Argus_camera bring up 3016*5776 failed!
Hello, I am debugging a Sony camera. I can read the frame rate using v4l2 ctl, but I am using argus_ Camera cannot be lit. The resolution of the sensor is 3016x5776, SDK is 35.3.1 , When I changed the active_h in the dts from 5776 to 4000, I could see the image in the argus_camera. Could you please help to see what caused it?
trace.txt (280.9 KB)
entries-in-buffer/entries-written: 1663/1663 #P:8
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
 kworker/0:6-153     [000] ....    84.184655: rtcpu_string: tstamp:3335561856 id:0x04010000 str:"VM0 deactivating."
 kworker/0:6-153     [000] ....   133.153358: rtcpu_string: tstamp:4866847319 id:0x04010000 str:"VM0 activating."
 kworker/0:6-153     [000] ....   134.569361: rtcpu_vinotify_error: tstamp:4910996178 cch:-1 vi:1 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:157151855840 data:0x0000000000000100
 kworker/0:6-153     [000] ....   134.569366: rtcpu_vinotify_event: tstamp:4911012524 cch:-1 vi:1 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:157151855840 data:0x0000000000000100
 kworker/0:6-153     [000] ....   134.569366: rtcpu_vinotify_event: tstamp:4911012664 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157151899168 data:0x399e300010000000
 kworker/0:6-153     [000] ....   134.569367: rtcpu_vinotify_event: tstamp:4911012817 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157151905632 data:0x0000000031000001
 kworker/0:6-153     [000] ....   134.569368: rtcpu_nvcsi_intr: tstamp:4911153757 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   134.569369: rtcpu_nvcsi_intr: tstamp:4911153757 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   134.569369: rtcpu_nvcsi_intr: tstamp:4911153757 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   134.569370: rtcpu_nvcsi_intr: tstamp:4911153757 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   134.569370: rtcpu_vinotify_event: tstamp:4911351690 cch:1 vi:1 tag:FS channel:0x00 frame:3 vi_tstamp:157160483008 data:0x0000000300000012
 kworker/0:6-153     [000] ....   134.569371: rtcpu_vinotify_event: tstamp:4911351847 cch:1 vi:1 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:157160483008 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.569371: rtcpu_vinotify_event: tstamp:4911351982 cch:1 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:3 vi_tstamp:157160515104 data:0x0000000000000001
 kworker/0:6-153     [000] ....   134.569372: rtcpu_vinotify_event: tstamp:4911352135 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157160516608 data:0x0000000008020001
 kworker/0:6-153     [000] ....   134.569372: rtcpu_vinotify_event: tstamp:4911691284 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157169513696 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.569373: rtcpu_vinotify_event: tstamp:4911691439 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157169515168 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625343: rtcpu_vinotify_event: tstamp:4912030732 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157178513408 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625344: rtcpu_vinotify_event: tstamp:4912030894 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157178514880 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625344: rtcpu_vinotify_event: tstamp:4912370216 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157185158368 data:0x399e2d0010000000
 kworker/0:6-153     [000] ....   134.625345: rtcpu_vinotify_event: tstamp:4912370373 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157185164960 data:0x0000000031000002
 kworker/0:6-153     [000] ....   134.625345: rtcpu_vinotify_event: tstamp:4912370512 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157187513024 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625345: rtcpu_vinotify_event: tstamp:4912370666 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157187514464 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625346: rtcpu_vinotify_event: tstamp:4912391615 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157196512608 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625346: rtcpu_vinotify_event: tstamp:4912709695 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157196515200 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625347: rtcpu_vinotify_event: tstamp:4912709832 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157205512288 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625347: rtcpu_vinotify_event: tstamp:4912709989 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157205513728 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625347: rtcpu_vinotify_event: tstamp:4913049216 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157214511936 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625348: rtcpu_vinotify_event: tstamp:4913049378 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157214513376 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.625348: rtcpu_vinotify_event: tstamp:4913388628 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157223511584 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.625349: rtcpu_vinotify_event: tstamp:4913388788 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157223513024 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.681354: rtcpu_vinotify_event: tstamp:4913728188 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157232511264 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.681355: rtcpu_vinotify_event: tstamp:4913728349 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157232512672 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.681356: rtcpu_vinotify_event: tstamp:4914067642 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157241510848 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.681356: rtcpu_vinotify_event: tstamp:4914067799 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157241512288 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.681358: rtcpu_nvcsi_intr: