsi 150c0000.nvcsi: csi port:0
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.862622] nvcsi 150c0000.nvcsi: csi port:2
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.867456] nvcsi 150c0000.nvcsi: csi port:4
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.887617] nvcsi 150c0000.nvcsi: csi4_start_streaming ports index=0, lanes=2
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.894826] nvcsi 150c0000.nvcsi: csi4_stream_init
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.899662] nvcsi 150c0000.nvcsi: csi4_stream_config
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.904660] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.912600] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.917324] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.923102] nvcsi 150c0000.nvcsi: cil_settingtime is pulled from device
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.929763] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 102
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.936220] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.942585] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 25
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.949504] ar0144 30-0010: ar0144_s_stream++
Oct 30 15:10:33 tegra-ubuntu kernel: [ 71.953894] ar0144 30-0010: ar0144_start_stream()
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.209173] ar0144 30-0010: ar0144_start_stream() R0x3064=1982, data=1, stats=1
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.218848] ar0144 30-0010: ar0144_start_stream() - success
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.239252] video4linux video0: release_buffer: capture init latency is 354 ms
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.246588] video4linux video0: release_buffer: release buf[ffffffc1e48b4c00] frame[1] to user-space
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.253590] tegra-vi4 15700000.vi: Status: 2 channel:00 frame:0002
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.253610] tegra-vi4 15700000.vi: timestamp sof 100053266720 eof 100067627264 data 0x00400060
Oct 30 15:10:33 tegra-ubuntu kernel: [ 72.253623] tegra-vi4 15700000.vi: capture_id 1 stream 0 vchan 0
Oct 30 15:10:38 tegra-ubuntu kernel: [ 77.235698] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 15:10:38 tegra-ubuntu kernel: [ 77.242213] video4linux video0: release_buffer: release buf[ffffffc1e31d7800] frame[2] to user-space
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.251486] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.257231] video4linux video0: release_buffer: release buf[ffffffc1e31d6c00] frame[3] to user-space
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.267013] ar0144 30-0010: ar0144_s_stream++
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.272190] nvcsi 150c0000.nvcsi: csi4_stop_streaming ports index=0, lanes=2
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.279399] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.284348] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000002
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.290203] nvcsi 150c0000.nvcsi: csi4_stream_check_status
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.295810] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.303741] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.312027] nvcsi 150c0000.nvcsi: csi4_cil_check_status 353
Oct 30 15:10:39 tegra-ubuntu kernel: [ 78.320500] ar0144 30-0010: ar0144_power_off: power off
# tracer: nop
# entries-in-buffer/entries-written: 49/49 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:1-114 [000] ...1 71.925181: rtos_queue_peek_from_isr_failed: tstamp:3115646092 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 71.925185: rtcpu_start: tstamp:3115647477
kworker/0:1-114 [000] ...1 72.077169: rtos_queue_peek_from_isr_failed: tstamp:3120647032 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 72.233174: rtos_queue_peek_from_isr_failed: tstamp:3125647580 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 72.285112: rtcpu_vinotify_handle_msg: tstamp:3126594171 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:3126593645 data:0x00400060
kworker/0:1-114 [000] ...1 72.285124: rtcpu_vinotify_handle_msg: tstamp:3126663882 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:3126663357 data:0x00000000
kworker/0:1-114 [000] ...1 72.285127: rtcpu_vinotify_handle_msg: tstamp:3126665076 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:3126664585 data:0x00000001
kworker/0:1-114 [000] ...1 72.285131: rtcpu_vinotify_handle_msg: tstamp:3126670705 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:3126670207 data:0x08000000
kworker/0:1-114 [000] ...1 72.285134: rtcpu_vinotify_handle_msg: tstamp:3127112610 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:3127112088 data:0x02cf0002
kworker/0:1-114 [000] ...1 72.285138: rtcpu_vinotify_handle_msg: tstamp:3127114011 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:3127113352 data:0x00400060
kworker/0:1-114 [000] ...1 72.285141: rtcpu_vinotify_handle_msg: tstamp:3127114354 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:3127113356 data:0x00000000
kworker/0:1-114 [000] ...1 72.389087: rtos_queue_peek_from_isr_failed: tstamp:3130648102 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 72.545048: rtos_queue_peek_from_isr_failed: tstamp:3135648591 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 72.700979: rtos_queue_peek_from_isr_failed: tstamp:3140649098 queue:0x0b4a3c58
kworker/0:1-114 [000] ...1 72.856942: rtos_queue_peek_from_isr_failed: tstamp:3145649603 queue:0x0b4a3c58
4 lines of metadata: embedded data and statistics. yavta + trace + syslog. One frame output.
nvidia@tegra-ubuntu:~/soft/kernel/debuging/metadata-tests/4ds$ logger '=== yavta + trace b ===' ; ~/soft/yavta/yavta-master/yavta /dev/video0 -c10 -n1 -Fdata.ar0144b
Buffer 0 mapped at address 0x7f8b339000.
Buffer 1 mapped at address 0x7f8b177000.
Buffer 2 mapped at address 0x7f8afb5000.
0 (0) [E] 0 1843200 bytes 0.000000 1540908678.598426
Unable to queue buffer (5).
Unable to requeue buffer (5).
