can it run with default AGX CSI devkit sensor?
~/deploy/ubuntu/argus_camera-pkg$ ./run apps/samples/argus_camera/argus_camera
Running your Shell script
2022-02-22 20:28:58.495 WARN external/com_nvidia_isaac_engine/engine/alice/backend/application_json_loader.cpp@183: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system's abilities if possible.
2022-02-22 20:28:58.498 INFO external/com_nvidia_isaac_engine/engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2022-02-22 20:28:58.499 WARN external/com_nvidia_isaac_engine/engine/alice/backend/backend.cpp@200: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2022-02-22 20:28:58.499 WARN external/com_nvidia_isaac_engine/engine/gems/scheduler/scheduler.cpp@341: No default execution groups specified. Attempting to create scheduler configuration for 8 remaining cores. This may be non optimal for the system and application.
2022-02-22 20:28:58.499 INFO external/com_nvidia_isaac_engine/engine/gems/scheduler/scheduler.cpp@291: Scheduler execution groups are:
2022-02-22 20:28:58.500 INFO external/com_nvidia_isaac_engine/engine/gems/scheduler/scheduler.cpp@300: __BlockerGroup__: Cores = [4, 5], Workers = No
2022-02-22 20:28:58.500 INFO external/com_nvidia_isaac_engine/engine/gems/scheduler/scheduler.cpp@300: __WorkerGroup__: Cores = [7, 6, 1, 0, 2, 3], Workers = Yes
2022-02-22 20:28:58.559 INFO external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@271: Loaded module 'packages/sensors/libargus_camera_module.so': Now has 28 components total
2022-02-22 20:28:58.572 INFO external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@271: Loaded module 'packages/sight/libsight_module.so': Now has 33 components total
2022-02-22 20:28:58.603 INFO external/com_nvidia_isaac_engine/engine/alice/backend/modules.cpp@271: Loaded module 'packages/viewers/libviewers_module.so': Now has 66 components total
2022-02-22 20:28:58.603 INFO packages/sight/sight_start.cpp@157: Loading websight...
2022-02-22 20:28:58.605 DEBUG external/com_nvidia_isaac_engine/engine/alice/application.cpp@321: Loaded 66 components: isaac::ArgusCsiCamera, isaac::alice::BufferAllocatorReport, isaac::alice::ChannelMonitor, isaac::alice::CheckJetsonPerformanceModel, isaac::alice::CheckOperatingSystem, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::ConfigLoader, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::InteractiveMarkersBridge, isaac::alice::LifecycleReport, isaac::alice::MessageLedger, isaac::alice::MessagePassingReport, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::PoseInitializer, isaac::alice::PoseTree, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::map::Map, isaac::map::ObstacleAtlas, isaac::map::OccupancyGridMapLayer, isaac::map::PolygonMapLayer, isaac::map::WaypointMapLayer, isaac::navigation::DistanceMap, isaac::navigation::NavigationMap, isaac::navigation::RangeScanModelClassic, isaac::navigation::RangeScanModelFlatloc, isaac::sight::AliceSight, isaac::sight::PoseTreeJsonBridge, isaac::sight::SightTunnel, isaac::sight::SightWidget, isaac::sight::WebsightServer, isaac::viewers::BinaryMapViewer, isaac::viewers::DepthCameraViewer, isaac::viewers::Detections3Viewer, isaac::viewers::DetectionsViewer, isaac::viewers::FiducialsViewer, isaac::viewers::FlatscanViewer, isaac::viewers::GoalViewer, isaac::viewers::ImageKeypointViewer, isaac::viewers::ImageViewer, isaac::viewers::LidarViewer, isaac::viewers::MosaicViewer, isaac::viewers::ObjectViewer, isaac::viewers::OccupancyMapViewer, isaac::viewers::ParkingSpotListViewer, isaac::viewers::Plan2Viewer, isaac::viewers::PointCloudViewer, isaac::viewers::Polyline2Viewer, isaac::viewers::PoseTrailViewer, isaac::viewers::SegmentationCameraViewer, isaac::viewers::SegmentationViewer, isaac::viewers::SkeletonViewer, isaac::viewers::TensorViewer, isaac::viewers::TrajectoryListViewer, isaac::viewers::deprecated::ColorCameraViewer,
2022-02-22 20:28:58.608 WARN external/com_nvidia_isaac_engine/engine/alice/application.cpp@173: The function Application::findComponentByName is deprecated. Please use `getNodeComponentOrNull` instead. Note that the new method requires a node name instead of a component name. (argument: 'websight/isaac.sight.AliceSight')
2022-02-22 20:28:58.608 DEBUG external/com_nvidia_isaac_engine/engine/alice/application.cpp@321: Loaded 66 components: isaac::ArgusCsiCamera, isaac::alice::BufferAllocatorReport, isaac::alice::ChannelMonitor, isaac::alice::CheckJetsonPerformanceModel, isaac::alice::CheckOperatingSystem, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::ConfigLoader, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::InteractiveMarkersBridge, isaac::alice::LifecycleReport, isaac::alice::MessageLedger, isaac::alice::MessagePassingReport, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::PoseInitializer, isaac::alice::PoseTree, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::map::Map, isaac::map::ObstacleAtlas, isaac::map::OccupancyGridMapLayer, isaac::map::PolygonMapLayer, isaac::map::WaypointMapLayer, isaac::navigation::DistanceMap, isaac::navigation::NavigationMap, isaac::navigation::RangeScanModelClassic, isaac::navigation::RangeScanModelFlatloc, isaac::sight::AliceSight, isaac::sight::PoseTreeJsonBridge, isaac::sight::SightTunnel, isaac::sight::SightWidget, isaac::sight::WebsightServer, isaac::viewers::BinaryMapViewer, isaac::viewers::DepthCameraViewer, isaac::viewers::Detections3Viewer, isaac::viewers::DetectionsViewer, isaac::viewers::FiducialsViewer, isaac::viewers::FlatscanViewer, isaac::viewers::GoalViewer, isaac::viewers::ImageKeypointViewer, isaac::viewers::ImageViewer, isaac::viewers::LidarViewer, isaac::viewers::MosaicViewer, isaac::viewers::ObjectViewer, isaac::viewers::OccupancyMapViewer, isaac::viewers::ParkingSpotListViewer, isaac::viewers::Plan2Viewer, isaac::viewers::PointCloudViewer, isaac::viewers::Polyline2Viewer, isaac::viewers::PoseTrailViewer, isaac::viewers::SegmentationCameraViewer, isaac::viewers::SegmentationViewer, isaac::viewers::SkeletonViewer, isaac::viewers::TensorViewer, isaac::viewers::TrajectoryListViewer, isaac::viewers::deprecated::ColorCameraViewer,
2022-02-22 20:28:58.611 INFO external/com_nvidia_isaac_engine/engine/alice/application.cpp@295: Starting application 'argus_camera' (instance UUID: 'ae874c40-9415-11ec-846c-c7b9b235269c') ...