tstamp:4914278629 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   134.681358: rtcpu_nvcsi_intr: tstamp:4914278629 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   134.681359: rtcpu_nvcsi_intr: tstamp:4914278629 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   134.681359: rtcpu_nvcsi_intr: tstamp:4914278629 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   134.681360: rtcpu_vinotify_event: tstamp:4914280973 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:3 vi_tstamp:157250510496 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.681360: rtcpu_vinotify_event: tstamp:4914281125 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157250511936 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.681361: rtcpu_vinotify_event: tstamp:4914281256 cch:1 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:3 vi_tstamp:157256909600 data:0x0000000016970002
 kworker/0:6-153     [000] ....   134.681361: rtcpu_vinotify_event: tstamp:4914281406 cch:1 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:3 vi_tstamp:157256910272 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.681361: rtcpu_vinotify_event: tstamp:4914281537 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157256913120 data:0x0000000002020001
 kworker/0:6-153     [000] ....   134.681362: rtcpu_vinotify_event: tstamp:4914610810 cch:1 vi:1 tag:FE channel:0x00 frame:3 vi_tstamp:157256910496 data:0x0000000300000022
 kworker/0:6-153     [000] ....   134.681363: rtcpu_vinotify_event: tstamp:4914610950 cch:1 vi:1 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:157256910528 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.681363: rtcpu_vinotify_event: tstamp:4914611104 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:157256920576 data:0x0000000000020001
 kworker/0:6-153     [000] ....   134.681363: rtcpu_vinotify_event: tstamp:4914611238 cch:1 vi:1 tag:FS channel:0x00 frame:4 vi_tstamp:157260478944 data:0x0000000400000012
 kworker/0:6-153     [000] ....   134.681364: rtcpu_vinotify_event: tstamp:4914611392 cch:1 vi:1 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:157260478976 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.681364: rtcpu_vinotify_event: tstamp:4914611524 cch:1 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:4 vi_tstamp:157260511104 data:0x0000000000000001
 kworker/0:6-153     [000] ....   134.681364: rtcpu_vinotify_event: tstamp:4914611680 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157260512640 data:0x0000000008020002
 kworker/0:6-153     [000] ....   134.681365: rtcpu_vinotify_event: tstamp:4914611815 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157260577728 data:0x399e300010000000
 kworker/0:6-153     [000] ....   134.681365: rtcpu_vinotify_event: tstamp:4914611969 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157260584256 data:0x0000000031000003
 kworker/0:6-153     [000] ....   134.681365: rtcpu_vinotify_event: tstamp:4914950356 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157269509728 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.681366: rtcpu_vinotify_event: tstamp:4914950514 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157269511168 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737350: rtcpu_vinotify_event: tstamp:4915289758 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157278509408 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737352: rtcpu_vinotify_event: tstamp:4915289919 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157278510848 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737353: rtcpu_vinotify_event: tstamp:4915290055 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157287509024 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737353: rtcpu_vinotify_event: tstamp:4915290211 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157287510464 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737354: rtcpu_vinotify_event: tstamp:4915516498 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157296508672 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737355: rtcpu_vinotify_event: tstamp:4915833036 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157296511264 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737355: rtcpu_vinotify_event: tstamp:4915833175 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157305508320 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737356: rtcpu_vinotify_event: tstamp:4915833329 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157305509792 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737357: rtcpu_vinotify_event: tstamp:4916172651 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157314507936 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737357: rtcpu_vinotify_event: tstamp:4916172808 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157314509376 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737358: rtcpu_vinotify_event: tstamp:4916512105 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157323507584 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737359: rtcpu_vinotify_event: tstamp:4916512257 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157323509056 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.737359: rtcpu_vinotify_event: tstamp:4916851680 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157332507296 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.737360: rtcpu_vinotify_event: tstamp:4916851834 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157332508736 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.793387: rtcpu_vinotify_event: tstamp:4917191239 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157341506880 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793389: rtcpu_vinotify_event: tstamp:4917191395 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157341508320 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.793391: rtcpu_nvcsi_intr: tstamp:4917403503 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   134.793391: rtcpu_nvcsi_intr: tstamp:4917403503 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   134.793392: rtcpu_nvcsi_intr: tstamp:4917403503 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   134.793392: rtcpu_nvcsi_intr: tstamp:4917403503 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   134.793393: rtcpu_vinotify_event: tstamp:4917405854 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:4 vi_tstamp:157350506560 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793394: rtcpu_vinotify_event: tstamp:4917406016 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157350508000 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.793394: rtcpu_vinotify_event: tstamp:4917406152 cch:1 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:4 vi_tstamp:157356905664 data:0x0000000016970002