Oct 30 15:11:18 tegra-ubuntu nvidia: === yavta + trace b ===
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.646333] ar0144 30-0010: ar0144_power_on: power on
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.659834] nvcsi 150c0000.nvcsi: csi port:0
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.664486] nvcsi 150c0000.nvcsi: csi port:2
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.669239] nvcsi 150c0000.nvcsi: csi port:4
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.696963] nvcsi 150c0000.nvcsi: csi4_start_streaming ports index=0, lanes=2
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.704125] nvcsi 150c0000.nvcsi: csi4_stream_init
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.708956] nvcsi 150c0000.nvcsi: csi4_stream_config
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.713954] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.721888] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.726614] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.732368] nvcsi 150c0000.nvcsi: cil_settingtime is pulled from device
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.738982] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 102
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.745426] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.751779] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 25
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.758660] ar0144 30-0010: ar0144_s_stream++
Oct 30 15:11:18 tegra-ubuntu kernel: [ 116.763021] ar0144 30-0010: ar0144_start_stream()
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.016079] ar0144 30-0010: ar0144_start_stream() R0x3064=1982, data=1, stats=1
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.025600] ar0144 30-0010: ar0144_start_stream() - success
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.046040] video4linux video0: release_buffer: capture init latency is 355 ms
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.053504] video4linux video0: release_buffer: release buf[ffffffc07516b400] frame[1] to user-space
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.062876] tegra-vi4 15700000.vi: Status: 2 channel:00 frame:0002
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.069286] tegra-vi4 15700000.vi: timestamp sof 144860017632 eof 144874378176 data 0x00400060
Oct 30 15:11:18 tegra-ubuntu kernel: [ 117.078814] tegra-vi4 15700000.vi: capture_id 3 stream 0 vchan 0
Oct 30 15:11:23 tegra-ubuntu kernel: [ 122.044018] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 15:11:23 tegra-ubuntu kernel: [ 122.050525] video4linux video0: release_buffer: release buf[ffffffc075169000] frame[2] to user-space
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.060015] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.065728] video4linux video0: release_buffer: release buf[ffffffc075168400] frame[3] to user-space
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.075502] ar0144 30-0010: ar0144_s_stream++
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.080590] nvcsi 150c0000.nvcsi: csi4_stop_streaming ports index=0, lanes=2
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.087905] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.092688] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000002
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.098568] nvcsi 150c0000.nvcsi: csi4_stream_check_status
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.104330] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.112482] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.121085] nvcsi 150c0000.nvcsi: csi4_cil_check_status 353
Oct 30 15:11:24 tegra-ubuntu kernel: [ 123.134591] ar0144 30-0010: ar0144_power_off: power off
# tracer: nop
# _-----=> irqs-off
# ||| / delay
kworker/0:3-1331 [000] ...1 116.696015: rtos_queue_peek_from_isr_failed: tstamp:4515814881 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 116.696028: rtcpu_start: tstamp:4515816416
kworker/0:3-1331 [000] ...1 116.852007: rtos_queue_peek_from_isr_failed: tstamp:4520815815 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.062873: rtos_queue_peek_from_isr_failed: tstamp:4525816401 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.062894: rtcpu_vinotify_handle_msg: tstamp:4526805127 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:231837315 data:0x00400060
kworker/0:3-1331 [000] ...1 117.062897: rtcpu_vinotify_handle_msg: tstamp:4526874836 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:231907028 data:0x00000000
kworker/0:3-1331 [000] ...1 117.062900: rtcpu_vinotify_handle_msg: tstamp:4526876046 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:231908255 data:0x00000001
kworker/0:3-1331 [000] ...1 117.062903: rtcpu_vinotify_handle_msg: tstamp:4526882492 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:231914699 data:0x08000000
kworker/0:3-1331 [000] ...1 117.062905: rtcpu_vinotify_handle_msg: tstamp:4527323559 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:232355758 data:0x02cf0002
kworker/0:3-1331 [000] ...1 117.062908: rtcpu_vinotify_handle_msg: tstamp:4527324978 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:232357022 data:0x00400060
kworker/0:3-1331 [000] ...1 117.062911: rtcpu_vinotify_handle_msg: tstamp:4527325320 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:232357025 data:0x00000000
kworker/0:3-1331 [000] ...1 117.216061: rtos_queue_peek_from_isr_failed: tstamp:4530817006 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.372052: rtos_queue_peek_from_isr_failed: tstamp:4535817400 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.528098: rtos_queue_peek_from_isr_failed: tstamp:4540817902 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.684074: rtos_queue_peek_from_isr_failed: tstamp:4545818409 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.840074: rtos_queue_peek_from_isr_failed: tstamp:4550818915 queue:0x0b4a3c58
kworker/0:3-1331 [000] ...1 117.996057: rtos_queue_peek_from_isr_failed: tstamp:4555819424 queue:0x0b4a3c58
