Architecture for running scripts the first time Xavier boots
We currently implement a system where an initial service is copied into the filesystem, this service runs every single script in a folder until it completes, then deletes a file which conditions the service’s execution. This doesn’t seem like the best solution, what is usually implemented for running a bunch of scripts the first time only?
I don’t have an answer. If you want some services to run automatically, then there are already lots of posts shared by other forum users. You can refer to them.
Also, this is not regarding to platform. You can search what ubuntu18.04 supports and it shall work fine on jetson too.