 kworker/0:6-153     [000] ....   134.793394: rtcpu_vinotify_event: tstamp:4917406304 cch:1 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:4 vi_tstamp:157356906272 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793395: rtcpu_vinotify_event: tstamp:4917406439 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157356909152 data:0x0000000002020002
 kworker/0:6-153     [000] ....   134.793395: rtcpu_vinotify_event: tstamp:4917734251 cch:1 vi:1 tag:FE channel:0x00 frame:4 vi_tstamp:157356906496 data:0x0000000400000022
 kworker/0:6-153     [000] ....   134.793397: rtcpu_vinotify_event: tstamp:4917734394 cch:1 vi:1 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:157356906528 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.793398: rtcpu_vinotify_event: tstamp:4917734550 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:157356916608 data:0x0000000000020002
 kworker/0:6-153     [000] ....   134.793399: rtcpu_vinotify_event: tstamp:4917734683 cch:1 vi:1 tag:FS channel:0x00 frame:5 vi_tstamp:157360475008 data:0x0000000500000012
 kworker/0:6-153     [000] ....   134.793399: rtcpu_vinotify_event: tstamp:4917734844 cch:1 vi:1 tag:ATOMP_FS channel:0x00 frame:5 vi_tstamp:157360475008 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.793399: rtcpu_vinotify_event: tstamp:4917734976 cch:1 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:5 vi_tstamp:157360507104 data:0x0000000000000001
 kworker/0:6-153     [000] ....   134.793400: rtcpu_vinotify_event: tstamp:4917735129 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157360508640 data:0x0000000008020003
 kworker/0:6-153     [000] ....   134.793400: rtcpu_vinotify_event: tstamp:4917735263 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157360574560 data:0x399e2d0010000000
 kworker/0:6-153     [000] ....   134.793400: rtcpu_vinotify_event: tstamp:4917735414 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157360581120 data:0x0000000031000004
 kworker/0:6-153     [000] ....   134.793401: rtcpu_vinotify_event: tstamp:4918073700 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157369505792 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793401: rtcpu_vinotify_event: tstamp:4918073852 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157369507232 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.793402: rtcpu_vinotify_event: tstamp:4918413176 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157378505376 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793402: rtcpu_vinotify_event: tstamp:4918413329 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157378506848 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.793402: rtcpu_vinotify_event: tstamp:4918413463 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157387505056 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.793403: rtcpu_vinotify_event: tstamp:4918413620 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157387506496 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.793403: rtcpu_vinotify_event: tstamp:4918641361 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157396504704 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849349: rtcpu_vinotify_event: tstamp:4918956262 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157396507296 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.849352: rtcpu_vinotify_event: tstamp:4918956395 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157405504352 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849352: rtcpu_vinotify_event: tstamp:4918956545 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157405505792 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.849352: rtcpu_vinotify_event: tstamp:4919295810 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157414504000 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849353: rtcpu_vinotify_event: tstamp:4919295963 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157414505440 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.849353: rtcpu_vinotify_event: tstamp:4919635407 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157423503584 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849353: rtcpu_vinotify_event: tstamp:4919635560 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157423504992 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.849354: rtcpu_vinotify_event: tstamp:4919974782 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157432503296 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849354: rtcpu_vinotify_event: tstamp:4919974933 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157432504704 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.849354: rtcpu_vinotify_event: tstamp:4920314413 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157441502912 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.849355: rtcpu_vinotify_event: tstamp:4920314566 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157441504384 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.905341: rtcpu_nvcsi_intr: tstamp:4920528380 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   134.905344: rtcpu_nvcsi_intr: tstamp:4920528380 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   134.905345: rtcpu_nvcsi_intr: tstamp:4920528380 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   134.905346: rtcpu_nvcsi_intr: tstamp:4920528380 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   134.905348: rtcpu_vinotify_event: tstamp:4920530719 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:5 vi_tstamp:157450502560 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905348: rtcpu_vinotify_event: tstamp:4920530873 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157450504000 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.905349: rtcpu_vinotify_event: tstamp:4920531008 cch:1 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:5 vi_tstamp:157456901664 data:0x0000000016970002