I also tried setting embedded_metadata_height to 1 (which should be nonsense). With at least embedded data enabled, yavta produces 10 valid looking RAW files. But it took about 5 seconds for each grabbed frame.
1 lines of metadata: embedded data and statistics. yavta + trace + syslog. Ten frames output @ 0.2fps.
Buffer 0 mapped at address 0x7f8201b000.
Buffer 1 mapped at address 0x7f81e59000.
Buffer 2 mapped at address 0x7f81c97000.
0 (0) [E] 0 1843200 bytes 0.000000 1540912798.307103
1 (1) [E] 1 1843200 bytes 0.000000 1540912803.303505
2 (2) [-] 2 1843200 bytes 0.000000 1540912808.307594
3 (0) [-] 3 1843200 bytes 0.000000 1540912813.311579
4 (1) [-] 4 1843200 bytes 0.000000 1540912818.315485
5 (2) [-] 5 1843200 bytes 0.000000 1540912823.319572
6 (0) [-] 6 1843200 bytes 0.000000 1540912828.323487
7 (1) [-] 7 1843200 bytes 0.000000 1540912833.327464
8 (2) [-] 8 1843200 bytes 0.000000 1540912838.331516
9 (0) [-] 9 1843200 bytes 0.000000 1540912843.335605
Captured 9 frames in 45.109949 seconds (0.199513 fps, 408601.659026 B/s).
3 buffers released.
Oct 30 16:19:52 tegra-ubuntu nvidia: === yavta + trace a ===
Oct 30 16:19:52 tegra-ubuntu rsyslogd-2007: action 'action 9' suspended, next retry is Tue Oct 30 16:20:22 2018 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.266890] ar0144 30-0010: ar0144_power_on: power on
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.279029] nvcsi 150c0000.nvcsi: csi port:0
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.283474] nvcsi 150c0000.nvcsi: csi port:2
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.287930] nvcsi 150c0000.nvcsi: csi port:4
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.298105] nvcsi 150c0000.nvcsi: csi4_start_streaming ports index=0, lanes=2
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.305263] nvcsi 150c0000.nvcsi: csi4_stream_init
Oct 30 16:19:52 tegra-ubuntu kernel: [ 82.310088] nvcsi 150c0000.nvcsi: csi4_stream_config
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.315080] nvcsi 150c0000.nvcsi: csi4_stream_config (0) read VC0_DPCM_CTRL = 00000000
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.323014] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.327740] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.333518] nvcsi 150c0000.nvcsi: cil_settingtime is pulled from device
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.340146] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 102
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.346669] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.353054] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 25
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.359955] ar0144 30-0010: ar0144_s_stream++
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.364331] ar0144 30-0010: ar0144_start_stream()
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.594069] ar0144 30-0010: ar0144_start_stream() R0x3064=1982, data=1, stats=1
Oct 30 16:19:53 tegra-ubuntu kernel: [ 82.602742] ar0144 30-0010: ar0144_start_stream() - success
Oct 30 16:19:58 tegra-ubuntu kernel: [ 87.606197] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:19:58 tegra-ubuntu kernel: [ 87.612822] video4linux video0: release_buffer: capture init latency is 5316 ms
Oct 30 16:19:58 tegra-ubuntu kernel: [ 87.620317] video4linux video0: release_buffer: release buf[ffffffc1ca7f2400] frame[1] to user-space
Oct 30 16:20:03 tegra-ubuntu kernel: [ 92.610155] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:03 tegra-ubuntu kernel: [ 92.616700] video4linux video0: release_buffer: release buf[ffffffc1ca7f3c00] frame[2] to user-space
Oct 30 16:20:08 tegra-ubuntu kernel: [ 97.614178] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:08 tegra-ubuntu kernel: [ 97.620722] video4linux video0: release_buffer: release buf[ffffffc1ca7f3000] frame[3] to user-space
Oct 30 16:20:13 tegra-ubuntu kernel: [ 102.618185] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:13 tegra-ubuntu kernel: [ 102.624731] video4linux video0: release_buffer: release buf[ffffffc1ca7f2400] frame[4] to user-space
Oct 30 16:20:18 tegra-ubuntu kernel: [ 107.622182] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:18 tegra-ubuntu kernel: [ 107.628718] video4linux video0: release_buffer: release buf[ffffffc1ca7f3c00] frame[5] to user-space
Oct 30 16:20:23 tegra-ubuntu kernel: [ 112.626185] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:23 tegra-ubuntu kernel: [ 112.632779] video4linux video0: release_buffer: release buf[ffffffc1ca7f3000] frame[6] to user-space
Oct 30 16:20:23 tegra-ubuntu rsyslogd-2007: action 'action 9' suspended, next retry is Tue Oct 30 16:20:53 2018 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Oct 30 16:20:28 tegra-ubuntu kernel: [ 117.630153] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:28 tegra-ubuntu kernel: [ 117.636695] video4linux video0: release_buffer: release buf[ffffffc1ca7f2400] frame[7] to user-space
Oct 30 16:20:33 tegra-ubuntu kernel: [ 122.634173] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:33 tegra-ubuntu kernel: [ 122.640713] video4linux video0: release_buffer: release buf[ffffffc1ca7f3c00] frame[8] to user-space
Oct 30 16:20:38 tegra-ubuntu kernel: [ 127.638190] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:38 tegra-ubuntu kernel: [ 127.644740] video4linux video0: release_buffer: release buf[ffffffc1ca7f3000] frame[9] to user-space
Oct 30 16:20:43 tegra-ubuntu kernel: [ 132.642179] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:43 tegra-ubuntu kernel: [ 132.648721] video4linux video0: release_buffer: release buf[ffffffc1ca7f2400] frame[10] to user-space
Oct 30 16:20:48 tegra-ubuntu kernel: [ 137.646201] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
Oct 30 16:20:48 tegra-ubuntu kernel: [ 137.652741] video4linux video0: release_buffer: release buf[ffffffc1ca7f3000] frame[11] to user-space
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.662187] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.667928] video4linux video0: release_buffer: release buf[ffffffc1ca7f2400] frame[12] to user-space
