Huh In 2GB devkit it’s a Hard some crashes detected when some reboot Needed hard debug things …
[383175.786699] tegradc tegradc.0: pclk out of range!
[383176.840875] tegradc tegradc.0: sor_poll_register 0x15: timeout
[383176.840878] tegradc tegradc.0: dc timeout waiting for OR MODE = SAFE
[383176.908815] tegradc tegradc.0: dc_poll_register 0x41: timeout
[383176.908817] tegradc tegradc.0: dc timeout waiting for DC to stop
[383223.289022] soctherm: OC ALARM 0x00000001
[383449.559634] soctherm: OC ALARM 0x00000001
[383516.078391] watchdog: watchdog0: watchdog did not stop!
[383517.063264] reboot: Restarting system
[0000.159] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.164] Processing in cold boot mode Bootloader 2
[0000.169] A02 Bootrom Patch rev = 1023
[0000.173] Power-up reason: software reset
[0000.176] No Battery Present
[0000.179] pmic max77620 reset reason
[0000.182] pmic max77620 NVERC : 0x0
[0000.186] RamCode = 1
[0000.188] Platform has DDR4 type RAM
[0000.191] max77620 disabling SD1 Remote Sense
[0000.195] Setting DDR voltage to 1125mv
[0000.199] Serial Number of Pmic Max77663: 0x2e4
[0000.207] Entering ramdump check
[0000.210] Get RamDumpCarveOut = 0x0
[0000.213] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.218] Last reboot was clean, booting normally!
[0000.223] Sdram initialization is successful
[0000.227] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.233] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.239] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.245] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.250] Resize the SecureOs Carveout to 0x00100000
[0000.255] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.261] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.267] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.273] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.278] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.284] Platform-DebugCarveout: 0
[0000.288] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.293] Non secure mode, and RB not enabled.
[0000.298] BoardID = 3448, SKU = 0x3
[0000.301] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.305] Nano-SD: checking PT table on QSPI ...
[0000.309] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.315] Read PT from (2:0)
[0000.346] PT crc32 and magic check passed.
[0000.349] Using BFS PT to query partitions
[0000.355] Loading Tboot-CPU binary
[0000.383] Verifying TBC in OdmNonSecureSBK mode
[0000.393] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.400] Bootloader downloaded successfully.
[0000.404] Downloaded Tboot-CPU binary to 0xa0000258
[0000.410] MAX77620_GPIO5 configured
[0000.413] CPU power rail is up
[0000.416] CPU clock enabled
[0000.419] Performing RAM repair
[0000.422] Updating A64 Warmreset Address to 0xa00002e9
[0000.427] BoardID = 3448, SKU = 0x3
[0000.431] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.434] Nano-SD: checking PT table on QSPI ...
[0000.439] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.445] Loading NvTbootBootloaderDTB
[0000.511] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.580] Bootloader DTB Load Address: 0x83000000
[0000.585] BoardID = 3448, SKU = 0x3
[0000.588] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.592] Nano-SD: checking PT table on QSPI ...
[0000.596] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.603] Loading NvTbootKernelDTB
[0000.669] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.738] Kernel DTB Load Address: 0x83100000
[0000.742] BoardID = 3448, SKU = 0x3
[0000.745] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.749] Nano-SD: checking PT table on QSPI ...
[0000.753] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.761] Loading cboot binary
[0000.877] Verifying EBT in OdmNonSecureSBK mode
[0000.919] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.926] Bootloader downloaded successfully.
[0000.930] BoardID = 3448, SKU = 0x3
[0000.933] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.937] Nano-SD: checking PT table on QSPI ...
[0000.941] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.947] PT: Partition NCT NOT found !
[0000.951] Warning: Find Partition via PT Failed
[0000.955] Next binary entry address: 0x92c00258
[0000.960] BoardId: 3448
[0000.964] Overriding pmu board id with proc board id
[0000.969] Display board id is not available
[0000.973] No Bpmp FW loaded
[0000.976] Not loading WB0 as no bpmp/sc7entry fw
[0000.980] Set NvDecSticky Bits
[0000.984] GSC2 address ff93fffc value c0edbbcc
[0000.990] GSC MC Settings done
[0000.993] BoardID = 3448, SKU = 0x3
[0000.996] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0001.000] Nano-SD: checking PT table on QSPI ...
[0001.004] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.011] TOS Image length 53680
[0001.015] Monitor size 53680
[0001.017] OS size 0
[0001.033] Secure Os AES-CMAC Verification Success!
