Hello, I would like to know if are there more assets available to use in isaac sim besides those available on localhost. If yes, where I can find it? I would like to try more environments
Thank you in advance!!
@2212285 i am just another user, so i defer to the mods/devs for a more official answer. that said, the assets/contents shipped with OV and your local nucleus server is just a base line provided by NVIDIA. there will probably be new assets on the roadmap in the future; but, if you are needing to build custom environments, you can consider sourcing from third party vendor or build the asset yourself using other DCCs.
there are plenty of third party vendors out there that have both paid and free 3D contents offerings. sites like turbosquid or sketchfab are good examples (not to mention assets were prepped as USD). to that point, you could consider searching for asset
inside the extension manager, then enabling the Browser of Asset Stores
extension:
which should give you access to both turbosquid and sketchfab assets to purchase/download (access the panel through Window
> Browser
> Asset Stores (Beta)
just note those assets have high probability of not having proper physics/schema built into them and may require additional work should you find yourself needing to do simulation with those particular assets.