 kworker/0:6-153     [000] ....   134.905349: rtcpu_vinotify_event: tstamp:4920531161 cch:1 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:5 vi_tstamp:157456902304 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905350: rtcpu_vinotify_event: tstamp:4920531296 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157456905184 data:0x0000000002020003
 kworker/0:6-153     [000] ....   134.905350: rtcpu_vinotify_event: tstamp:4920857796 cch:1 vi:1 tag:FE channel:0x00 frame:5 vi_tstamp:157456902560 data:0x0000000500000022
 kworker/0:6-153     [000] ....   134.905351: rtcpu_vinotify_event: tstamp:4920857938 cch:1 vi:1 tag:ATOMP_FE channel:0x00 frame:5 vi_tstamp:157456902560 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.905351: rtcpu_vinotify_event: tstamp:4920858093 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:5 vi_tstamp:157456912640 data:0x0000000000020003
 kworker/0:6-153     [000] ....   134.905352: rtcpu_vinotify_event: tstamp:4920858230 cch:1 vi:1 tag:FS channel:0x00 frame:6 vi_tstamp:157460471008 data:0x0000000600000012
 kworker/0:6-153     [000] ....   134.905352: rtcpu_vinotify_event: tstamp:4920858386 cch:1 vi:1 tag:ATOMP_FS channel:0x00 frame:6 vi_tstamp:157460471040 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.905352: rtcpu_vinotify_event: tstamp:4920858517 cch:1 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:6 vi_tstamp:157460503136 data:0x0000000000000001
 kworker/0:6-153     [000] ....   134.905353: rtcpu_vinotify_event: tstamp:4920858668 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157460504704 data:0x0000000008020004
 kworker/0:6-153     [000] ....   134.905353: rtcpu_vinotify_event: tstamp:4920858801 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157460569696 data:0x399e300010000000
 kworker/0:6-153     [000] ....   134.905354: rtcpu_vinotify_event: tstamp:4920858970 cch:1 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:157460576256 data:0x0000000031000005
 kworker/0:6-153     [000] ....   134.905354: rtcpu_vinotify_event: tstamp:4921197192 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157469501792 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905355: rtcpu_vinotify_event: tstamp:4921197345 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157469503232 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.905355: rtcpu_vinotify_event: tstamp:4921536764 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157478501408 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905355: rtcpu_vinotify_event: tstamp:4921536917 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157478502848 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.905356: rtcpu_vinotify_event: tstamp:4921537050 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157487501056 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905356: rtcpu_vinotify_event: tstamp:4921537204 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157487502496 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.905357: rtcpu_vinotify_event: tstamp:4921766239 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157496500704 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905357: rtcpu_vinotify_event: tstamp:4922080168 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157496503296 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.905357: rtcpu_vinotify_event: tstamp:4922080300 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157505500384 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.905358: rtcpu_vinotify_event: tstamp:4922080453 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157505501856 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961352: rtcpu_vinotify_event: tstamp:4922419687 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157514500032 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961354: rtcpu_vinotify_event: tstamp:4922419841 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157514501504 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961355: rtcpu_vinotify_event: tstamp:4922759320 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157523499616 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961356: rtcpu_vinotify_event: tstamp:4922759474 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157523501088 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961356: rtcpu_vinotify_event: tstamp:4923098919 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157532499296 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961357: rtcpu_vinotify_event: tstamp:4923099076 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157532500736 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961358: rtcpu_vinotify_event: tstamp:4923438392 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157541498944 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961358: rtcpu_vinotify_event: tstamp:4923438547 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157541500384 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961361: rtcpu_nvcsi_intr: tstamp:4923653255 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   134.961361: rtcpu_nvcsi_intr: tstamp:4923653255 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   134.961362: rtcpu_nvcsi_intr: tstamp:4923653255 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   134.961363: rtcpu_nvcsi_intr: tstamp:4923653255 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   134.961364: rtcpu_vinotify_event: tstamp:4923655618 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:6 vi_tstamp:157550498624 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961365: rtcpu_vinotify_event: tstamp:4923655771 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157550500096 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961366: rtcpu_vinotify_event: tstamp:4923655905 cch:1 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:6 vi_tstamp:157556897696 data:0x0000000016970002
