Argus Daemon restart and multi-camera stream failure when a single camera hangs
Hi team,
We have a camera setup using the AR2020 sensor with the NVIDIA ISP. We have 16 cameras connected to the NVIDIA Jetson AGX Orin through a 4-lane SerDes interface. All cameras are currently streaming at 5120 × 3840 (20 MP) @ 4 FPS.
Orin L4T version is 36.3.0.
During our testing, we observed that if any one of the cameras stops streaming or gets stuck due to an issue, the other cameras that are streaming normally also get stuck.
Further investigation showed that the Argus daemon service is getting restarted when one camera encounters a streaming issue. As a result, cam_off is being called for the other cameras as well, causing all camera streams to stop.
We have also set enableCamInfiniteTimeout to 1, but this has not resolved the issue.
Could you please help us understand why the Argus daemon is restarting when a single camera stream hangs and suggest a way to handle the failed camera without affecting the other active camera streams?
Logs are attached for your reference.
camera_hang_dmesg_log.txt (107.6 KB)
camera_hang_ArgusDaemonLog.txt (26.7 KB)
Thanks,
AbdulSamad.
Hi abdulsamad,
We have dealt with similar stability issues in the past. Before focusing specifically on the Argus recovery behavior, I would suggest isolating the issue first and determining whether it is specific to Argus or also reproducible through the V4L2 capture path.
Could you confirm how the 16 cameras are currently being captured? Are you using nvarguscamerasrc through GStreamer, or is this a custom Libargus-based application?
As a first step, I would recommend bypassing Argus completely and testing the cameras using v4l2-ctl. From the dmesg logs you shared, there seem to be a few I2C errors, so I would first rule out an issue in the camera/SerDes path. If the other V4L2 streams also stop or become unresponsive when one camera fails, then the issue is likely below Argus.
If the V4L2 test is stable, then I would start by reducing the number of active cameras to determine at what point the issue can no longer be reproduced. Since you are running 16 cameras at 5120x3840 @ 4 FPS through the NVIDIA ISP, this represents a significant load. It would be useful to test with 12, 8, 4, and 2 cameras, and also monitor system resources.
Regards,
Carolina Trejos
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Let’s track this issue with another support channel. Thanks
