Are USB2-1/2/3 DRD capable or is USB2-0 the only OTG port on Jetson Thor?
I have a question regarding USB DRD (OTG) capability on Jetson Thor.
From the available documentation and forum posts, I can confirm that:
- USB2-0 is used for the recovery/flash port
- USB2-0 supports peripheral mode and role switching
- All examples related to OTG configuration are based on USB2-0
However, I could not find any information about USB2-1, USB2-2, and USB2-3.
Could you please clarify:
1. Is USB2-0 the only DRD (Dual Role Device) capable USB port on Jetson Thor?
2. Are USB2-1, USB2-2, and USB2-3 host-only ports, or can they also operate in device mode with proper hardware and device tree configuration?
3. Is there any TRM or design guide section that lists which USB ports support DRD/OTG functionality?
You can make any USB2 pin as device mode.
However, there is one key limitation. There could be only one device mode in use at same time.
For example, if you configure usb2-0 and usb2-1 as OTG at same time. Then you could use either usb2-0 or 2-1 as a device mode port in the same time.
Thus, basically we only configure one port as OTG and as flash port is fixed on usb2-0, we always choose usb2-0 as the only OTG port.