 kworker/0:6-153     [000] ....   134.961366: rtcpu_vinotify_event: tstamp:4923656058 cch:1 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:6 vi_tstamp:157556898336 data:0x0000000000000000
 kworker/0:6-153     [000] ....   134.961367: rtcpu_vinotify_event: tstamp:4923656190 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157556901216 data:0x0000000002020004
 kworker/0:6-153     [000] ....   134.961368: rtcpu_vinotify_event: tstamp:4923981859 cch:1 vi:1 tag:FE channel:0x00 frame:6 vi_tstamp:157556898592 data:0x0000000600000022
 kworker/0:6-153     [000] ....   134.961368: rtcpu_vinotify_event: tstamp:4923981995 cch:1 vi:1 tag:ATOMP_FE channel:0x00 frame:6 vi_tstamp:157556898592 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.961369: rtcpu_vinotify_event: tstamp:4923982148 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:6 vi_tstamp:157556908640 data:0x0000000000020004
 kworker/0:6-153     [000] ....   134.961370: rtcpu_vinotify_event: tstamp:4923982278 cch:1 vi:1 tag:FS channel:0x00 frame:7 vi_tstamp:157560467136 data:0x0000000700000012
 kworker/0:6-153     [000] ....   134.961370: rtcpu_vinotify_event: tstamp:4923982432 cch:1 vi:1 tag:ATOMP_FS channel:0x00 frame:7 vi_tstamp:157560467136 data:0x0000000800000000
 kworker/0:6-153     [000] ....   134.961371: rtcpu_vinotify_event: tstamp:4923982563 cch:1 vi:1 tag:CHANSEL_PXL_SOF channel:0x23 frame:7 vi_tstamp:157560499200 data:0x0000000000000001
 kworker/0:6-153     [000] ....   134.961372: rtcpu_vinotify_event: tstamp:4923982712 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157560500736 data:0x0000000008020005
 kworker/0:6-153     [000] ....   135.017346: rtcpu_vinotify_event: tstamp:4924321430 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157569497824 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017348: rtcpu_vinotify_event: tstamp:4924321588 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157569499264 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.017350: rtcpu_vinotify_event: tstamp:4924661113 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157578497504 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017351: rtcpu_vinotify_event: tstamp:4924661278 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157578498976 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.017351: rtcpu_vinotify_event: tstamp:4924661410 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157587497152 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017352: rtcpu_vinotify_event: tstamp:4924661563 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157587498560 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.017353: rtcpu_vinotify_event: tstamp:4925000661 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157596496736 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017353: rtcpu_vinotify_event: tstamp:4925000814 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157596498208 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.017354: rtcpu_vinotify_event: tstamp:4925172358 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157605496448 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017355: rtcpu_vinotify_event: tstamp:4925509958 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157605499008 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.017355: rtcpu_vinotify_event: tstamp:4925510092 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157614496032 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.017356: rtcpu_vinotify_event: tstamp:4925510247 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157614497472 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073352: rtcpu_vinotify_event: tstamp:4925849669 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157623495680 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.073355: rtcpu_vinotify_event: tstamp:4925849827 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157623497152 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073355: rtcpu_vinotify_event: tstamp:4926189197 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157632495328 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.073356: rtcpu_vinotify_event: tstamp:4926189351 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157632496800 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073357: rtcpu_vinotify_event: tstamp:4926528755 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157641494976 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.073358: rtcpu_vinotify_event: tstamp:4926528909 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157641496416 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073359: rtcpu_nvcsi_intr: tstamp:4926778136 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.073360: rtcpu_nvcsi_intr: tstamp:4926778136 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.073360: rtcpu_nvcsi_intr: tstamp:4926778136 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.073361: rtcpu_nvcsi_intr: tstamp:4926778136 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.073362: rtcpu_vinotify_event: tstamp:4926780534 cch:1 vi:1 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:7 vi_tstamp:157650494624 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.073363: rtcpu_vinotify_event: tstamp:4926780706 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157650496096 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073363: rtcpu_vinotify_event: tstamp:4926780837 cch:1 vi:1 tag:CHANSEL_PXL_EOF channel:0x23 frame:7 vi_tstamp:157656893760 data:0x0000000016970002