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.677974] ar0144 30-0010: ar0144_s_stream++
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.682974] nvcsi 150c0000.nvcsi: csi4_stop_streaming ports index=0, lanes=2
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.690724] nvcsi 150c0000.nvcsi: csi4_phy_config
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.696050] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000002
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.701891] nvcsi 150c0000.nvcsi: csi4_stream_check_status
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.707474] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000004
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.715467] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000004
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.723723] nvcsi 150c0000.nvcsi: csi4_cil_check_status 353
Oct 30 16:20:49 tegra-ubuntu kernel: [ 138.736560] ar0144 30-0010: ar0144_power_off: power off
# tracer: nop
# entries-in-buffer/entries-written: 3786/3786 #P:4
# _-----=> irqs-off
# ||| / delay
kworker/3:2-266 [003] ...1 82.306057: rtos_queue_peek_from_isr_failed: tstamp:3441790745 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 82.306062: rtcpu_start: tstamp:3441791496
kworker/3:2-266 [003] ...1 82.462066: rtos_queue_peek_from_isr_failed: tstamp:3446791607 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 82.618077: rtos_queue_peek_from_isr_failed: tstamp:3451792110 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 82.670110: rtcpu_vinotify_handle_msg: tstamp:3451900454 tag:CSIMUX_FRAME channel:0x00 frame:1 vi_tstamp:3451900035 data:0x00400060
kworker/3:2-266 [003] ...1 82.670112: rtcpu_vinotify_handle_msg: tstamp:3451970162 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:3451969747 data:0x00000000
kworker/3:2-266 [003] ...1 82.670113: rtcpu_vinotify_handle_msg: tstamp:3451970765 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:3451970353 data:0x00010800
kworker/3:2-266 [003] ...1 82.670114: rtcpu_vinotify_handle_msg: tstamp:3451971378 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:3451970975 data:0x00000801
kworker/3:2-266 [003] ...1 82.670114: rtcpu_vinotify_handle_msg: tstamp:3452418885 tag:CHANSEL_FAULT channel:0x00 frame:2 vi_tstamp:3452418478 data:0x02cf0802
kworker/3:2-266 [003] ...1 82.670115: rtcpu_vinotify_handle_msg: tstamp:3452420316 tag:CSIMUX_FRAME channel:0x00 frame:2 vi_tstamp:3452419742 data:0x00400060
kworker/3:2-266 [003] ...1 82.670115: rtcpu_vinotify_handle_msg: tstamp:3452420451 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:3452419745 data:0x00000000
kworker/3:2-266 [003] ...1 82.670116: rtcpu_vinotify_handle_msg: tstamp:3452939859 tag:CSIMUX_FRAME channel:0x00 frame:3 vi_tstamp:3452939448 data:0x00400060
kworker/3:2-266 [003] ...1 82.722081: rtcpu_vinotify_handle_msg: tstamp:3453459566 tag:CSIMUX_FRAME channel:0x00 frame:4 vi_tstamp:3453459155 data:0x00400060
kworker/3:2-266 [003] ...1 82.722084: rtcpu_vinotify_handle_msg: tstamp:3453979269 tag:CSIMUX_FRAME channel:0x00 frame:5 vi_tstamp:3453978862 data:0x00400060
kworker/3:2-266 [003] ...1 82.722085: rtcpu_vinotify_handle_msg: tstamp:3454498976 tag:CSIMUX_FRAME channel:0x00 frame:6 vi_tstamp:3454498568 data:0x00400060
kworker/3:2-266 [003] ...1 82.722085: rtcpu_vinotify_handle_msg: tstamp:3455018686 tag:CSIMUX_FRAME channel:0x00 frame:7 vi_tstamp:3455018275 data:0x00400060
kworker/3:2-266 [003] ...1 82.774073: rtcpu_vinotify_handle_msg: tstamp:3455538392 tag:CSIMUX_FRAME channel:0x00 frame:8 vi_tstamp:3455537981 data:0x00400060
kworker/3:2-266 [003] ...1 82.774076: rtcpu_vinotify_handle_msg: tstamp:3456058095 tag:CSIMUX_FRAME channel:0x00 frame:9 vi_tstamp:3456057688 data:0x00400060
kworker/3:2-266 [003] ...1 82.774076: rtcpu_vinotify_handle_msg: tstamp:3456577807 tag:CSIMUX_FRAME channel:0x00 frame:10 vi_tstamp:3456577395 data:0x00400060
kworker/3:2-266 [003] ...1 82.826077: rtos_queue_peek_from_isr_failed: tstamp:3456792612 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 82.826080: rtcpu_vinotify_handle_msg: tstamp:3457097512 tag:CSIMUX_FRAME channel:0x00 frame:11 vi_tstamp:3457097101 data:0x00400060
kworker/3:2-266 [003] ...1 82.826081: rtcpu_vinotify_handle_msg: tstamp:3457617219 tag:CSIMUX_FRAME channel:0x00 frame:12 vi_tstamp:3457616808 data:0x00400060
kworker/3:2-266 [003] ...1 82.826081: rtcpu_vinotify_handle_msg: tstamp:3458136922 tag:CSIMUX_FRAME channel:0x00 frame:13 vi_tstamp:3458136514 data:0x00400060
kworker/3:2-266 [003] ...1 82.878123: rtcpu_vinotify_handle_msg: tstamp:3458656632 tag:CSIMUX_FRAME channel:0x00 frame:14 vi_tstamp:3458656221 data:0x00400060
kworker/3:2-266 [003] ...1 82.878126: rtcpu_vinotify_handle_msg: tstamp:3459176338 tag:CSIMUX_FRAME channel:0x00 frame:15 vi_tstamp:3459175928 data:0x00400060
kworker/3:2-266 [003] ...1 82.878127: rtcpu_vinotify_handle_msg: tstamp:3459696044 tag:CSIMUX_FRAME channel:0x00 frame:16 vi_tstamp:3459695634 data:0x00400060
kworker/3:2-266 [003] ...1 82.930078: rtcpu_vinotify_handle_msg: tstamp:3460215749 tag:CSIMUX_FRAME channel:0x00 frame:17 vi_tstamp:3460215341 data:0x00400060
kworker/3:2-266 [003] ...1 82.930080: rtcpu_vinotify_handle_msg: tstamp:3460735455 tag:CSIMUX_FRAME channel:0x00 frame:18 vi_tstamp:3460735047 data:0x00400060
kworker/3:2-266 [003] ...1 82.930081: rtcpu_vinotify_handle_msg: tstamp:3461255161 tag:CSIMUX_FRAME channel:0x00 frame:19 vi_tstamp:3461254754 data:0x00400060
kworker/3:2-266 [003] ...1 82.982075: rtcpu_vinotify_handle_msg: tstamp:3461774871 tag:CSIMUX_FRAME channel:0x00 frame:20 vi_tstamp:3461774460 data:0x00400060
kworker/3:2-266 [003] ...1 82.982080: rtos_queue_peek_from_isr_failed: tstamp:3461793116 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 82.982081: rtcpu_vinotify_handle_msg: tstamp:3462294578 tag:CSIMUX_FRAME channel:0x00 frame:21 vi_tstamp:3462294167 data:0x00400060
kworker/3:2-266 [003] ...1 82.982081: rtcpu_vinotify_handle_msg: tstamp:3462814285 tag:CSIMUX_FRAME channel:0x00 frame:22 vi_tstamp:3462813874 data:0x00400060
