Archiconda error on jetson tx2
HI,
I want to run YOLOv8 on jetson tx2 so i will use archiconda.
I tried following [Anaconda for Jetson Nano - #12 by krunal].
But, I got an error “FileNotFoundError(2, “No such file or directory: ‘/home/nvidia/archiconda3/bin/python3.8’”)”
So,
I remove /home/user/archiconda3 directiory.
And then following the procedure again by changing the command like below.
conda install -y python=3.8.13 libiconv && \
However, I got the same error.
How can i install conda(python=3.8) with no error?
Have you installed Python 3.8 first?
$ sudo apt install python3.8
$ python3 --version
Hi
I run the command as you mentioned.
But, the result is “Python 3.6.9”.
nvidia@ubuntu:~$ python3 --version
Python 3.6.9
Is it ok?
I run the command below.
nvidia@ubuntu:~$ python3.8 --version
Python 3.8.0
Then, I tried following Anaconda for Jetson Nano - #12 by krunal again.
But, I got the same error again…
I don’t know what;'s the problem…
After the installation, does the file exist?