[0001.037] TOS image cipher info: plaintext
[0001.041] Loading and Validation of Secure OS Successful
[0001.057] NvTbootPackSdramParams: start.
[0001.062] NvTbootPackSdramParams: done.
[0001.066] Tegraboot started after 86977 us
[0001.070] Basic modules init took 957353 us
[0001.074] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.079] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.085] Next stage binary read took 11286 us
[0001.089] Carveout took -69934 us
[0001.092] CPU initialization took 106102 us
[0001.096] Total time taken by TegraBoot 1004807 us
[0001.101] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:09:37, Jul 26 2021
ERROR: Error initializing runtime service trusty_fast
[0001.222] RamCode = 1
[0001.227] LPDDR4 Training: Read DT: Number of tables = 2
[0001.232] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.245] EMC Training Successful
[0001.248] 408000 not found in DVFS table
[0001.254] RamCode = 1
[0001.258] DT Write: emc-table@204000 succeeded
[0001.263] DT Write: emc-table@1600000 succeeded
[0001.268] LPDDR4 Training: Write DT: Number of tables = 2
[0001.307]
[0001.308] Debug Init done
[0001.310] Marked DTB cacheable
[0001.313] Bootloader DTB loaded at 0x83000000
[0001.318] Marked DTB cacheable
[0001.321] Kernel DTB loaded at 0x83100000
[0001.325] DeviceTree Init done
[0001.338] Pinmux applied successfully
[0001.342] gicd_base: 0x50041000
[0001.346] gicc_base: 0x50042000
[0001.349] Interrupts Init done
[0001.353] Using base:0x60005090 & irq:208 for tick-timer
[0001.358] Using base:0x60005098 for delay-timer
[0001.363] platform_init_timer: DONE
[0001.366] Timer(tick) Init done
[0001.370] osc freq = 38400 khz
[0001.374]
[0001.375] Welcome to L4T Cboot
[0001.378]
[0001.379] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.384] calling constructors
[0001.387] initializing heap
[0001.389] initializing threads
[0001.392] initializing timers
[0001.395] creating bootstrap completion thread
[0001.400] top of bootstrap2()
[0001.402] CPU: ARM Cortex A57
[0001.405] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.410] initializing platform
[0001.418] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.422] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.427] Macronix QSPI chip present
[0001.430] SPI device register
[0001.433] init boot device
[0001.436] allocating memory for boot device(SPI)
[0001.440] registering boot device
[0001.448] QSPI bdev is already initialized
[0001.452] Enable APE clock
[0001.455] Un-powergate APE partition
[0001.459] of_register: registering tegra_udc to of_hal
[0001.464] of_register: registering inv20628-driver to of_hal
[0001.469] of_register: registering ads1015-driver to of_hal
[0001.475] of_register: registering lp8557-bl-driver to of_hal
[0001.481] of_register: registering bq2419x_charger to of_hal
[0001.486] of_register: registering bq27441_fuel_gauge to of_hal
[0001.498] gpio framework initialized
[0001.501] of_register: registering tca9539_gpio to of_hal
[0001.506] of_register: registering tca9539_gpio to of_hal
[0001.512] of_register: registering i2c_bus_driver to of_hal
[0001.517] of_register: registering i2c_bus_driver to of_hal
[0001.523] of_register: registering i2c_bus_driver to of_hal
[0001.529] pmic framework initialized
[0001.532] of_register: registering max77620_pmic to of_hal
[0001.537] regulator framework initialized
[0001.541] of_register: registering tps65132_bl_driver to of_hal
[0001.547] initializing target
[0001.553] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.561] board ID = D78, board SKU = 3
[0001.565] Skipping Z3!