kworker/3:2-266 [003] ...1 83.034084: rtcpu_vinotify_handle_msg: tstamp:3463333991 tag:CSIMUX_FRAME channel:0x00 frame:23 vi_tstamp:3463333580 data:0x00400060
kworker/3:2-266 [003] ...1 83.034087: rtcpu_vinotify_handle_msg: tstamp:3463853712 tag:CSIMUX_FRAME channel:0x00 frame:24 vi_tstamp:3463853287 data:0x00400060
kworker/3:2-266 [003] ...1 83.034087: rtcpu_vinotify_handle_msg: tstamp:3464373406 tag:CSIMUX_FRAME channel:0x00 frame:25 vi_tstamp:3464372993 data:0x00400060
kworker/3:2-266 [003] ...1 83.086067: rtcpu_vinotify_handle_msg: tstamp:3464893116 tag:CSIMUX_FRAME channel:0x00 frame:26 vi_tstamp:3464892700 data:0x00400060
kworker/3:2-266 [003] ...1 83.086070: rtcpu_vinotify_handle_msg: tstamp:3465412817 tag:CSIMUX_FRAME channel:0x00 frame:27 vi_tstamp:3465412407 data:0x00400060
kworker/3:2-266 [003] ...1 83.086071: rtcpu_vinotify_handle_msg: tstamp:3465932522 tag:CSIMUX_FRAME channel:0x00 frame:28 vi_tstamp:3465932113 data:0x00400060
kworker/3:2-266 [003] ...1 83.138072: rtcpu_vinotify_handle_msg: tstamp:3466452227 tag:CSIMUX_FRAME channel:0x00 frame:29 vi_tstamp:3466451820 data:0x00400060
kworker/3:2-266 [003] ...1 83.138076: rtos_queue_peek_from_isr_failed: tstamp:3466793625 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.138077: rtcpu_vinotify_handle_msg: tstamp:3466971937 tag:CSIMUX_FRAME channel:0x00 frame:30 vi_tstamp:3466971526 data:0x00400060
kworker/3:2-266 [003] ...1 83.138077: rtcpu_vinotify_handle_msg: tstamp:3467491641 tag:CSIMUX_FRAME channel:0x00 frame:31 vi_tstamp:3467491233 data:0x00400060
kworker/3:2-266 [003] ...1 83.138078: rtcpu_vinotify_handle_msg: tstamp:3468011348 tag:CSIMUX_FRAME channel:0x00 frame:32 vi_tstamp:3468010940 data:0x00400060
kworker/3:2-266 [003] ...1 83.190111: rtcpu_vinotify_handle_msg: tstamp:3468531053 tag:CSIMUX_FRAME channel:0x00 frame:33 vi_tstamp:3468530646 data:0x00400060
kworker/3:2-266 [003] ...1 83.190114: rtcpu_vinotify_handle_msg: tstamp:3469050760 tag:CSIMUX_FRAME channel:0x00 frame:34 vi_tstamp:3469050353 data:0x00400060
kworker/3:2-266 [003] ...1 83.190114: rtcpu_vinotify_handle_msg: tstamp:3469570471 tag:CSIMUX_FRAME channel:0x00 frame:35 vi_tstamp:3469570059 data:0x00400060
kworker/3:2-266 [003] ...1 83.242131: rtcpu_vinotify_handle_msg: tstamp:3470090174 tag:CSIMUX_FRAME channel:0x00 frame:36 vi_tstamp:3470089766 data:0x00400060
kworker/3:2-266 [003] ...1 83.242134: rtcpu_vinotify_handle_msg: tstamp:3470609881 tag:CSIMUX_FRAME channel:0x00 frame:37 vi_tstamp:3470609472 data:0x00400060
kworker/3:2-266 [003] ...1 83.242135: rtcpu_vinotify_handle_msg: tstamp:3471129592 tag:CSIMUX_FRAME channel:0x00 frame:38 vi_tstamp:3471129179 data:0x00400060
kworker/3:2-266 [003] ...1 83.294110: rtcpu_vinotify_handle_msg: tstamp:3471649294 tag:CSIMUX_FRAME channel:0x00 frame:39 vi_tstamp:3471648886 data:0x00400060
kworker/3:2-266 [003] ...1 83.294114: rtos_queue_peek_from_isr_failed: tstamp:3471794133 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.294114: rtcpu_vinotify_handle_msg: tstamp:3472169001 tag:CSIMUX_FRAME channel:0x00 frame:40 vi_tstamp:3472168592 data:0x00400060
kworker/3:2-266 [003] ...1 83.294115: rtcpu_vinotify_handle_msg: tstamp:3472688706 tag:CSIMUX_FRAME channel:0x00 frame:41 vi_tstamp:3472688299 data:0x00400060
kworker/3:2-266 [003] ...1 83.346079: rtcpu_vinotify_handle_msg: tstamp:3473208414 tag:CSIMUX_FRAME channel:0x00 frame:42 vi_tstamp:3473208005 data:0x00400060
kworker/3:2-266 [003] ...1 83.346082: rtcpu_vinotify_handle_msg: tstamp:3473728120 tag:CSIMUX_FRAME channel:0x00 frame:43 vi_tstamp:3473727712 data:0x00400060
kworker/3:2-266 [003] ...1 83.346083: rtcpu_vinotify_handle_msg: tstamp:3474247826 tag:CSIMUX_FRAME channel:0x00 frame:44 vi_tstamp:3474247418 data:0x00400060
kworker/3:2-266 [003] ...1 83.398109: rtcpu_vinotify_handle_msg: tstamp:3474767537 tag:CSIMUX_FRAME channel:0x00 frame:45 vi_tstamp:3474767125 data:0x00400060
kworker/3:2-266 [003] ...1 83.398111: rtcpu_vinotify_handle_msg: tstamp:3475287239 tag:CSIMUX_FRAME channel:0x00 frame:46 vi_tstamp:3475286832 data:0x00400060
kworker/3:2-266 [003] ...1 83.398112: rtcpu_vinotify_handle_msg: tstamp:3475806946 tag:CSIMUX_FRAME channel:0x00 frame:47 vi_tstamp:3475806538 data:0x00400060
kworker/3:2-266 [003] ...1 83.450110: rtcpu_vinotify_handle_msg: tstamp:3476326652 tag:CSIMUX_FRAME channel:0x00 frame:48 vi_tstamp:3476326245 data:0x00400060
kworker/3:2-266 [003] ...1 83.450114: rtos_queue_peek_from_isr_failed: tstamp:3476794641 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.450115: rtcpu_vinotify_handle_msg: tstamp:3476846358 tag:CSIMUX_FRAME channel:0x00 frame:49 vi_tstamp:3476845951 data:0x00400060
kworker/3:2-266 [003] ...1 83.450115: rtcpu_vinotify_handle_msg: tstamp:3477366066 tag:CSIMUX_FRAME channel:0x00 frame:50 vi_tstamp:3477365658 data:0x00400060
kworker/3:2-266 [003] ...1 83.502085: rtcpu_vinotify_handle_msg: tstamp:3477885772 tag:CSIMUX_FRAME channel:0x00 frame:51 vi_tstamp:3477885365 data:0x00400060
kworker/3:2-266 [003] ...1 83.502088: rtcpu_vinotify_handle_msg: tstamp:3478405479 tag:CSIMUX_FRAME channel:0x00 frame:52 vi_tstamp:3478405071 data:0x00400060
kworker/3:2-266 [003] ...1 83.502088: rtcpu_vinotify_handle_msg: tstamp:3478925185 tag:CSIMUX_FRAME channel:0x00 frame:53 vi_tstamp:3478924778 data:0x00400060
kworker/3:2-266 [003] ...1 83.554076: rtcpu_vinotify_handle_msg: tstamp:3479444891 tag:CSIMUX_FRAME channel:0x00 frame:54 vi_tstamp:3479444484 data:0x00400060
kworker/3:2-266 [003] ...1 83.554079: rtcpu_vinotify_handle_msg: tstamp:3479964598 tag:CSIMUX_FRAME channel:0x00 frame:55 vi_tstamp:3479964191 data:0x00400060
kworker/3:2-266 [003] ...1 83.554080: rtcpu_vinotify_handle_msg: tstamp:3480484306 tag:CSIMUX_FRAME channel:0x00 frame:56 vi_tstamp:3480483898 data:0x00400060
kworker/3:2-266 [003] ...1 83.554080: rtcpu_vinotify_handle_msg: tstamp:3481004015 tag:CSIMUX_FRAME channel:0x00 frame:57 vi_tstamp:3481003604 data:0x00400060
kworker/3:2-266 [003] ...1 83.606063: rtcpu_vinotify_handle_msg: tstamp:3481523719 tag:CSIMUX_FRAME channel:0x00 frame:58 vi_tstamp:3481523311 data:0x00400060
