if I download the latest kernel sources from:
L4T r32_Release_v4.3 download link
I get a damaged archive. I repeated the step once or twice, and waited for a new version. I still get the following error:
localhost /usr/src # tar -xvjf public_sources.tbz2
Linux_for_Tegra/
Linux_for_Tegra/source/
Linux_for_Tegra/source/public/
Linux_for_Tegra/source/public/u-boot_src.tbz2
Linux_for_Tegra/source/public/opencv_gst_samples_src.tbz2
Linux_for_Tegra/source/public/kernel_src.tbz2.sha1sum
Linux_for_Tegra/source/public/gst-nvv4l2camera_src.tbz2.sha1sum
Linux_for_Tegra/source/public/nvsample_cudaprocess_src.tbz2
Linux_for_Tegra/source/public/nvgstapps_src.tbz2.sha1sum
Linux_for_Tegra/source/public/opencv_gst_samples_src.tbz2.sha1sum
Linux_for_Tegra/source/public/atf_src.tbz2
Linux_for_Tegra/source/public/libgstnvvideosinks_src.tbz2.sha1sum
Linux_for_Tegra/source/public/trusty_src.tbz2
bzip2: Data integrity error when decompressing.
Input file = (stdin), output file = (stdout)
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover' program to attempt to recover
data from undamaged sections of corrupted files.
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
I repaired the archive as recommended, but I am unsure if any errors persisted.
Best regards
Hi zottelmail,
I can tar file success.
I think there are some corrupt when you download the package, please download again. Thanks!
$ tar xpvf public_sources.tbz2
Linux_for_Tegra/
Linux_for_Tegra/source/public/gst-nvvideo4linux2_src.tbz2.sha1sum
Linux_for_Tegra/source/public/v4l2_libs_src.tbz2
Linux_for_Tegra/source/public/gstjpeg_src.tbz2.sha1sum
Linux_for_Tegra/source/public/gstegl_src.tbz2.sha1sum
Linux_for_Tegra/source/public/FreeRTOSV8.1.2_src.tbz2.sha1sum
Linux_for_Tegra/source/public/u-boot_src.tbz2.sha1sum
Linux_for_Tegra/source/public/public_sources_sha.txt
Linux_for_Tegra/source/public/dtc-1.4.0.tar.bz2.sha1sum
Linux_for_Tegra/source/public/gst-nvarguscamera_src.tbz2.sha1sum
Linux_for_Tegra/source/public/gstomx1_src.tbz2
Linux_for_Tegra/source/public/atf_src.tbz2.sha1sum
Linux_for_Tegra/source/public/nvsample_cudaprocess_src.tbz2.sha1sum
Linux_for_Tegra/source/public/gstomx1_src.tbz2.sha1sum
Linux_for_Tegra/source/public/v4l2_libs_src.tbz2.sha1sum
Linux_for_Tegra/source/public/trusty_src.tbz2.sha1sum
Linux_for_Tegra/source/public/nv_public_src_build.sh
Thanks for your answer. It seems fixed now. Can you please confirm the sha512.
Hi zottelmail,
Please check:
$ sha512sum public_sources.tbz2
5e6db0c9e739db07b461b041b58b668d20662e2048029f6fa50bb3963f0319715527e9cc3d76e1b97229a3bc3f46ae082a5725d44172550e25e3db1df2bdcbfb public_sources.tbz2