[0001.570] fixed regulator driver initialized
[0001.589] initializing OF layer
[0001.592] NCK carveout not present
[0001.595] Skipping dts_overrides
[0001.599] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.615] I2C Bus Init done
[0001.618] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.628] I2C Bus Init done
[0001.631] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.641] I2C Bus Init done
[0001.644] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.654] I2C Bus Init done
[0001.657] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.667] I2C Bus Init done
[0001.670] of_children_init: Ops found for compatible string maxim,max77620
[0001.680] max77620_init using irq 118
[0001.685] register 'maxim,max77620' pmic
[0001.689] gpio_driver_register: register 'max77620-gpio' driver
[0001.695] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.706] I2C Bus Init done
[0001.709] NCK carveout not present
[0001.719] Find /i2c@7000c000's alias i2c0
[0001.723] get eeprom at 1-a0, size 256, type 0
[0001.732] Find /i2c@7000c500's alias i2c2
[0001.735] get eeprom at 3-a0, size 256, type 0
[0001.740] get eeprom at 3-ae, size 256, type 0
[0001.744] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.749] I2C slave not started
[0001.752] I2C write failed
[0001.755] Writing offset failed
[0001.758] eeprom_init: EEPROM read failed
[0001.762] pm_ids_update: eeprom init failed
[0001.766] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.796] pm_ids_update: The pm board id is 3448-0003-400
[0001.803] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.811] pm_ids_update: pm id update successful
[0001.816] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.846] pm_ids_update: The pm board id is 3542-0000-201
[0001.852] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.860] pm_ids_update: pm id update successful
[0001.890] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.896] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.904] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.910] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.918] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:d5:18
[0001.924] Plugin Manager: Parse ODM data 0x000a4000
[0001.936] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70 006000
[0001.951] Find /i2c@7000c000's alias i2c0
[0001.955] get eeprom at 1-a0, size 256, type 0
[0001.964] Find /i2c@7000c500's alias i2c2
[0001.968] get eeprom at 3-a0, size 256, type 0
[0001.972] get eeprom at 3-ae, size 256, type 0
[0001.977] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.982] I2C slave not started
[0001.985] I2C write failed
[0001.987] Writing offset failed
[0001.990] eeprom_init: EEPROM read failed
[0001.994] pm_ids_update: eeprom init failed
[0001.999] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.029] pm_ids_update: The pm board id is 3448-0003-400
[0002.035] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0002.042] pm_ids_update: pm id update successful
[0002.046] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.076] pm_ids_update: The pm board id is 3542-0000-201
[0002.083] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.090] pm_ids_update: pm id update successful
[0002.120] Add serial number:1424120064975 as DT property
[0002.128] Applying platform configs
[0002.134] platform-init is not present. Skipping
[0002.138] calling apps_init()
[0002.144] Couldn't find GPT header
[0002.149] Proceeding to Cold Boot
[0002.152] starting app android_boot_app
[0002.156] Device state: unlocked
[0002.159] display console init
[0002.167] could not find regulator
[0002.170] hdmi cable connected
[0002.186] edid read success
[0002.201] edid read success
[0002.204] width DT entry for leds-pwm not found
=[0002.211] 640, height = 480, frequency = 25174825
[0002.216] width = 640, height = 480, frequency = 25174825
[0002.221] width = 640, height = 480, frequency = 25174825
[0002.227] width = 3440, height = 1440, frequency = 266570000
[0002.232] width = 3440, height = 1440, frequency = 533120000
[0002.238] width = 640, height = 480, frequency = 25174825
[0002.243] width = 720, height = 480, frequency = 26973026
[0002.249] width = 720, height = 480, frequency = 26973026
[0002.254] width = 1280, height = 720, frequency = 74175824
[0002.260] width = 1920, height = 1080, frequency = 148351648
[0002.265] width = 720, height = 576, frequency = 26973026
[0002.271] width = 720, height = 576, frequency = 26973026
[0002.276] width = 1280, height = 720, frequency = 74175824
[0002.281] width = 1920, height = 1080, frequency = 148351648
[0002.287] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.295] tmds-config node not found
[0002.299] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepr opsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[0002.314] setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.321] could not find regulator
[0002.324] could not find regulator
[0002.328] could not find regulator
[0002.356] using default cmu settings
[0002.360] dc_hdmi_enable, starting HDMI initialisation
[0002.366] dc_hdmi_enable, HDMI initialisation complete
[0002.371] list and configure display window
[0002.380] display console init completed
[0002.391] subnode volume_up is not found !
[0002.395] subnode back is not found !
[0002.398] subnode volume_down is not found !
[0002.402] subnode menu is not found !
[0002.406] Gpio keyboard init success
[0002.486] found decompressor handler: lz4-legacy
[0002.501] decompressing blob (type 1)...
[0002.570] load_bmp_blob: panelresolution=1080 type=3
[0002.644] decompressor handler not found
[0002.648] load_firmware_blob: Firmware blob loaded, entries=2
[0002.654] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.660] -------> se_aes_verify_sbk_clear: 747
[0002.664] se_aes_verify_sbk_clear: Error
[0002.668] SE operation failed
[0002.671] bl_battery_charging: connected to external power supply
[0002.683] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.691] MSC Partition not found
[0002.697] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.704] USP partition read failed!