kworker/3:2-266 [003] ...1 83.606067: rtos_queue_peek_from_isr_failed: tstamp:3481795146 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.606068: rtcpu_vinotify_handle_msg: tstamp:3482043428 tag:CSIMUX_FRAME channel:0x00 frame:59 vi_tstamp:3482043017 data:0x00400060
kworker/3:2-266 [003] ...1 83.606069: rtcpu_vinotify_handle_msg: tstamp:3482563133 tag:CSIMUX_FRAME channel:0x00 frame:60 vi_tstamp:3482562724 data:0x00400060
kworker/3:2-266 [003] ...1 83.658058: rtcpu_vinotify_handle_msg: tstamp:3483082840 tag:CSIMUX_FRAME channel:0x00 frame:61 vi_tstamp:3483082430 data:0x00400060
kworker/3:2-266 [003] ...1 83.658061: rtcpu_vinotify_handle_msg: tstamp:3483602546 tag:CSIMUX_FRAME channel:0x00 frame:62 vi_tstamp:3483602137 data:0x00400060
kworker/3:2-266 [003] ...1 83.658061: rtcpu_vinotify_handle_msg: tstamp:3484122251 tag:CSIMUX_FRAME channel:0x00 frame:63 vi_tstamp:3484121844 data:0x00400060
kworker/3:2-266 [003] ...1 83.710062: rtcpu_vinotify_handle_msg: tstamp:3484641958 tag:CSIMUX_FRAME channel:0x00 frame:64 vi_tstamp:3484641550 data:0x00400060
kworker/3:2-266 [003] ...1 83.710065: rtcpu_vinotify_handle_msg: tstamp:3485161664 tag:CSIMUX_FRAME channel:0x00 frame:65 vi_tstamp:3485161257 data:0x00400060
kworker/3:2-266 [003] ...1 83.710066: rtcpu_vinotify_handle_msg: tstamp:3485681372 tag:CSIMUX_FRAME channel:0x00 frame:66 vi_tstamp:3485680964 data:0x00400060
kworker/3:2-266 [003] ...1 83.762063: rtcpu_vinotify_handle_msg: tstamp:3486201078 tag:CSIMUX_FRAME channel:0x00 frame:67 vi_tstamp:3486200670 data:0x00400060
kworker/3:2-266 [003] ...1 83.762065: rtcpu_vinotify_handle_msg: tstamp:3486720785 tag:CSIMUX_FRAME channel:0x00 frame:68 vi_tstamp:3486720377 data:0x00400060
kworker/3:2-266 [003] ...1 83.762068: rtos_queue_peek_from_isr_failed: tstamp:3486795655 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.762068: rtcpu_vinotify_handle_msg: tstamp:3487240492 tag:CSIMUX_FRAME channel:0x00 frame:69 vi_tstamp:3487240083 data:0x00400060
kworker/3:2-266 [003] ...1 83.814057: rtcpu_vinotify_handle_msg: tstamp:3487760199 tag:CSIMUX_FRAME channel:0x00 frame:70 vi_tstamp:3487759790 data:0x00400060
kworker/3:2-266 [003] ...1 83.814059: rtcpu_vinotify_handle_msg: tstamp:3488279904 tag:CSIMUX_FRAME channel:0x00 frame:71 vi_tstamp:3488279497 data:0x00400060
kworker/3:2-266 [003] ...1 83.814060: rtcpu_vinotify_handle_msg: tstamp:3488799612 tag:CSIMUX_FRAME channel:0x00 frame:72 vi_tstamp:3488799203 data:0x00400060
kworker/3:2-266 [003] ...1 83.866082: rtcpu_vinotify_handle_msg: tstamp:3489319319 tag:CSIMUX_FRAME channel:0x00 frame:73 vi_tstamp:3489318910 data:0x00400060
kworker/3:2-266 [003] ...1 83.866086: rtcpu_vinotify_handle_msg: tstamp:3489839025 tag:CSIMUX_FRAME channel:0x00 frame:74 vi_tstamp:3489838616 data:0x00400060
kworker/3:2-266 [003] ...1 83.866086: rtcpu_vinotify_handle_msg: tstamp:3490358732 tag:CSIMUX_FRAME channel:0x00 frame:75 vi_tstamp:3490358323 data:0x00400060
kworker/3:2-266 [003] ...1 83.918088: rtcpu_vinotify_handle_msg: tstamp:3490878439 tag:CSIMUX_FRAME channel:0x00 frame:76 vi_tstamp:3490878029 data:0x00400060
kworker/3:2-266 [003] ...1 83.918091: rtcpu_vinotify_handle_msg: tstamp:3491398144 tag:CSIMUX_FRAME channel:0x00 frame:77 vi_tstamp:3491397736 data:0x00400060
kworker/3:2-266 [003] ...1 83.918094: rtos_queue_peek_from_isr_failed: tstamp:3491796159 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 83.918094: rtcpu_vinotify_handle_msg: tstamp:3491917852 tag:CSIMUX_FRAME channel:0x00 frame:78 vi_tstamp:3491917443 data:0x00400060
kworker/3:2-266 [003] ...1 83.918095: rtcpu_vinotify_handle_msg: tstamp:3492437558 tag:CSIMUX_FRAME channel:0x00 frame:79 vi_tstamp:3492437149 data:0x00400060
kworker/3:2-266 [003] ...1 83.970095: rtcpu_vinotify_handle_msg: tstamp:3492957261 tag:CSIMUX_FRAME channel:0x00 frame:80 vi_tstamp:3492956856 data:0x00400060
kworker/3:2-266 [003] ...1 83.970100: rtcpu_vinotify_handle_msg: tstamp:3493476971 tag:CSIMUX_FRAME channel:0x00 frame:81 vi_tstamp:3493476562 data:0x00400060
kworker/3:2-266 [003] ...1 83.970101: rtcpu_vinotify_handle_msg: tstamp:3493996678 tag:CSIMUX_FRAME channel:0x00 frame:82 vi_tstamp:3493996269 data:0x00400060
kworker/3:2-266 [003] ...1 84.022091: rtcpu_vinotify_handle_msg: tstamp:3494516383 tag:CSIMUX_FRAME channel:0x00 frame:83 vi_tstamp:3494515976 data:0x00400060
kworker/3:2-266 [003] ...1 84.022096: rtcpu_vinotify_handle_msg: tstamp:3495036113 tag:CSIMUX_FRAME channel:0x00 frame:84 vi_tstamp:3495035682 data:0x00400060
kworker/3:2-266 [003] ...1 84.022098: rtcpu_vinotify_handle_msg: tstamp:3495555814 tag:CSIMUX_FRAME channel:0x00 frame:85 vi_tstamp:3495555389 data:0x00400060
kworker/3:2-266 [003] ...1 84.074060: rtcpu_vinotify_handle_msg: tstamp:3496075521 tag:CSIMUX_FRAME channel:0x00 frame:86 vi_tstamp:3496075095 data:0x00400060
kworker/3:2-266 [003] ...1 84.074063: rtcpu_vinotify_handle_msg: tstamp:3496595227 tag:CSIMUX_FRAME channel:0x00 frame:87 vi_tstamp:3496594802 data:0x00400060
kworker/3:2-266 [003] ...1 84.074065: rtos_queue_peek_from_isr_failed: tstamp:3496796667 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.074066: rtcpu_vinotify_handle_msg: tstamp:3497114914 tag:CSIMUX_FRAME channel:0x00 frame:88 vi_tstamp:3497114509 data:0x00400060
kworker/3:2-266 [003] ...1 84.126062: rtcpu_vinotify_handle_msg: tstamp:3497634624 tag:CSIMUX_FRAME channel:0x00 frame:89 vi_tstamp:3497634215 data:0x00400060
kworker/3:2-266 [003] ...1 84.126065: rtcpu_vinotify_handle_msg: tstamp:3498154329 tag:CSIMUX_FRAME channel:0x00 frame:90 vi_tstamp:3498153922 data:0x00400060
kworker/3:2-266 [003] ...1 84.126066: rtcpu_vinotify_handle_msg: tstamp:3498674034 tag:CSIMUX_FRAME channel:0x00 frame:91 vi_tstamp:3498673628 data:0x00400060
kworker/3:2-266 [003] ...1 84.178054: rtcpu_vinotify_handle_msg: tstamp:3499193743 tag:CSIMUX_FRAME channel:0x00 frame:92 vi_tstamp:3499193335 data:0x00400060
kworker/3:2-266 [003] ...1 84.178056: rtcpu_vinotify_handle_msg: tstamp:3499713449 tag:CSIMUX_FRAME channel:0x00 frame:93 vi_tstamp:3499713042 data:0x00400060
