Are there tools to eGPU or cluster a 5090 to DGX Spark single or cluster?
Have been trying to clock the development of using a 5090 as a tandem workhorse in an orchestrator environment, but there has been sparse chatter about using it via a traditional eGPU arrangement.
The USB4 drivers may not have finely tuned drivers so far, but I’m wondering if more adept minds could chime in on this ideal arrangement.
The DGX Spark doesn’t have USB4 so no eGPU.
RTX Spark apparently has USB4 according to some comments I spotted earlier.
The requirement is not USB4 but rather TB3+ (or just TB? I have never used anything below TB3 for eGPUs). This is also the reason why the DGX Spark can not do eGPUs.
The reason USB4 is important is because Microsoft (to be clear this is not a broad requirement but most manufacturers follow this because this is a relevant policy for Enterprise usecases more so than consumers) pretty much demands TB3+ support with USB4.
You probably don’t see the clustering (even via Mellanox networking) is because the bandwidth classes are way to far apart the benefit of a DGX Spark in such a mismatched cluster is really low (vs the other alternative paths at this spend level).
After the DGX Spark launch last year this was one of the first questions asked on the forum. See eGPU support?
That’s pretty much where my head was at already. The potential for the rtxSpark has me thinking about all the workarounds that crowd could potentially bring to the platform, although that oversells the dgxSpark’s platform.
I suppose the search is still on for a useable automated orchestrator betwixt the two.
I’ve heard of people trying to use nvme → pcie for the graphics card and then moving the storage over usbc.
That’s been the rumour for awhile, but I’ve yet to see anyone implement a working solution, let alone an active repo. An urban-gpu-legend maybe.
The only solution left is a really nicely tuned orchestrator I suppose. A real missing link in the ecosystem of mixed hardware. Bit of a holy grail for me.
Yeah there are working reports of repurposing the NVME slot to connect a GPU on other forums. I’ve seen photos of people’s setups, with USB drives used instead for storage.
Not sure the overall point of this exercise would be other than to demonstrate its feasibility. Maybe use with llama.cpp? In that case just running a DDR5 server with a 5090 would accomplish the same purpose while being a lot cheaper
This is the “right sort of crazy” to dream about.
@ChemistSpark07 I think the point is bigger than proving it can be done. A strange setup like fill the mind with wonder.
Most of us picture an eGPU as a bigger engine bolted onto a smaller one, and from that angle the mismatch looks like a flaw. The M.2 slot on a Spark is a Gen5 x4 link, about 14 GB/s. That’s a narrow door. You’ll never pour memory through it fast enough to make the card feel like part of the Spark.
What if the bolt-on isn’t just more memory? What work could live entirely on the other side of the door?
A big MoE model is less one machine than a society of very different parts. DeepSeek V4.1 Flash, which we run across four Sparks ( GitHub - christopherowen/spark-ds41f: Reproducible Docker/vLLM deployment, tuning, and benchmarks for DeepSeek V4.1 Flash on a switchless three-node DGX Spark fabric. · GitHub ), has a drafter that guesses the next few tokens, Engram tables that work like a 200 GB library of n-grams, a million-token memory of the conversation, and 384 experts who each wake up for only some of the tokens. Each of those has its own relationship with memory. Some parts want to be read constantly and fast. Others want to be huge and patient. The interesting machine matches each part to the memory that suits it.
Picture one RTX PRO 6000 on one Spark:
  • The drafter gets a fast mind of its own. It can start guessing the next tokens while the Sparks are still checking the last ones, and because verification is exact, it can’t change a word the model says.
  • The library moves off the disk. That also answers the NVMe trick’s catch: the SSD you pull out is the one the Engram rows stream from, and one node’s share of those tables fits in 96 GB.
  • A million-token document gets read on the side, so a long prompt stops interrupting everyone else’s conversation.
Now picture a card on each of four Sparks. The roles invert. The weights live in the cards’ GDDR7, at 6.6x the bandwidth of the Spark’s memory. The Sparks become what they’re great at: a big, patient memory for the conversation and the library, and the network that ties it all together. On paper, single-stream decode doubles, and a cluster that looked mismatched starts to look designed.
@VCR you called it a holy grail. I don’t think the grail is an orchestrator that shuffles requests between boxes. I think it’s one engine that knows the character of every memory it owns.
Two things have to hold first. DGX OS has to drive the GB10 and a discrete Blackwell card at the same time, and our SM121 kernels have to give identical bits on SM120. If both hold, the card can join without changing a single token the model produces.
If anyone has a riser working in a Spark’s M.2 slot, please post your lspci -vv link status and nvidia-smi. It’s the sort of crazy I may try if someone comes up with a good way to integrate this into a 10 inch rack beautifully.
This should be possible also I personally have not tried this, yet.
https://forums.developer.nvidia.com/t/dgx-spark-rtx-3090-any-other-gpu-dgx-spark-mini-station-dgx-sprak-e-dgpu/366304?
