Full Title: “[Arch Linux] glxgears crashes with ‘BadValue’ and ‘X_GLXCreateNewContext’ using nvidia version 361.28-5 with a NVS 5400M card.”
Here is what happens when I run glxinfo:
$ glxinfo
name of display: :0
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 154 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 45
Current serial number in output stream: 46
I’m running Arch Linux, up-to-date, on a Thinkpad T530 with a NVS 5400M card:
$ lspci | grep -i nvidia
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF108M [NVS 5400M] [10de:0def] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device [17aa:21f6]
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at f2000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at 5000
[virtual] Expansion ROM at f3080000 [disabled]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia
I’m using the latest drivers (361.28-4):
$ sudo pacman -Ss nvidia | grep installed
extra/libvdpau 1.1.1-2 [installed]
extra/nvidia-dkms 361.28-4 [installed]
extra/nvidia-libgl 361.28-5 [installed]
extra/nvidia-settings 361.28-1 [installed]
extra/nvidia-utils 361.28-5 [installed]
extra/opencl-nvidia 361.28-5 [installed]
community/cuda 7.5.18-1 [installed]
multilib/lib32-libvdpau 1.1.1-2 [installed]
multilib/lib32-nvidia-libgl 361.28-4 [installed]
multilib/lib32-nvidia-utils 361.28-4 [installed]
Interesting lines in dmesg:
[ 29.467110] NVRM: Your system is not currently configured to drive a VGA console
[ 29.467114] NVRM: on the primary VGA device. The NVIDIA Linux graphics driver
[ 29.467116] NVRM: requires the use of a text-mode VGA console. Use of other console
[ 29.467118] NVRM: drivers including, but not limited to, vesafb, may result in
[ 29.467119] NVRM: corruption and stability problems, and is not supported.
[ 29.617228] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 361.28 Wed Feb 3 15:15:17 PST 2016
[ 29.617925] nvidia-modeset: Allocated GPU:0 (GPU-1696bcb5-95f6-5158-f98e-fb076c2aa9fd) @ PCI:0000:01:00.0
No errors in Xorg.0.log.
I tried compiling glxinfo from source so that I can debug with gdb. I’ve discovered that the error is called on this line in glxinfo.c when glXCreateNewContext() is called.
nvidia-bug-report.log.gz (71.8 KB)