kworker/3:2-266 [003] ...1 84.178057: rtcpu_vinotify_handle_msg: tstamp:3500233156 tag:CSIMUX_FRAME channel:0x00 frame:94 vi_tstamp:3500232748 data:0x00400060
kworker/3:2-266 [003] ...1 84.230048: rtcpu_vinotify_handle_msg: tstamp:3500752863 tag:CSIMUX_FRAME channel:0x00 frame:95 vi_tstamp:3500752455 data:0x00400060
kworker/3:2-266 [003] ...1 84.230051: rtcpu_vinotify_handle_msg: tstamp:3501272566 tag:CSIMUX_FRAME channel:0x00 frame:96 vi_tstamp:3501272161 data:0x00400060
kworker/3:2-266 [003] ...1 84.230052: rtcpu_vinotify_handle_msg: tstamp:3501792273 tag:CSIMUX_FRAME channel:0x00 frame:97 vi_tstamp:3501791868 data:0x00400060
kworker/3:2-266 [003] ...1 84.230054: rtos_queue_peek_from_isr_failed: tstamp:3501797179 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.282056: rtcpu_vinotify_handle_msg: tstamp:3502311983 tag:CSIMUX_FRAME channel:0x00 frame:98 vi_tstamp:3502311574 data:0x00400060
kworker/3:2-266 [003] ...1 84.282058: rtcpu_vinotify_handle_msg: tstamp:3502831689 tag:CSIMUX_FRAME channel:0x00 frame:99 vi_tstamp:3502831281 data:0x00400060
kworker/3:2-266 [003] ...1 84.282059: rtcpu_vinotify_handle_msg: tstamp:3503351396 tag:CSIMUX_FRAME channel:0x00 frame:100 vi_tstamp:3503350988 data:0x00400060
kworker/3:2-266 [003] ...1 84.334063: rtcpu_vinotify_handle_msg: tstamp:3503871103 tag:CSIMUX_FRAME channel:0x00 frame:101 vi_tstamp:3503870694 data:0x00400060
kworker/3:2-266 [003] ...1 84.334066: rtcpu_vinotify_handle_msg: tstamp:3504390809 tag:CSIMUX_FRAME channel:0x00 frame:102 vi_tstamp:3504390401 data:0x00400060
kworker/3:2-266 [003] ...1 84.334067: rtcpu_vinotify_handle_msg: tstamp:3504910517 tag:CSIMUX_FRAME channel:0x00 frame:103 vi_tstamp:3504910107 data:0x00400060
kworker/3:2-266 [003] ...1 84.334068: rtcpu_vinotify_handle_msg: tstamp:3505430223 tag:CSIMUX_FRAME channel:0x00 frame:104 vi_tstamp:3505429814 data:0x00400060
kworker/3:2-266 [003] ...1 84.386058: rtcpu_vinotify_handle_msg: tstamp:3505949930 tag:CSIMUX_FRAME channel:0x00 frame:105 vi_tstamp:3505949520 data:0x00400060
kworker/3:2-266 [003] ...1 84.386060: rtcpu_vinotify_handle_msg: tstamp:3506469638 tag:CSIMUX_FRAME channel:0x00 frame:106 vi_tstamp:3506469227 data:0x00400060
kworker/3:2-266 [003] ...1 84.386062: rtos_queue_peek_from_isr_failed: tstamp:3506797681 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.386063: rtcpu_vinotify_handle_msg: tstamp:3506989344 tag:CSIMUX_FRAME channel:0x00 frame:107 vi_tstamp:3506988934 data:0x00400060
kworker/3:2-266 [003] ...1 84.438057: rtcpu_vinotify_handle_msg: tstamp:3507509050 tag:CSIMUX_FRAME channel:0x00 frame:108 vi_tstamp:3507508640 data:0x00400060
kworker/3:2-266 [003] ...1 84.438060: rtcpu_vinotify_handle_msg: tstamp:3508028757 tag:CSIMUX_FRAME channel:0x00 frame:109 vi_tstamp:3508028347 data:0x00400060
kworker/3:2-266 [003] ...1 84.438061: rtcpu_vinotify_handle_msg: tstamp:3508548463 tag:CSIMUX_FRAME channel:0x00 frame:110 vi_tstamp:3508548054 data:0x00400060
kworker/3:2-266 [003] ...1 84.490139: rtcpu_vinotify_handle_msg: tstamp:3509068169 tag:CSIMUX_FRAME channel:0x00 frame:111 vi_tstamp:3509067760 data:0x00400060
kworker/3:2-266 [003] ...1 84.490143: rtcpu_vinotify_handle_msg: tstamp:3509587897 tag:CSIMUX_FRAME channel:0x00 frame:112 vi_tstamp:3509587467 data:0x00400060
kworker/3:2-266 [003] ...1 84.490145: rtcpu_vinotify_handle_msg: tstamp:3510107604 tag:CSIMUX_FRAME channel:0x00 frame:113 vi_tstamp:3510107173 data:0x00400060
kworker/3:2-266 [003] ...1 84.542136: rtcpu_vinotify_handle_msg: tstamp:3510627333 tag:CSIMUX_FRAME channel:0x00 frame:114 vi_tstamp:3510626880 data:0x00400060
kworker/3:2-266 [003] ...1 84.542140: rtcpu_vinotify_handle_msg: tstamp:3511147040 tag:CSIMUX_FRAME channel:0x00 frame:115 vi_tstamp:3511146586 data:0x00400060
kworker/3:2-266 [003] ...1 84.542143: rtcpu_vinotify_handle_msg: tstamp:3511666747 tag:CSIMUX_FRAME channel:0x00 frame:116 vi_tstamp:3511666293 data:0x00400060
kworker/3:2-266 [003] ...1 84.542150: rtos_queue_peek_from_isr_failed: tstamp:3511798233 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.594118: rtcpu_vinotify_handle_msg: tstamp:3512186518 tag:CSIMUX_FRAME channel:0x00 frame:117 vi_tstamp:3512186000 data:0x00400060
kworker/3:2-266 [003] ...1 84.594123: rtcpu_vinotify_handle_msg: tstamp:3512706225 tag:CSIMUX_FRAME channel:0x00 frame:118 vi_tstamp:3512705706 data:0x00400060
kworker/3:2-266 [003] ...1 84.594126: rtcpu_vinotify_handle_msg: tstamp:3513225932 tag:CSIMUX_FRAME channel:0x00 frame:119 vi_tstamp:3513225413 data:0x00400060
kworker/3:2-266 [003] ...1 84.646107: rtcpu_vinotify_handle_msg: tstamp:3513745637 tag:CSIMUX_FRAME channel:0x00 frame:120 vi_tstamp:3513745119 data:0x00400060
kworker/3:2-266 [003] ...1 84.646112: rtcpu_vinotify_handle_msg: tstamp:3514265345 tag:CSIMUX_FRAME channel:0x00 frame:121 vi_tstamp:3514264826 data:0x00400060
kworker/3:2-266 [003] ...1 84.646115: rtcpu_vinotify_handle_msg: tstamp:3514785052 tag:CSIMUX_FRAME channel:0x00 frame:122 vi_tstamp:3514784533 data:0x00400060
kworker/3:2-266 [003] ...1 84.698113: rtcpu_vinotify_handle_msg: tstamp:3515304758 tag:CSIMUX_FRAME channel:0x00 frame:123 vi_tstamp:3515304239 data:0x00400060
kworker/3:2-266 [003] ...1 84.698119: rtcpu_vinotify_handle_msg: tstamp:3515824464 tag:CSIMUX_FRAME channel:0x00 frame:124 vi_tstamp:3515823946 data:0x00400060
kworker/3:2-266 [003] ...1 84.698122: rtcpu_vinotify_handle_msg: tstamp:3516344196 tag:CSIMUX_FRAME channel:0x00 frame:125 vi_tstamp:3516343652 data:0x00400060
kworker/3:2-266 [003] ...1 84.698128: rtos_queue_peek_from_isr_failed: tstamp:3516798803 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.750109: rtcpu_vinotify_handle_msg: tstamp:3516863878 tag:CSIMUX_FRAME channel:0x00 frame:126 vi_tstamp:3516863359 data:0x00400060
kworker/3:2-266 [003] ...1 84.750113: rtcpu_vinotify_handle_msg: tstamp:3517383585 tag:CSIMUX_FRAME channel:0x00 frame:127 vi_tstamp:3517383065 data:0x00400060
kworker/3:2-266 [003] ...1 84.750116: rtcpu_vinotify_handle_msg: tstamp:3517903289 tag:CSIMUX_FRAME channel:0x00 frame:128 vi_tstamp:3517902772 data:0x00400060
kworker/3:2-266 [003] ...1 84.750120: rtcpu_vinotify_handle_msg: tstamp:3518422996 tag:CSIMUX_FRAME channel:0x00 frame:129 vi_tstamp:3518422479 data:0x00400060
