Ariel Omniverse Digital Twin Compatible with AWS Ec2 instances
Hey everyone!
I am trying to run Ariel Omniverse Digital Twin on Amazon AWS Ec2 instance.
If anyone has tried running it on Ec2, which instance should I run it on?
@haseem Please make sure that the instance support
the recommended GPUs, drivers and OS version. You might need to ensure that the ports are accessible between the front end and backend.
Please download the azure installation package and look at the azure_install.sh to get an idea of the configuration that you need to provision on EC2
I have successfully installed it on g5.2xlarge. FYI
@muratcancicek
I am currently considering using AODT on Amazon EC2. As far as I know, the G5.2xlarge instance supports only 1 GPU, while AODT requires at least 2 GPUs for RAN simulations.
Could you confirm if the full AODT service is fully supported in your EC2 environment?