2022-02-22 20:28:58.611 DEBUG external/com_nvidia_isaac_engine/engine/gems/scheduler/execution_groups.cpp@476: Launching 0 pre-start job(s)
2022-02-22 20:28:58.611 DEBUG external/com_nvidia_isaac_engine/engine/gems/scheduler/execution_groups.cpp@485: Replaying 0 pre-start event(s)
2022-02-22 20:28:58.612 DEBUG external/com_nvidia_isaac_engine/engine/gems/scheduler/execution_groups.cpp@476: Launching 0 pre-start job(s)
2022-02-22 20:28:58.612 DEBUG external/com_nvidia_isaac_engine/engine/gems/scheduler/execution_groups.cpp@485: Replaying 0 pre-start event(s)
2022-02-22 20:28:58.614 INFO packages/sight/WebsightServer.cpp@247: Sight webserver is loaded
2022-02-22 20:28:58.614 INFO packages/sight/WebsightServer.cpp@248: Please open Chrome Browser and navigate to http://<ip address>:3000
2022-02-22 20:28:58.615 WARN external/com_nvidia_isaac_engine/engine/alice/backend/codelet_canister.cpp@229: Codelet 'websight/isaac.sight.AliceSight' was not added to scheduler because no tick method is specified.
2022-02-22 20:28:58.616 WARN external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick parameter
2022-02-22 20:28:58.616 ERROR external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@229: Component '_check_operating_system/isaac.alice.CheckOperatingSystem' of type 'isaac::alice::CheckOperatingSystem' reported FAILURE:
'/etc/nv_tegra_release' does not start with '# R32 (release), REVISION: 5.1'. Please flash L4T using Jetpack 4.5.1.
2022-02-22 20:28:58.616 ERROR external/com_nvidia_isaac_engine/engine/alice/backend/event_manager.cpp@43: Stopping node '_check_operating_system' because it reached status 'FAILURE'
2022-02-22 20:28:58.625 WARN external/com_nvidia_isaac_engine/engine/alice/backend/codelet_canister.cpp@229: Codelet '_check_operating_system/isaac.alice.CheckOperatingSystem' was not added to scheduler because no tick method is specified.
2022-02-22 20:28:58.625 WARN external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick parameter
2022-02-22 20:28:58.626 WARN external/com_nvidia_isaac_engine/engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick parameter
2022-02-22 20:28:58.628 INFO packages/sensors/ArgusCsiCamera.cpp@95: 1 CSI camera(s) connected
2022-02-22 20:28:58.629 INFO packages/sensors/ArgusCsiCamera.cpp@121: Supported resolutions:
2022-02-22 20:28:58.629 INFO packages/sensors/ArgusCsiCamera.cpp@129: Mode 0 - 2592 x 1944
2022-02-22 20:28:58.630 INFO packages/sensors/ArgusCsiCamera.cpp@129: Mode 1 - 2592 x 1458
2022-02-22 20:28:58.630 INFO packages/sensors/ArgusCsiCamera.cpp@129: Mode 2 - 1280 x 720
2022-02-22 20:28:58.630 PANIC packages/sensors/ArgusCsiCamera.cpp@133: Invalid mode 4
| Isaac application terminated unexpectedly |
#01 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0x65fc8) [0x558e496fc8]
#02 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xcfa88) [0x558e500a88]
#03 external/com_nvidia_isaac_engine/engine/alice/tools/main(+0xcfd90) [0x558e500d90]
#04 linux-vdso.so.1(__kernel_rt_sigreturn+0) [0x7fa799d6b0]
#05 /lib/aarch64-linux-gnu/libc.so.6(raise+0xb0) [0x7fa74b54f8]
Minidump written to: /tmp/1333f3d4-e76a-4eea-fffea0a7-8641e866.dmp
Aborted (core dumped)
nvidia@nvidia-desktop:~/deploy/ubuntu/argus_camera-pkg$
3fca7de9-bbe9-4543-4925caa3-26ac1c4e.dmp (198.2 KB)
