I am trying to port camera to 36.3.0.
DTS were significantly reorganized, so I am checking all my settings.
I see that
hardware/nvidia/t23x/nv-public/overlay/tegra234-p3737-camera-modules.dtsi
still defines
tpg_max_iso = <3916800>;
but I do not see anybody reading it. Was it deprecated? Can I remove it from my DTS as well?
tegra_camera_isomgr_register is empty in JP6.x, unless public_sources.tbz2 on nvidia.com is wrong. This is what I did:
curl -L -o public_sources.tbz2 https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v3.0/sources/public_sources.tbz2
md5sum public_sources.tbz2
1daa801c8396b4c6a149e459af75d595 public_sources.tbz2
tar xf public_sources.tbz2
tar xf Linux_for_Tegra/source/kernel_oot_modules_src.tbz2
grep tegra_camera_isomgr_register . -r -A 10
static int tegra_camera_isomgr_register(struct tegra_camera_info *info,
struct device *dev)
return 0;
Yes, I already quoted this file tegra_camera_platform.c in my previous post, but now it has empty implementation of tegra_camera_isomgr_register (at least in the version of public_sources.tbz2 from nvidia.com).
In fact, these settings:
num_csi_lanes, max_lane_speed, min_bits_per_pixel, vi_peak_byte_per_pixel, vi_bw_margin_pct, max_pixel_rate, isp_peak_byte_per_pixel, isp_bw_margin_pct, skip_mux_detect
are not found in any source file anymore,
but they are still included in several .dtsi, including the reference file tegra234-camera-imx185-a00.dtsi and in documentation.
I suggest you double check with developers whether they removed these settings and update the reference .dtsi and documentation.
It is also possible that https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v3.0/sources/public_sources.tbz2 is somehow out of sync with the real kernel used by developers.
Please, clarify.
it was based on total number of active CSI lanes (i.e. num_csi_lanes & max_lane_speed) when all cameras on the camera board are active to calculate VI ISO bandwidth.
those code has deprecated due to bwmgr and isomgr has disabled for Orin series. emc_bwmgr driver is replaced by interconnect (ICC) framework and tegra ICC driver.
you may refer to RTCPU driver, it’s now using devm_of_icc_get(), which is upstream API.
for instance, $public_sources/kernel_src/kernel/nvidia-oot/drivers/platform/tegra/rtcpu/tegra-camera-rtcpu-base.c
ya… it looks those driver did not update accordingly.
let me arrange resources to address them.
