Are the network switches in the Thor Drive AGX dev kit configurable?
DRIVE OS Version: 7.0.3
Issue Description:
Is there any functionality or documentation for configuring the RTL907xD Realtek switches or the 88Q5152 Marvell switches in the Thor DriveAGX dev kit? I looked through the SDK docs here and couldn’t see anything obvious to configure. There’s a note in this page that says In NVIDIA platforms, network switch configuration occurs via sMCU firmware or through the network switch firmware. These configuration cannot be altered in run time. but no further information to review about updating that configuration seems to be there.
We are interested in settings such as master/slave automotive ethernet settings as well as things like VLAN tagging per port.
A use case would be to connect multiple Thor Drive AGX Dev Kits together to form a small local network to pass typical network traffic between them (e.g. ssh, scp, ROS comms, PTP time sync, etc…). We’re concerned that if everything is set to be a automotive ethernet master by default then we cannot connect two Thor dev kits together directly. We are currently assuming the mgbe0_0 connection that does not go through a switch will be used for connecting to a network storage device and not for connecting to another Thor, hence the interest in the internal switch configuration settings.
Thank you.
Dear @umansky ,
Is it like you want to configure switch ports to master/slave, the configurations can’t be done from DRIVE OS. You might need to check with vendor to update FW as per need.
I think I’ve I think the same issue. I’d like to connect the mgbe0_0 10 Gbps interface of one Drive Thor to a 10 Gbps switch port on another Drive Thor (something like the Condor-2 P9 or P10 10 Gbps port).
The dev kit contains a cable that looks like it makes this physically possible but it doesn’t appear to work and this post makes it sound like it may require some switch configuration changes.
At this point I’d just like to:
Just wondering if it is easier/possible to configure the Master/Slave setting of the mgbe0 interface since it doesn’t involve one of the embedded switches.
I would also be interested in understanding that possibility of configuring mgbe0 as well.
And to build on the question around mgbe0, the Marvell switch connects to an external “10G-T1 Phy” through an XFI interface which I believe means the switch can’t configure the external Phy settings for Master/Slave. So maybe there is a general configuration process for changing the settings on these external phys outside the switches? (We’ve tried various commands with ethtool that haven’t worked so far)
We suggest to open new topic for each issue to avoid fluttering of topics