[0002.708] blob_init: blob-partition USP header read failed
[0002.713] android_boot Unable to update recovery partition
[0002.719] kfs_getpartname: name = LNX
[0002.722] Loading kernel from LNX
[0002.731] Found 19 BFS partitions in "spiflash0"
[0003.053] load kernel from storage
[0003.058] decompressor handler not found
[0003.324] Successfully loaded kernel and ramdisk images
[0003.329] board ID = D78, board SKU = 3
[0003.334] sdmmc node status = okay
[0003.337] sdcard instance = 0
[0003.340] sdmmc cd-inverted
[0003.343] sdcard gpio handle 0x5a
[0003.346] sdcard gpio pin 0xc9
[0003.349] sdcard gpio flags 0x0
[0003.352] vmmc-supply 0x9a
[0003.355] cd_gpio_pin = 201
[0003.357] pin_state = 0
[0003.360] Found sdcard
[0003.362] SD-card IS present ...
[0003.365] load_and_boot_kernel: SD card detected OK
[0003.371] load_bmp_blob: panelresolution=1080 type=3
[0003.856] display bmp image done
[0003.859] NCK carveout not present
[0003.862] Skipping dts_overrides
[0003.866] NCK carveout not present
[0003.875] Find /i2c@7000c000's alias i2c0
[0003.879] get eeprom at 1-a0, size 256, type 0
[0003.888] Find /i2c@7000c500's alias i2c2
[0003.892] get eeprom at 3-a0, size 256, type 0
[0003.896] get eeprom at 3-ae, size 256, type 0
[0003.901] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.906] I2C slave not started
[0003.909] I2C write failed
[0003.912] Writing offset failed
[0003.915] eeprom_init: EEPROM read failed
[0003.919] pm_ids_update: eeprom init failed
[0003.923] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.953] pm_ids_update: The pm board id is 3448-0003-400
[0003.960] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0003.968] pm_ids_update: pm id update successful
[0003.973] pm_ids_update: Updating 3,ae, size 256, type 0
[0004.003] pm_ids_update: The pm board id is 3542-0000-201
[0004.009] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0004.017] pm_ids_update: pm id update successful
[0004.047] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.053] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0004.061] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0004.067] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0004.075] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:d5:18
[0004.081] Plugin Manager: Parse ODM data 0x000a4000
[0004.093] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70 006000
[0004.101] Add serial number:1424120064975 as DT property
[0004.109] Updated bpmp info to DTB
[0004.114] Updated initrd info to DTB
[0004.117] "proc-board" doesn't exist, creating
[0004.123] Updated board info to DTB
[0004.127] "pmu-board" doesn't exist, creating
[0004.133] Updated board info to DTB
[0004.136] "display-board" doesn't exist, creating
[0004.142] Updated board info to DTB
[0004.145] "reset" doesn't exist, creating
[0004.150] Updated reset info to DTB
[0004.153] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype= 0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@6 3 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lspor t,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 c ore_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_ini tialised=1
[0004.190] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.196] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 c onsole=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.209] Updated bootarg info to DTB
[0004.212] Adding uuid 00000001644608091c00000010010440 to DT
[0004.218] Adding eks info 0 to DT
[0004.224] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.230] Updated memory info to DTB
[0004.238] set vdd_core voltage to 1075 mv
[0004.241] setting 'vdd-core' regulator to 1075000 micro volts
[0004.247] Found secure-pmc; disable BPMP
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:09:42 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 2 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1101 bytes read in 30 ms (35.2 KiB/s)
L4T boot options
1: primary kernel
2: overclock kernel
Enter choice: 2: overclock kernel
Retrieving file: /boot/initrd
7160133 bytes read in 334 ms (20.4 MiB/s)
Retrieving file: /boot/Image_overclock
34746376 bytes read in 1542 ms (21.5 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegr afb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlypri ntk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1 075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype= ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/d ev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbc on=map:0 net.ifnames=0
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083100000, end 000000008317ae79
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.253-tegra (aresuser@aresuser-desktop) (gcc vers ion 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #1 SMP PREEMPT Wed Aug 25 05:17 :53 CEST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 1.322743] imx219 6-0010: imx219_board_setup: error during i2c read probe (- 121)
[ 1.322811] imx219 6-0010: board setup failed
[ 2.129262] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
[ 2.137870] cgroup: cgroup2: unknown option "nsdelegate"
[ 3.382385] scsi 0:0:0:0: Direct-Access WD 10EAVS External 1.75 PQ : 0 ANSI: 4
[ 3.391302] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/93 2 GiB)
[ 3.399369] sd 0:0:0:0: [sda] Write Protect is off
[ 3.407262] sd 0:0:0:0: [sda] No Caching mode page found
[ 3.415794] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 3.594773] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ign ored
[ 3.602379] squashfs: SQUASHFS error: unable to read xattr id index table
[ 3.627664] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ign ored
[ 3.635262] squashfs: SQUASHFS error: unable to read xattr id index table
[ 4.213789] tegra_cec 70015000.tegra_cec: timeout in tegra_cec_native_write_l :172.
