Hi Folks,
I am processing YUV420 inputs from two cameras concurrently. I am also encoding/recording from each camera, while feeding frames to opencv pipeline with workload divided between GPU and CPU. I am using Argus library to interface with cameras.
The camera interface of the pipeline looks like -
bool aaCamCaptureThread::threadExecute()
IStream *iStream = interface_cast<IStream>(m_stream);
IFrameConsumer *iFrameConsumer = interface_cast<IFrameConsumer>(m_consumer);
Argus::Status status;
int ret;
// Wait until the producer has connected to the stream.
AACAM_CAPTURE_PRINT("Waiting until producer is connected...%x\n", m_stream);
if (iStream->waitUntilConnected() != STATUS_OK)
ORIGINATE_ERROR("Stream failed to connect.");
AACAM_CAPTURE_PRINT("Producer has connected; continuing. %x\n", iFrameConsumer);
int frameCount = 0;
while (m_currentFrame < (m_lastFrameCount-2))
// Acquire a Frame.
UniqueObj<Frame> frame(iFrameConsumer->acquireFrame());
IFrame *iFrame = interface_cast<IFrame>(frame);
if (!iFrame)
break;
// Get the Frame's Image.
Image *image = iFrame->getImage();
EGLStream::NV::IImageNativeBuffer *iImageNativeBuffer
= interface_cast<EGLStream::NV::IImageNativeBuffer>(image);
TEST_ERROR_RETURN(!iImageNativeBuffer, "Failed to create an IImageNativeBuffer");
int fd = iImageNativeBuffer->createNvBuffer(ARGUSSIZE {m_pCamInfo->liveParams.inputVideoInfo.width, m_pCamInfo->liveParams.inputVideoInfo.height},
NvBufferColorFormat_YUV420, NvBufferLayout_Pitch, &status);
This code, alongwith rest of my opencv processing and encoding pipe works well on R24.2.1. However on R28.1 it gets choked in -
I copied this code from ~/tegra_multimedia_api/argus/samples/multiSensor example.
I am wondering whether there could be an issue with concurrent access of CSI interface by the two cameras ? I tried protecting acquireFrame() call with a mutex - but that still gets results in same choking.
I am assuming that - ~/tegra_multimedia_api/argus/samples/multiSensor example - which does concurrent access to two cameras does not quite run into this issue - because the two cameras are not reading frame at 30 fps, which is what I do in my case.
Please help.
