Argus getFrameReadoutTime
Can you please explains the value returned by getFrameReadoutTime from libArgus ?
I have a sensor connected to the Jetson Orin.
Video acquisition is done at 30fps.
I printed the different meta data retrieved using the following functions:
std::cout << "Frame Readout " << m_iMetadata->getFrameReadoutTime() << std::endl;
std::cout << "Frame duration " << m_iMetadata->getFrameDuration() << std::endl;
std::cout << "Timestamp " << m_iMetadata->getSensorTimestamp() << std::endl;
std::cout << "SOF " << iSensorTimestampTsc->getSensorSofTimestampTsc() << std::endl;
std::cout << "EOF " << iSensorTimestampTsc->getSensorEofTimestampTsc() << std::endl;
And I get a result similar to:
Frame Readout 61704616
Frame duration 33333333
Timestamp 3158036092000
SOF 3176939776000
EOF 3176969789000
Timestamp 3158069302000
SOF 3176973004000
EOF 3177006220000
Timestamp 3158102550000
SOF 3177006233000
EOF 3177036246000
I can see that
  • SOF - EOF is around 30ms
  • Timestamp image 2 - timestamp image 1 is around 30ms
Why do I have a Frame Readout of around 60ms ?
The read out time is define by “Specifies time taken to read out active region.”
It should be height*line_length/pixel_clock.
Maybe confirm the line_length in you device tree.
thanks for the information,
Where is this read in the pipeline ?
is this the time to read out in CSI driver, in ISP or in application using Argus ?
It’s from the camera core driver.