kworker/3:2-266 [003] ...1 84.802102: rtcpu_vinotify_handle_msg: tstamp:3518942704 tag:CSIMUX_FRAME channel:0x00 frame:130 vi_tstamp:3518942185 data:0x00400060
kworker/3:2-266 [003] ...1 84.802108: rtcpu_vinotify_handle_msg: tstamp:3519462407 tag:CSIMUX_FRAME channel:0x00 frame:131 vi_tstamp:3519461892 data:0x00400060
kworker/3:2-266 [003] ...1 84.802111: rtcpu_vinotify_handle_msg: tstamp:3519982124 tag:CSIMUX_FRAME channel:0x00 frame:132 vi_tstamp:3519981598 data:0x00400060
kworker/3:2-266 [003] ...1 84.854146: rtcpu_vinotify_handle_msg: tstamp:3520501821 tag:CSIMUX_FRAME channel:0x00 frame:133 vi_tstamp:3520501305 data:0x00400060
kworker/3:2-266 [003] ...1 84.854158: rtcpu_vinotify_handle_msg: tstamp:3521021529 tag:CSIMUX_FRAME channel:0x00 frame:134 vi_tstamp:3521021012 data:0x00400060
kworker/3:2-266 [003] ...1 84.854162: rtcpu_vinotify_handle_msg: tstamp:3521541237 tag:CSIMUX_FRAME channel:0x00 frame:135 vi_tstamp:3521540718 data:0x00400060
kworker/3:2-266 [003] ...1 84.906178: rtos_queue_peek_from_isr_failed: tstamp:3521799311 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 84.906182: rtcpu_vinotify_handle_msg: tstamp:3522060944 tag:CSIMUX_FRAME channel:0x00 frame:136 vi_tstamp:3522060425 data:0x00400060
kworker/3:2-266 [003] ...1 84.906186: rtcpu_vinotify_handle_msg: tstamp:3522580646 tag:CSIMUX_FRAME channel:0x00 frame:137 vi_tstamp:3522580131 data:0x00400060
kworker/3:2-266 [003] ...1 84.906189: rtcpu_vinotify_handle_msg: tstamp:3523100356 tag:CSIMUX_FRAME channel:0x00 frame:138 vi_tstamp:3523099838 data:0x00400060
kworker/3:2-266 [003] ...1 84.958172: rtcpu_vinotify_handle_msg: tstamp:3523620060 tag:CSIMUX_FRAME channel:0x00 frame:139 vi_tstamp:3523619544 data:0x00400060
kworker/3:2-266 [003] ...1 84.958177: rtcpu_vinotify_handle_msg: tstamp:3524139769 tag:CSIMUX_FRAME channel:0x00 frame:140 vi_tstamp:3524139251 data:0x00400060
kworker/3:2-266 [003] ...1 84.958180: rtcpu_vinotify_handle_msg: tstamp:3524659476 tag:CSIMUX_FRAME channel:0x00 frame:141 vi_tstamp:3524658958 data:0x00400060
kworker/3:2-266 [003] ...1 85.010114: rtcpu_vinotify_handle_msg: tstamp:3525179182 tag:CSIMUX_FRAME channel:0x00 frame:142 vi_tstamp:3525178664 data:0x00400060
kworker/3:2-266 [003] ...1 85.010119: rtcpu_vinotify_handle_msg: tstamp:3525698888 tag:CSIMUX_FRAME channel:0x00 frame:143 vi_tstamp:3525698371 data:0x00400060
kworker/3:2-266 [003] ...1 85.010122: rtcpu_vinotify_handle_msg: tstamp:3526218600 tag:CSIMUX_FRAME channel:0x00 frame:144 vi_tstamp:3526218077 data:0x00400060
kworker/3:2-266 [003] ...1 85.062141: rtcpu_vinotify_handle_msg: tstamp:3526738303 tag:CSIMUX_FRAME channel:0x00 frame:145 vi_tstamp:3526737784 data:0x00400060
kworker/3:2-266 [003] ...1 85.062149: rtos_queue_peek_from_isr_failed: tstamp:3526799816 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 85.062154: rtcpu_vinotify_handle_msg: tstamp:3527258010 tag:CSIMUX_FRAME channel:0x00 frame:146 vi_tstamp:3527257491 data:0x00400060
kworker/3:2-266 [003] ...1 85.062157: rtcpu_vinotify_handle_msg: tstamp:3527777715 tag:CSIMUX_FRAME channel:0x00 frame:147 vi_tstamp:3527777197 data:0x00400060
kworker/3:2-266 [003] ...1 85.114171: rtcpu_vinotify_handle_msg: tstamp:3528297423 tag:CSIMUX_FRAME channel:0x00 frame:148 vi_tstamp:3528296904 data:0x00400060
kworker/3:2-266 [003] ...1 85.114176: rtcpu_vinotify_handle_msg: tstamp:3528817130 tag:CSIMUX_FRAME channel:0x00 frame:149 vi_tstamp:3528816610 data:0x00400060
kworker/3:2-266 [003] ...1 85.114179: rtcpu_vinotify_handle_msg: tstamp:3529336837 tag:CSIMUX_FRAME channel:0x00 frame:150 vi_tstamp:3529336317 data:0x00400060
kworker/3:2-266 [003] ...1 85.166130: rtcpu_vinotify_handle_msg: tstamp:3529856552 tag:CSIMUX_FRAME channel:0x00 frame:151 vi_tstamp:3529856023 data:0x00400060
kworker/3:2-266 [003] ...1 85.166134: rtcpu_vinotify_handle_msg: tstamp:3530376250 tag:CSIMUX_FRAME channel:0x00 frame:152 vi_tstamp:3530375730 data:0x00400060
kworker/3:2-266 [003] ...1 85.166137: rtcpu_vinotify_handle_msg: tstamp:3530895957 tag:CSIMUX_FRAME channel:0x00 frame:153 vi_tstamp:3530895437 data:0x00400060
kworker/3:2-266 [003] ...1 85.166141: rtcpu_vinotify_handle_msg: tstamp:3531415662 tag:CSIMUX_FRAME channel:0x00 frame:154 vi_tstamp:3531415143 data:0x00400060
kworker/3:2-266 [003] ...1 85.218118: rtos_queue_peek_from_isr_failed: tstamp:3531800324 queue:0x0b4a3c58
kworker/3:2-266 [003] ...1 85.218123: rtcpu_vinotify_handle_msg: tstamp:3531935370 tag:CSIMUX_FRAME channel:0x00 frame:155 vi_tstamp:3531934850 data:0x00400060
kworker/3:2-266 [003] ...1 85.218126: rtcpu_vinotify_handle_msg: tstamp:3532455090 tag:CSIMUX_FRAME channel:0x00 frame:156 vi_tstamp:3532454557 data:0x00400060
kworker/3:2-266 [003] ...1 85.218129: rtcpu_vinotify_handle_msg: tstamp:3532974781 tag:CSIMUX_FRAME channel:0x00 frame:157 vi_tstamp:3532974263 data:0x00400060
kworker/3:2-266 [003] ...1 85.270114: rtcpu_vinotify_handle_msg: tstamp:3533494489 tag:CSIMUX_FRAME channel:0x00 frame:158 vi_tstamp:3533493970 data:0x00400060
kworker/3:2-266 [003] ...1 85.270118: rtcpu_vinotify_handle_msg: tstamp:3534014194 tag:CSIMUX_FRAME channel:0x00 frame:159 vi_tstamp:3534013676 data:0x00400060
kworker/3:2-266 [003] ...1 85.270122: rtcpu_vinotify_handle_msg: tstamp:3534533901 tag:CSIMUX_FRAME channel:0x00 frame:160 vi_tstamp:3534533383 data:0x00400060
kworker/3:2-266 [003] ...1 85.322110: rtcpu_vinotify_handle_msg: tstamp:3535053605 tag:CSIMUX_FRAME channel:0x00 frame:161 vi_tstamp:3535053089 data:0x00400060
kworker/3:2-266 [003] ...1 85.322115: rtcpu_vinotify_handle_msg: tstamp:3535573312 tag:CSIMUX_FRAME channel:0x00 frame:162 vi_tstamp:3535572796 data:0x00400060
kworker/3:2-266 [003] ...1 85.322118: rtcpu_vinotify_handle_msg: tstamp:3536093021 tag:CSIMUX_FRAME channel:0x00 frame:163 vi_tstamp:3536092502 data:0x00400060
kworker/3:2-266 [003] ...1 85.374229: rtcpu_vinotify_handle_msg: tstamp:3536612729 tag:CSIMUX_FRAME channel:0x00 frame:164 vi_tstamp:3536612209 data:0x00400060
patch.txt (74.7 KB)
data.ar0144b-000000.bin.zip (640 KB)
