Are there any plans to support massflashing in sdk manager?
Thank you.
Thank you.
It does not make sense to let sdkmanager to support massflash…
Massflash is for doing the production. But SDKM will only flash default jetpack binary for the “NV devkit board”.
Take an easy example, you have a custom board, with custom dtb to let it work. What would happen if you flash with sdkm? The result is your dtb may get overwrite and then your board may even not able to boot.
Thus, sdkm shall not support massflash. Only the L4T driver package will have it because you can customize what will be installed in L4T package but not in sdkm.
