(Argus) Error Timeout: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
I’m on Jetpack 5.1.1 on Jetson orin Nano. I’m trying to use Raspberry PI High Quality camera which have an IMX477 sensor OpenCV-python version is 4.7.0.
I’m trying to display the camera output on screen and I am using this command to do so :
gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! “video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1” ! nvvidconv ! xvimagesink
But it gives the following Error:
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 219)
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:746 Failed to create CameraProvider
WARNING: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.003557479
Setting pipeline to NULL …
Freeing pipeline …
I have tried reconfiguring pins with jetson-IO for IMX477 DUAL and installing drivers from ArduCam for IMX477 none of it worked.
Looking forward to your help!
Thanks in advance
Confirm the HW by v4l2-ctl first.
v4l2-ctl --set-fmt-video=width=1920,height=1080 --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
the command is working now
