Could you release ar0820at’s configuration file if it exists?
in samples/nvmedia/ipp_raw under drive-t186ref-linux, There is only a configuration file for ar0231.
or do I have to purchase the ar0820 camera module from the specified manufacturer?
Because I have an AR0820 camera purchased through D3 Engineering.
Of course, I know that revision or fuse ID will quite different so I can’t use it easily.
However, I have ar0820’s driver code and datasheet, the configuration except the hidden register can be checked and modified for working.
I wish to better understand your needs.
Who is the vendor you are referring to? Did you procure the modules from Entron?
what is the lens config you are using?
What do you mean by configuration file? ddpx-a.conf?
what do you mean in camera module? the driver module for the camera?
Have you tested that the sensor is working?
Entron is enabled with the drivers and they can support you for a configuration file and a driver as you need.
Same applies to Sony camera, please approach Sony for support - configuration file and driver.
if Jabil is not able to deliver a driver than I would suggest getting support from Entron, I am not sure if you have to buy the module through Entron, please direct this question to Entron.
