hi,
i am working on jetson Xavier NX box,
i updated to jetpack 5.0.1 and deepstream6.1 right now.
before i setup ARCH= -gencode arch=compute 72 for NX to train some models.
but i cmake another file yesterday it detected arch-gencode 75!
so i am confuse right now, should i setup 72 or 75 for jetson xavier nx when i trainning?
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Xavier"
CUDA Driver Version / Runtime Version 10.2 / 10.2
CUDA Capability Major/Minor version number: 7.2
Total amount of global memory: 7773 MBytes (8151035904 bytes)
( 6) Multiprocessors, ( 64) CUDA Cores/MP: 384 CUDA Cores
GPU Max Clock rate: 1109 MHz (1.11 GHz)
Memory Clock rate: 1109 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 524288 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Version = 10.2, NumDevs = 1
Result = PASS
Perhaps the cmake file you ran wasn’t properly configured to detect the Jetson GPUs.
Or you can check the sysfs file that the jetson_clocks script uses to control your fan:
do_fan()
TARGET_PWM="/sys/devices/pwm-fan/target_pwm"
TEMP_CONTROL="/sys/devices/pwm-fan/temp_control"
FAN_SPEED=255
if [ ! -w "${TARGET_PWM}" ]; then
echo "Can't access Fan!"
return
fi
case "${ACTION}" in
show)
echo "Fan: PWM=`cat ${TARGET_PWM}`"
store)
store "${TARGET_PWM}"
store "${TEMP_CONTROL}"
if [ "${FAN_SPEED_OVERRIDE}" -eq "0" ]; then
return
fi
if [ -w "${TEMP_CONTROL}" ]; then
echo "0" > "${TEMP_CONTROL}"
fi
echo "${FAN_SPEED}" > "${TARGET_PWM}"
esac
if [ "${SOCFAMILY}" = "tegra194" -a "${machine}" = "Clara-AGX" ]; then
FPGA_TARGET_PWM="/sys/devices/pwm-fan-fpga/target_pwm"
FPGA_TEMP_CONTROL="/sys/devices/pwm-fan-fpga/temp_control"
if [ ! -w "${FPGA_TARGET_PWM}" ]; then
echo "Can't access Fan (FPGA)!"
return
fi
case "${ACTION}" in
show)
echo "Fan (FPGA): PWM=`cat ${FPGA_TARGET_PWM}`"
store)
store "${FPGA_TARGET_PWM}"
store "${FPGA_TEMP_CONTROL}"
return
fi
if [ -w "${FPGA_TEMP_CONTROL}" ]; then
echo "0" > "${FPGA_TEMP_CONTROL}"
fi
echo "${FAN_SPEED}" > "${FPGA_TARGET_PWM}"
esac
fi