 kworker/0:6-153     [000] ....   135.073364: rtcpu_vinotify_event: tstamp:4926780990 cch:1 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:7 vi_tstamp:157656894368 data:0x0000000000000000
 kworker/0:6-153     [000] ....   135.073364: rtcpu_vinotify_event: tstamp:4926781121 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157656897248 data:0x0000000002020005
 kworker/0:6-153     [000] ....   135.073365: rtcpu_vinotify_event: tstamp:4926781270 cch:1 vi:1 tag:FE channel:0x00 frame:7 vi_tstamp:157656894624 data:0x0000000700000022
 kworker/0:6-153     [000] ....   135.073365: rtcpu_vinotify_event: tstamp:4926781405 cch:1 vi:1 tag:ATOMP_FE channel:0x00 frame:7 vi_tstamp:157656894624 data:0x0000000800000000
 kworker/0:6-153     [000] ....   135.073367: rtcpu_vinotify_error: tstamp:4926891226 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:157660495168 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.073367: rtcpu_vinotify_event: tstamp:4927106204 cch:1 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:7 vi_tstamp:157656904704 data:0x0000000000020005
 kworker/0:6-153     [000] ....   135.073368: rtcpu_vinotify_event: tstamp:4927106336 cch:1 vi:1 tag:FS channel:0x00 frame:8 vi_tstamp:157660463104 data:0x0000000800000012
 kworker/0:6-153     [000] ....   135.073369: rtcpu_vinotify_event: tstamp:4927106493 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:157660495168 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.185347: rtcpu_nvcsi_intr: tstamp:4929903010 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.185349: rtcpu_nvcsi_intr: tstamp:4929903010 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.185350: rtcpu_nvcsi_intr: tstamp:4929903010 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.185350: rtcpu_nvcsi_intr: tstamp:4929903010 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.185352: rtcpu_vinotify_error: tstamp:4930016103 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:157760491264 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.185353: rtcpu_vinotify_event: tstamp:4930158191 cch:1 vi:1 tag:FE channel:0x00 frame:8 vi_tstamp:157756890656 data:0x0000000800000022
 kworker/0:6-153     [000] ....   135.185354: rtcpu_vinotify_event: tstamp:4930158345 cch:1 vi:1 tag:FS channel:0x00 frame:9 vi_tstamp:157760459104 data:0x0000000900000012
 kworker/0:6-153     [000] ....   135.185354: rtcpu_vinotify_event: tstamp:4930158478 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:157760491264 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.297335: rtcpu_nvcsi_intr: tstamp:4933027887 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.297336: rtcpu_nvcsi_intr: tstamp:4933027887 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.297337: rtcpu_nvcsi_intr: tstamp:4933027887 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.297337: rtcpu_nvcsi_intr: tstamp:4933027887 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.297338: rtcpu_vinotify_error: tstamp:4933140976 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:157860487296 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.297339: rtcpu_vinotify_event: tstamp:4933209775 cch:1 vi:1 tag:FE channel:0x00 frame:9 vi_tstamp:157856886688 data:0x0000000900000022
 kworker/0:6-153     [000] ....   135.297340: rtcpu_vinotify_event: tstamp:4933209909 cch:1 vi:1 tag:FS channel:0x00 frame:10 vi_tstamp:157860455200 data:0x0000000a00000012
 kworker/0:6-153     [000] ....   135.297340: rtcpu_vinotify_event: tstamp:4933210067 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:157860487296 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.353343: rtcpu_nvcsi_intr: tstamp:4936152761 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.353345: rtcpu_nvcsi_intr: tstamp:4936152761 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.353345: rtcpu_nvcsi_intr: tstamp:4936152761 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.353346: rtcpu_nvcsi_intr: tstamp:4936152761 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.353347: rtcpu_vinotify_event: tstamp:4936261344 cch:1 vi:1 tag:FE channel:0x00 frame:10 vi_tstamp:157956882688 data:0x0000000a00000022
 kworker/0:6-153     [000] ....   135.353347: rtcpu_vinotify_error: tstamp:4936265850 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:157960483296 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.409341: rtcpu_vinotify_event: tstamp:4936600337 cch:1 vi:1 tag:FS channel:0x00 frame:11 vi_tstamp:157960451264 data:0x0000000b00000012
 kworker/0:6-153     [000] ....   135.409342: rtcpu_vinotify_event: tstamp:4936600471 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:157960483296 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.465339: rtcpu_nvcsi_intr: tstamp:4939277638 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.465340: rtcpu_nvcsi_intr: tstamp:4939277638 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.465341: rtcpu_nvcsi_intr: tstamp:4939277638 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.465342: rtcpu_nvcsi_intr: tstamp:4939277638 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.465343: rtcpu_vinotify_event: tstamp:4939312872 cch:1 vi:1 tag:FE channel:0x00 frame:11 vi_tstamp:158056878784 data:0x0000000b00000022
 kworker/0:6-153     [000] ....   135.465344: rtcpu_vinotify_error: tstamp:4939390727 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:158060479360 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.465344: rtcpu_vinotify_event: tstamp:4939652011 cch:1 vi:1 tag:FS channel:0x00 frame:12 vi_tstamp:158060447232 data:0x0000000c00000012