[ 4.221568] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -62.
[ 4.236084] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 4.604279] random: crng init done
[ 4.607704] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.477779] using random self ethernet address
[ 5.482280] using random host ethernet address
[ 7.523224] using random self ethernet address
[ 7.527717] using random host ethernet address
[ 10.701134] sd 0:0:0:0: [sda] Attached SCSI disk
[ 10.768230] nvgpu: 57000000.gpu gk20a_pmu_isr:724 [ERR] pmu exterr intr not implemented. Clearing interrupt.
[ 10.780062] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:560 [ERR] <<< FALCON id-0 DEBUG INFORMATION - START >>>
[ 10.791276] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:504 [ERR] FALCON IMEM BLK MAPPING (PA->VA) (96 TOTAL):
[ 10.802444] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x00: 0x01000000 0x01000100 0x01000200 0x01000300
[ 10.814086] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x04: 0x01000400 0x01000500 0x01000600 0x01000700
[ 10.825782] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x08: 0x01000800 0x01000900 0x01000a00 0x01000b00
[ 10.837434] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x0c: 0x01000c00 0x01000d00 0x01000e00 0x01000f00
[ 10.849159] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x10: 0x01001000 0x01001100 0x01001200 0x01001300
[ 10.860875] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x14: 0x01001400 0x01001500 0x01001600 0x01002d00
[ 10.872543] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x18: 0x01002e00 0x01002f00 0x01003000 0x01003100
[ 10.884175] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x1c: 0x01001c00 0x01001d00 0x01001e00 0x01001f00
[ 10.895820] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x20: 0x01002000 0x01002100 0x01002200 0x01004b00
[ 10.907473] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x24: 0x01004c00 0x01004d00 0x01004e00 0x01004f00
[ 10.919126] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x28: 0x01005000 0x01005100 0x01002300 0x01002400
[ 10.930770] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x2c: 0x01002500 0x01003200 0x01003300 0x01003400
[ 10.942431] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x30: 0x01003500 0x01003600 0x01003700 0x01003800
[ 10.954111] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x34: 0x01003900 0x01003a00 0x01003b00 0x01003c00
[ 10.965886] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x38: 0x01003d00 0x01003e00 0x01003f00 0x01004000
[ 10.977582] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x3c: 0x01004100 0x01004200 0x01004300 0x01004400
[ 10.989284] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x40: 0x01004500 0x01004600 0x01004700 0x01004800
[ 11.000953] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x44: 0x01004900 0x01004a00 0x01005200 0x01005300
[ 11.012651] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x48: 0x01005400 0x01005500 0x01005600 0x01005700
[ 11.024348] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x4c: 0x01005800 0x01005900 0x01005a00 0x01005b00
[ 11.036027] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x50: 0x01005c00 0x01005d00 0x01005e00 0x01005f00
[ 11.047725] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x54: 0x01006000 0x01006100 0x01006200 0x01006300
[ 11.059411] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:518 [ERR] 0x58: 0x01006400 0x01006500 0x01006600 0x01002600
[ 11.071049] nvgpu: 57000000.gpu gk20a_falcon_dump_imblk:520 [ERR] 0x5c: 0x01002700 0x01002800 0x01002900 0x01002c00
[ 11.082755] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:541 [ERR] PC TRACE (TOTAL 7 ENTRIES. entry 0 is the most recent branch):
[ 11.095475] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(0) : 0x0000054a
[ 11.105570] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(1) : 0x00000545
[ 11.115661] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(2) : 0x0000054e
[ 11.125746] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(3) : 0x00001041
[ 11.135831] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(4) : 0x000015e2
[ 11.145930] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(5) : 0x0000160e
[ 11.156023] nvgpu: 57000000.gpu gk20a_falcon_dump_pc_trace:549 [ERR] FALCON_TRACEPC(6) : 0x00000a59
[ 11.166114] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:567 [ERR] FALCON ICD REGISTERS DUMP
[ 11.175642] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 11.184850] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 11.194082] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 11.203332] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 11.212569] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 11.221782] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 11.231024] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:575 [ERR] FALCON_REG_PC : 0x1041
