I am getting raw data (PIXEL_FMT_RAW16) frames using argus API.
I use ‘cuEGLStreamConsumerAcquireFrame’ to get frame and ‘cuEGLStreamConsumerReleaseFrame’ to push it back and everything works perfectly.
The problem is that if I don’t release frames the maximum number of frames I can get is 13 (for AGX device) and then Argus returns:
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function assignAllBuffersFromStream(), line 232)
SCF: Error Timeout: (propagating from src/components/stages/CCDataSetupStage.cpp, function doHandleRequest(), line 68)
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
SCF: Error Timeout: Sending critical error event (in src/api/Session.cpp, function sendErrorEvent(), line 997)
I believe it means something like: I don’t have availabale bufers to continue.
For my task I need 20-30 cached frames and I want to avoid coping frame data owned by Argus to my predefined buffers (because the chance I need to use frame data from the cache is let’s say 1%, other frames can be just skipped, so I don’t want to waste resources for coping other 99% of buffers).
Is there any way to increase internal argus frame buffer?
Is there any way to use predefined user owned buffers for PIXEL_FMT_RAW16? I use my own predefined buffers with STREAM_TYPE_BUFFER stream, but it works only with NvBufferColorFormat_NV12 and I can’t it get to work with raw data.
Thanks,
Vladimir
