I was wondering if I can run arduino-cli on TX1?
I used this tutorial How To Program Arduino From The Raspberry Pi Command Line – Siytek that worked exactly the same up until I tried to upload the code to my arduino nano.
the code:
void setup() {
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
This is >Example>Basic>Blink from arduino library, that I tested on my rasberry pi 4 before and worked.
On TX1 I get sync errors when I try uploading the code.