[ 11.240255] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:582 [ERR] FALCON_REG_SP : 0x43c4
[ 11.249493] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:589 [ERR] FALCON_REG_IMB : 0xff9071
[ 11.258963] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:595 [ERR] FALCON_REG_DMB : 0xff90d8
[ 11.268447] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:601 [ERR] FALCON_REG_CSW : 0x330801
[ 11.277960] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:607 [ERR] FALCON_REG_CTX : 0x0
[ 11.286998] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:613 [ERR] FALCON_REG_EXCI : 0x693
[ 11.296329] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[0] : 0xa5a5a5a5
[ 11.306488] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[1] : 0xa5a5a5a5
[ 11.316571] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[2] : 0xa5a5a5a5
[ 11.326663] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[3] : 0xa5a5a5a5
[ 11.336755] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[4] : 0xa5a5a5a5
[ 11.346836] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:622 [ERR] FALCON_REG_RSTAT[5] : 0xa5a5a5a5
[ 11.356959] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:625 [ERR] FALCON REGISTERS DUMP
[ 11.366162] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:627 [ERR] falcon_falcon_os_r : 0
[ 11.375387] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:629 [ERR] falcon_falcon_cpuctl_r : 0x60
[ 11.385196] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:631 [ERR] falcon_falcon_idlestate_r : 0x0
[ 11.395219] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:633 [ERR] falcon_falcon_mailbox0_r : 0x0
[ 11.405160] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:635 [ERR] falcon_falcon_mailbox1_r : 0x0
[ 11.415105] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:637 [ERR] falcon_falcon_irqstat_r : 0x60
[ 11.425027] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:639 [ERR] falcon_falcon_irqmode_r : 0xfc24
[ 11.435112] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:641 [ERR] falcon_falcon_irqmask_r : 0x7879
[ 11.445211] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:643 [ERR] falcon_falcon_irqdest_r : 0x90372
[ 11.455392] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:645 [ERR] falcon_falcon_debug1_r : 0x10000
[ 11.465478] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:647 [ERR] falcon_falcon_debuginfo_r : 0x0
[ 11.475477] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:649 [ERR] falcon_falcon_bootvec_r : 0x3200
[ 11.485566] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:651 [ERR] falcon_falcon_hwcfg_r : 0x400cc060
[ 11.495851] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:653 [ERR] falcon_falcon_engctl_r : 0x0
[ 11.505592] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:655 [ERR] falcon_falcon_curctx_r : 0x707fffe7
[ 11.515971] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:657 [ERR] falcon_falcon_nxtctx_r : 0x707fffe7
[ 11.526309] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:659 [ERR] falcon_falcon_exterrstat_r : 0x85002efb
[ 11.537040] nvgpu: 57000000.gpu gk20a_falcon_dump_stats:661 [ERR] falcon_falcon_exterraddr_r : 0x18405804
[ 11.547721] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(0) : 0x0
[ 11.557271] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(1) : 0x0
[ 11.566824] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(2) : 0x0
[ 11.576385] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(3) : 0x0
[ 11.585944] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(4) : 0x0
[ 11.595507] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(5) : 0x0
[ 11.606197] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(6) : 0x0
Ubuntu 21.10 aresuser-desktop[ 11.616911] nvgpu: 57000000.gpu gk20a_pmu_ dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(7) : 0x0
ttyS0
aresuser-desktop login[ 11.629135] nvgpu: 57000000.gpu gk20a_pmu_dump_fa lcon_stats:630 [ERR] pwr_pmu_mailbox_r(8) : 0x0
: [ 11.641415] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR ] pwr_pmu_mailbox_r(9) : 0x0
[ 11.652080] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(10) : 0x0
[ 11.662825] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:630 [ERR] pwr_pmu_mailbox_r(11) : 0x0
[ 11.673489] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(0) : 0x0
[ 11.683946] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(1) : 0x0
[ 11.694319] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(2) : 0x2a
[ 11.704790] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:635 [ERR] pwr_pmu_debug_r(3) : 0x0
[ 11.715087] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:639 [ERR] pwr_pmu_bar0_error_status_r : 0x0