 kworker/0:6-153     [000] ....   135.465345: rtcpu_vinotify_event: tstamp:4939652165 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:158060479360 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.577341: rtcpu_nvcsi_intr: tstamp:4942402672 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.577342: rtcpu_nvcsi_intr: tstamp:4942402672 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.577344: rtcpu_nvcsi_intr: tstamp:4942402672 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.577344: rtcpu_nvcsi_intr: tstamp:4942402672 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.577346: rtcpu_vinotify_event: tstamp:4942403721 cch:1 vi:1 tag:FE channel:0x00 frame:12 vi_tstamp:158156874752 data:0x0000000c00000022
 kworker/0:6-153     [000] ....   135.577347: rtcpu_vinotify_error: tstamp:4942515601 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:158160475328 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.577348: rtcpu_vinotify_event: tstamp:4942737584 cch:1 vi:1 tag:FS channel:0x00 frame:13 vi_tstamp:158160443296 data:0x0000000d00000012
 kworker/0:6-153     [000] ....   135.577348: rtcpu_vinotify_event: tstamp:4942737719 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:158160475328 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.689339: rtcpu_nvcsi_intr: tstamp:4945527389 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.689340: rtcpu_nvcsi_intr: tstamp:4945527389 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.689340: rtcpu_nvcsi_intr: tstamp:4945527389 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.689341: rtcpu_nvcsi_intr: tstamp:4945527389 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.689342: rtcpu_vinotify_error: tstamp:4945640479 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:158260471392 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.689342: rtcpu_vinotify_event: tstamp:4945789570 cch:1 vi:1 tag:FE channel:0x00 frame:13 vi_tstamp:158256870816 data:0x0000000d00000022
 kworker/0:6-153     [000] ....   135.689343: rtcpu_vinotify_event: tstamp:4945789705 cch:1 vi:1 tag:FS channel:0x00 frame:14 vi_tstamp:158260439296 data:0x0000000e00000012
 kworker/0:6-153     [000] ....   135.689343: rtcpu_vinotify_event: tstamp:4945789858 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:158260471392 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.801336: rtcpu_nvcsi_intr: tstamp:4948652267 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.801337: rtcpu_nvcsi_intr: tstamp:4948652267 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.801338: rtcpu_nvcsi_intr: tstamp:4948652267 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.801338: rtcpu_nvcsi_intr: tstamp:4948652267 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.801339: rtcpu_vinotify_error: tstamp:4948765359 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:158360467456 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.801339: rtcpu_vinotify_event: tstamp:4948841466 cch:1 vi:1 tag:FE channel:0x00 frame:14 vi_tstamp:158356866848 data:0x0000000e00000022
 kworker/0:6-153     [000] ....   135.801340: rtcpu_vinotify_event: tstamp:4948841618 cch:1 vi:1 tag:FS channel:0x00 frame:15 vi_tstamp:158360435328 data:0x0000000f00000012
 kworker/0:6-153     [000] ....   135.801341: rtcpu_vinotify_event: tstamp:4948841752 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:158360467456 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.857356: rtcpu_nvcsi_intr: tstamp:4951777140 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.857358: rtcpu_nvcsi_intr: tstamp:4951777140 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.857359: rtcpu_nvcsi_intr: tstamp:4951777140 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.857360: rtcpu_nvcsi_intr: tstamp:4951777140 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.857361: rtcpu_vinotify_error: tstamp:4951890234 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:158460463424 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.857361: rtcpu_vinotify_event: tstamp:4951893363 cch:1 vi:1 tag:FE channel:0x00 frame:15 vi_tstamp:158456862848 data:0x0000000f00000022
 kworker/0:6-153     [000] ....   135.857362: rtcpu_vinotify_event: tstamp:4951893495 cch:1 vi:1 tag:FS channel:0x00 frame:16 vi_tstamp:158460431296 data:0x0000001000000012
 kworker/0:6-153     [000] ....   135.857362: rtcpu_vinotify_event: tstamp:4951893651 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:158460463424 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.969334: rtcpu_nvcsi_intr: tstamp:4954902017 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   135.969336: rtcpu_nvcsi_intr: tstamp:4954902017 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   135.969336: rtcpu_nvcsi_intr: tstamp:4954902017 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   135.969337: rtcpu_nvcsi_intr: tstamp:4954902017 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   135.969338: rtcpu_vinotify_event: tstamp:4954945269 cch:1 vi:1 tag:FE channel:0x00 frame:16 vi_tstamp:158556858848 data:0x0000001000000022
 kworker/0:6-153     [000] ....   135.969339: rtcpu_vinotify_error: tstamp:4955015107 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:158560459488 data:0x0000000000000589
 kworker/0:6-153     [000] ....   135.969339: rtcpu_vinotify_event: tstamp:4955284255 cch:1 vi:1 tag:FS channel:0x00 frame:17 vi_tstamp:158560427392 data:0x0000001100000012
 kworker/0:6-153     [000] ....   135.969340: rtcpu_vinotify_event: tstamp:4955284387 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:158560459488 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.085332: rtcpu_nvcsi_intr: tstamp:4958026895 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   136.085333: rtcpu_nvcsi_intr: tstamp:4958026895 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   136.085334: rtcpu_nvcsi_intr: tstamp:4958026895 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   136.085335: rtcpu_nvcsi_intr: tstamp:4958026895 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   136.085336: rtcpu_vinotify_event: tstamp:4958138801 cch:1 vi:1 tag:FE channel:0x00 frame:17 vi_tstamp:158656854912 data:0x0000001100000022
 kworker/0:6-153     [000] ....   136.085337: rtcpu_vinotify_event: tstamp:4958138934 cch:1 vi:1 tag:FS channel:0x00 frame:18 vi_tstamp:158660423424 data:0x0000001200000012
