Argus cannot detect crc payload error
we are experiencing camera crc payload errors on our Jetson Orin modules. It seems that those errors cannot be detected when using libargus stack. Is there some way to catch those error events?
Note that we can see the errors in dmesg when using v4l2 to do camera streaming as below.
Maybe check the trace log.
We used the following cmd to capture trace log but not found crc related error. See the complete trace log: trace.log (41.5 MB)
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Doesn’t looks like get correct data.
Does argus working?
Yes, argus is running, the trace log shows the whole process including start - running - stop.
Did you check the preview screen to confirm it.
