Same test, but with the cameras in HDR mode. Results were similar. The error occurred more often though. Log is below.
Failed to fetch stats for frame 37888
SCF: Error BadParameter: (propagating from src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 58)
SCF: Error BadParameter: There was an error decoding stats for frame 37888, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
totalCount of histogram is zero
(Autocontrol) Error BadParameter: histFromLac1 histogram totalMass is invalid (in src/algorithms/ae/ae_stats_utils.cpp, function NvIspAeCalcMaxRGBHistogramsFromLac1(), line 287)
(Autocontrol) Error BadParameter: (propagating from src/algorithms/ae/plugins/aohdr/AEComputePluginAoHdr.cpp, function computeMidtoneMeter(), line 95)
(Autocontrol) Error BadParameter: (propagating from src/algorithms/ae/plugins/aohdr/AEComputePluginAoHdr.cpp, function computeDerivedStats(), line 352)
AWB: M3Stats VWindows = 0 != 64
Failed to fetch stats for frame 37887
SCF: Error BadParameter: There was an error decoding stats for frame 37887, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 52760
SCF: Error BadParameter: There was an error decoding stats for frame 52760, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 52761
SCF: Error BadParameter: There was an error decoding stats for frame 52761, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 52759
SCF: Error BadParameter: There was an error decoding stats for frame 52759, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 189987
SCF: Error BadParameter: There was an error decoding stats for frame 189987, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 202636
SCF: Error BadParameter: There was an error decoding stats for frame 202636, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 202649
Error 0x00000004 occurred at /media/jerry/Hitachi/L4T/T186/r32.x/camera/core_v3/camera_isp/isp/state_update/blocks/stats/LAC.cpp:664
SCF: Error BadParameter: There was an error decoding stats for frame 202649, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266271
SCF: Error BadParameter: There was an error decoding stats for frame 266271, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266269
SCF: Error BadParameter: There was an error decoding stats for frame 266269, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266268
SCF: Error BadParameter: There was an error decoding stats for frame 266268, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266273
SCF: Error BadParameter: There was an error decoding stats for frame 266273, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266279
SCF: Error BadParameter: There was an error decoding stats for frame 266279, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266274
Failed to fetch stats for frame 266272
SCF: Error BadParameter: There was an error decoding stats for frame 266272, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
SCF: Error BadParameter: There was an error decoding stats for frame 266274, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266278
SCF: Error BadParameter: There was an error decoding stats for frame 266278, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266277
SCF: Error BadParameter: There was an error decoding stats for frame 266277, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266282
SCF: Error BadParameter: There was an error decoding stats for frame 266282, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266283
SCF: Error BadParameter: There was an error decoding stats for frame 266283, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 266287
SCF: Error BadParameter: There was an error decoding stats for frame 266287, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
Failed to fetch stats for frame 280792
SCF: Error BadParameter: There was an error decoding stats for frame 280792, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
(NvCamV4l2) Error IoctlFailed: (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function setControlValMultiple(), line 792)
(NvOdmDevice) Error IoctlFailed: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function setDeviceControls(), line 1856)
updateOutputSettings: Set Control failed. Use cached values
Failed to fetch stats for frame 347058
SCF: Error BadParameter: There was an error decoding stats for frame 347058, frame stats will be invalid (in src/services/autocontrol/isp_stats/IspLegacyStatsDecoder.cpp, function decodeIspStats(), line 66)
