bwana
April 22, 2019, 8:58pm
#1
Can i install nvidia docker to pull some prebuilt containers from the nvidia gpu cloud? Can i install nvidia-docker as described here: https://github.com/nvidia/nvidia-docker/wiki/Installation-(version-2.0) ?
Problem is that I cannot figure out which nvidia driver i am using or which version of CUDA.
$nvidia-smi
bash: nvidia-smi: command not found
$nvcc -V
gives nothing
$cat /proc/driver/nvidia/version
cwt137
April 23, 2019, 12:23am
#2
I would say no on using the prebuilt containers. These are for x86_64 images. You can tell by the first item in the “Prerequisites” section. The Nano uses Arm.
bwana
April 23, 2019, 1:34am
#3
there are some containers prebuilt for arm64. Docker hub allows filtering by architecture. And I CAN run THOSE containers - for example
docker run -it openhorizon/aarch64-tx2-nvidia-caffe:jetpack3.3 bash
however even tho this runs on the nano and gives me a shell, the command nvidia-smi or nvcc do not work for me.
nvidia-docker and nvidia-smi doesn’t support Jetson platform.
But you still can use the official docker on Nano:
https://github.com/Technica-Corporation/Tegra-Docker
