I have jetson orin nx with JP6.1 and imx577 camera. I need to get timestamp for every row of image. To calculate the time of first row i fix time right after frameConsumer->acquireFrame()
struct timespec ts;
clock_gettime(CLOCK_MONOTONIC, &ts);
uint64_t curTimeNs = static_cast<uint64_t>(ts.tv_sec) * BILLION + static_cast<uint64_t>(ts.tv_nsec);
and
firstRowLatency = iFrame->getTime() - iCaptureMetadata->getSensorTimestamp() + iCaptureMetadata->getSensorExposureTime()
firstRowTimestamp = curTimeNs - firstRowLatency
To calculate other rows timestamps i need to know readoutTime
ith_rowTimestamp = firstRowTimestamp + i * readoutTime / height
but i got iCaptureMetadata->getFrameReadoutTime() ~ 125ms, which is impossible, because FPS is 21, so readout time can’t be more than 1000 / 21 ms ~ 47.6 ms
Am i doing something wrong or iCaptureMetadata->getFrameReadoutTime() working wrong ?
The readouttime is calculate by below.
active_pixel_height * line_length/pix_clk_hz
I know that , but i don’t know where to get ‘pix_clk_hz’.
It’s reported by device tree.
I could not find ‘pix_clk_hz’ and i think iCaptureMetadata->getFrameReadoutTime() returns wrong value.
But I did rolling shutter calibration for imx577 and calc time difference between first and last lines of the image:
for sensor mode0 4032x3040 21fps I got ~44ms,
for sensor mode1 3840x2160 30fps I got ~ 29ms,
for sensor mode2 1920x1080 60fps I got ~ 9ms
It looks like this values are the same as
‘iSensorTimestampTsc->getSensorEofTimestampTsc() - iSensorTimestampTsc->getSensorSofTimestampTsc()’
pix_clk_hz is report by sensor driver device tree.
One more time
for sensor mode0 4032x3040 21fps ‘iCaptureMetadata->getFrameReadoutTime() ~125ms’
But if readoutTime is 125ms, than fps cant be more than 1000 / 125 = 8.
Which means that ‘iCaptureMetadata->getFrameReadoutTime()’ returns wrong value, or it is not readoutTime.
As my previous comment the readout time doesn’t matter with the frame rate.
