Hello, i would like to use the Jetson TK1 board to test SIMD functions on ARM architecture, i want to create objet files (.o) from C++ code and Assembly code, and then link all together to a binary file. Which assembler do you recommend to create the .o file from the Assembly Code ? I use NASM for Intel architecture
Well, for the Assembly part, any assembler would do. In fact I would recommend AS from the GCC-toolchain.
It is very wide spread, the syntax thus is some sort of a standard and you can easily test/play with C-ASM…
