is there any command from linux bash to know the type of architecture of the nvidia graphic device installed in the system?
i mean number of cores, device memory size, shared memory size in every SM, etc…
the other idea was: given the type of graphic device, look for a datasheet…
but i’ve only seen a brief description on nVidia website.
maybe it’s a stupid question, i’m pretty new with cuda programming…
The CUDA SDK includes a command called deviceQuery that does exactly that and give output like this:
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 2 devices supporting CUDA
Device 0: "GeForce GTX 275"
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 3
Total amount of global memory: 938803200 bytes
Number of multiprocessors: 30
Number of cores: 240
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 16384
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 2147483647 bytes
Texture alignment: 256 bytes
Clock rate: 1.46 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Prohibited (no host thread can use this device)
Device 1: "GeForce GTX 275"
Total amount of global memory: 939327488 bytes
Warp size: 32
Run time limit on kernels: No
Integrated: No
Compute mode: Default (multiple host threads can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 4249427, CUDA Runtime Version = 3.0, NumDevs = 2, Device = GeForce GTX 275, Device = GeForce GTX 275
thanks!!
i think i’ve read this somewhere in the programming guide or in the gettin’ started document,
but of course i forgot when i needed… External Image
