Argus - Segmentation fault issue
We developed an application for streaming from 2 cameras at approximately 30 frames per second. We’ve integrated a backup solution whereby if Argus encounters an error following the issue in this topic :
Argus Error: Freezing Streams with Multiple Cameras ,it triggers a restart of both the producer and consumer. However, after approximately 2 hours, the application crashes with a segmentation fault on “libnvargus_socketclient.so” and below is an exemple of the call stack:
We use:
  • Jetson AGX Orin
  • Jetpack 5.1.3 / L4T 35.5.0
  • Argus library 0.99.3.3
Please get the daemon log if more information.
BringUp
Hello @ShaneCCC , thank you for the answer.
Here is the daemon log while launching the 2 streams when the application crashes.
argus_init.txt (124.9 KB)
Please apply the attached libs and RCE firmware to verify the problem.
libnvscf.so.r35.5.inifite.txt (8.4 MB)
libnvfusacap.so.r35.5.txt (193.6 KB)
camera-rtcpu-t234-rce.img.r35.5.asynchronous (519.3 KB)
Hello @ShaneCCC,
Thank you for your answer.
We tested the libs provided and seems to solve both issues SegFault and the freeze here : Freeze argus
We would like to know, when it maybe a new release with those fixes ?
Yes, suppose the change should be included in next release.