[ 11.726216] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:652 [ERR] pwr_pmu_bar0_fecs_error_r : 0xbadf1201
[ 11.737746] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:655 [ERR] pwr_falcon_exterrstat_r : 0x85002efb
[ 11.749178] nvgpu: 57000000.gpu gk20a_pmu_dump_falcon_stats:659 [ERR] pwr_falcon_exterraddr_r : 0x18405804
[ 11.760604] nvgpu: 57000000.gpu print_pmu_trace:88 [ERR] dump PMU trace buffer
[ 11.770741] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:51 [ERR] pmu state: 7
[ 11.780075] nvgpu: 57000000.gpu nvgpu_pmu_dump_falcon_stats:52 [ERR] elpg state: 0
[ 11.789529] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:129 [ERR] gr_fecs_os_r : 0
[ 11.799261] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:131 [ERR] gr_fecs_cpuctl_r : 0x60
[ 11.809519] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:133 [ERR] gr_fecs_idlestate_r : 0x0
[ 11.819974] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:135 [ERR] gr_fecs_mailbox0_r : 0x0
[ 11.830336] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:137 [ERR] gr_fecs_mailbox1_r : 0x0
[ 11.840726] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:139 [ERR] gr_fecs_irqstat_r : 0x0
[ 11.851089] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:141 [ERR] gr_fecs_irqmode_r : 0x4
[ 11.861373] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:143 [ERR] gr_fecs_irqmask_r : 0x8704
[ 11.871949] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:145 [ERR] gr_fecs_irqdest_r : 0x0
[ 11.882201] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:147 [ERR] gr_fecs_debug1_r : 0x40
[ 11.892476] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:149 [ERR] gr_fecs_debuginfo_r : 0x0
[ 11.902958] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:151 [ERR] gr_fecs_ctxsw_status_1_r : 0x382
[ 11.914045] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(0) : 0x1
[ 11.925124] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(1) : 0x0
[ 11.936239] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(2) : 0x1
[ 11.947321] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(3) : 0x0
[ 11.958454] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(4) : 0x1ffda0
[ 11.970016] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(5) : 0x0
[ 11.981061] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(6) : 0x0
[ 11.992141] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(7) : 0x0
[ 12.003176] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(8) : 0x0
[ 12.014135] Bridge firewalling registered
[ 12.019246] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(9) : 0x0
[ 12.030309] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(10) : 0x0
[ 12.041458] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(11) : 0x0
[ 12.052618] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(12) : 0x0
[ 12.063792] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(13) : 0x0
[ 12.074958] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(14) : 0x0
[ 12.086143] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:155 [ERR] gr_fecs_ctxsw_mailbox_r(15) : 0x0
[ 12.097300] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:159 [ERR] gr_fecs_engctl_r : 0x0
[ 12.107462] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:161 [ERR] gr_fecs_curctx_r : 0x0
[ 12.117676] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:163 [ERR] gr_fecs_nxtctx_r : 0x0
[ 12.127846] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:169 [ERR] FECS_FALCON_REG_IMB : 0xbadfbadf
[ 12.138900] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:175 [ERR] FECS_FALCON_REG_DMB : 0xbadfbadf
[ 12.149986] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:181 [ERR] FECS_FALCON_REG_CSW : 0xbadfbadf
[ 12.161077] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:187 [ERR] FECS_FALCON_REG_CTX : 0xbadfbadf
[ 12.172255] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:193 [ERR] FECS_FALCON_REG_EXCI : 0xbadfbadf
[ 12.183499] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 12.194543] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 12.205583] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 12.216641] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 12.227693] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 12.238691] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
[ 12.249641] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:200 [ERR] FECS_FALCON_REG_PC : 0xbadfbadf
[ 12.260624] nvgpu: 57000000.gpu gk20a_fecs_dump_falcon_stats:206 [ERR] FECS_FALCON_REG_SP : 0xbadfbadf
Happen randomly not always time .
Also I detected the gpu driver detected bad resolution sometimes switch 3840x2160 on wrong monitors 21:9 3440x1440 stuck 50hz instead 120hz on HDMI.
