- Hardware Platform Jetson Nano 4GB
- DeepStream Version – 5.0.1
- JetPack Version (valid for Jetson only) – 4.4.1
- TensorRT Version – 7.1.3.0
- Camera Type: Raspberry Pi Camera V2 (MIPI Camera)
I am trying to switch camera between Gstreamer pipeline , Deepstream Pose Estimation Cpp App using Multiprocessing process and then killing the process after 30 secs and again switch to Gstreamer pipeline in a single script with above mentioned Camera.
While running the same, after Deepstream Pose Estimation Cpp App is executed the below mentioned error occurs
But If i try to switch Camera only between Deepstream App and then Gstreamer pipeline it works properly.
Attaching the Code Block SwitchCamera.py (2.1 KB) and the Error:
Error:
(Argus) Error EndofFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error EndofFile: Receiving thread terminated with error in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 368)
(Argus) Error InvalidState: Recieve thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/socketClientDispatch.cpp, function dispatch(), line 87)
Error generated. .dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No camera available
[warn:0] global /tmp/build_opencv/opencv/modulesvideoio/src/cap_gsteamer.cpp (935) open OpenCV | Gstreamer warning: Cannot query video position: status=0,value=-1, duration=-1
Please advise on the same.
Thanks in advance.
Restart the nvargus-daemon before switch to others.
Thanks for your reply.
Kindly please advice how to restart the nvargus-daemon.
sudo ps aux | grep -i nvargus-daemon
sudo kill {PID of nvargus-daemon}
I tried killing the nvargus-daemon with the above command for the “root” USER and also restarted the nvargus-daemon with the command “sudo systemctl restart nvargus-daemon” from the same script but still i m getting the below errors:
Error:
Please advise.
How about some delay between switch and daemon stop/start
I have tried putting delay for 30 secs between switch and daemon stop/start.
Does manually switch those APP working?
Can you attached the deepstream APP here to try.
