Argus bypass
Hello
We are currently using an IMX390 camera to output UYVY data through the ISP on the carrier board.
I want to try using argus. Does it support bypass function?
If I apply, is there a way to check?
Or is there another way to check?
hello rlatae123,
ISP output is YUV420 format types.
may I confirm what’s bypass function you’re mentioned?
As far as I know, using argus requires inputting raw data. What I meant was a question about whether the argus tool can be used with the input data in UYVY format.
no, that’s not supported.
