I’m able to boot to GDM, but when I try to launch gnome-shell after entering my password and start the regular GNOME Xorg Session the Monitor tries to modeset and nothing happens. I was able to see in dmesg that the kernel paniced with some nvidia related calls.
The bugreport was generated before this issue happened (still on GDM). I tried to do it after the kernel panics, but the bug report script hangs. I tried the recommeded parameters but nothing happens for minutes until suddenly the fans are blasting at 100% so I turned the PC of to avoid damaging the card. Check the dmesg dump I attached separately which is after the panic.
Unfortunately I don’t know which last driver version was working fine as I haven’t used this PC for some time.
Your wifi is missing firmware (unrelated).
The kernel trace is really not giving much information about where the problem might be. Tried downgrading to the 470 legacy driver?
It’s a desktop PC using Ethernet so I never bothered with Wifi. Using 470 driver series works. However, for me this is just a work around.
I was also able to get to the desktop with the current driver 2-3 times, but the chance of getting through the modesetting without crashing the driver is something like 1 in 20.