 kworker/0:6-153     [000] ....   136.085338: rtcpu_vinotify_error: tstamp:4958139981 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:158660455456 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.085339: rtcpu_vinotify_event: tstamp:4958471554 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:158660455456 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.197330: rtcpu_nvcsi_intr: tstamp:4961151769 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   136.197331: rtcpu_nvcsi_intr: tstamp:4961151769 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   136.197332: rtcpu_nvcsi_intr: tstamp:4961151769 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   136.197333: rtcpu_nvcsi_intr: tstamp:4961151769 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   136.197334: rtcpu_vinotify_event: tstamp:4961184004 cch:1 vi:1 tag:FE channel:0x00 frame:18 vi_tstamp:158756850944 data:0x0000001200000022
 kworker/0:6-153     [000] ....   136.197335: rtcpu_vinotify_error: tstamp:4961264858 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:158760451552 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.197336: rtcpu_vinotify_event: tstamp:4961523192 cch:1 vi:1 tag:FS channel:0x00 frame:19 vi_tstamp:158760419424 data:0x0000001300000012
 kworker/0:6-153     [000] ....   136.197337: rtcpu_vinotify_event: tstamp:4961523324 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:158760451552 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.253334: rtcpu_nvcsi_intr: tstamp:4964276646 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   136.253335: rtcpu_nvcsi_intr: tstamp:4964276646 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   136.253336: rtcpu_nvcsi_intr: tstamp:4964276646 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   136.253336: rtcpu_nvcsi_intr: tstamp:4964276646 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
 kworker/0:6-153     [000] ....   136.253337: rtcpu_vinotify_error: tstamp:4964389733 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:158860447520 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.309335: rtcpu_vinotify_event: tstamp:4964574821 cch:1 vi:1 tag:FE channel:0x00 frame:19 vi_tstamp:158856846944 data:0x0000001300000022
 kworker/0:6-153     [000] ....   136.309337: rtcpu_vinotify_event: tstamp:4964574958 cch:1 vi:1 tag:FS channel:0x00 frame:20 vi_tstamp:158860415488 data:0x0000001400000012
 kworker/0:6-153     [000] ....   136.309338: rtcpu_vinotify_event: tstamp:4964575116 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:158860447520 data:0x0000000000000589
 kworker/0:6-153     [000] ....   136.365336: rtcpu_nvcsi_intr: tstamp:4967401520 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x0e000000
 kworker/0:6-153     [000] ....   136.365338: rtcpu_nvcsi_intr: tstamp:4967401520 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x06000000
 kworker/0:6-153     [000] ....   136.365339: rtcpu_nvcsi_intr: tstamp:4967401520 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status:0x00000e00
 kworker/0:6-153     [000] ....   136.365339: rtcpu_nvcsi_intr: tstamp:4967401520 class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:1 st:0 vc:0 status:0x00000600
Looks like deskew calibration error.
Please configure sensor send deskew word for the MIPI output data rate > 15.Gbps.
Hi ShaneCCC:
I will try this method, but the sensor output is only 600Mbps, is there any other way?
Confirm the pix_clk_hz/serdes_pix_clk_hz
Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
You can calculate the output data rate with the following equation:
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes)
Hi ShaneCCC:
I confirm that this parameter is set correctly. The sensor outputs 4lane raw12 data and the Mipi rate is 600Mbps, so I set serdes_pix_clk_hz to 600*4/12=200M.
I can print the frame rate with v4l2-ctl
I have one more question,argus_camera Is there a requirement for the scale of the image? I changed the active_h in the dts from 5776 to 4000, and nothing else changed, so I could see the image in the argus_camera. What is the reason for this
Does there any error message for 5776?
Below command to check the failed log.
journalctl -f -u nvargus-daemon
vidia@nvidia-desktop:~$ journalctl -f -u nvargus-daemon
– Logs begin at Tue 2023-03-28 01:54:06 CST. –
11月 16 15:10:05 nvidia-desktop nvargus-daemon[2467]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 906)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 143)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
11月 16 15:10:06 nvidia-desktop nvargus-daemon[2467]: SCF: Error InvalidState: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 992)
11月 16 15:10:14 nvidia-desktop nvargus-daemon[2467]: SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
11月 16 15:10:14 nvidia-desktop nvargus-daemon[2467]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
These are the only error logs
What’s the trace log for 5776 failed.
Please clear it than run 5776 to get it.
sudo bash -c "echo > /sys/kernel/debug/tracing/trace"
journalctl_log.txt (16.7 KB)
trace.txt (734.2 KB)
HI: ShaneCCC
This is running log at 3016x5776 resolution
trace_3016x4000.txt (3.8 MB)
This is a trace log running at 3016x4000 resolution
The 5776 have below message could be the root cause.
Did you boost the clocks to try? And does embedded_data_height in device match to sensor output?
     kworker/2:3-370     [002] ....   290.198799: rtcpu_vinotify_error: tstamp:9774061620 cch:1 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:458 vi_tstamp:312769947936 data:0x0000000000000589
Hi ShaneCCC:
I have tried setting the deserializer mipi output rate to 600,800,1200,1800Mbps, but nothing worked. I’ve turned off the sensor’s emb data output
Hi ShaneCCC:
Is there any other reason that may cause this error message?
Did you boost the clocks to try.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
Yeah, I turn this on all the time for debugging
