I have executed the ( Ubuntu 22.04.4 LTS) through pip environment but It gets failed with below Error
ERROR Module “cgroups” failed to install on target: Failed to mount “cpuset” controller
ERROR Failed to mount “cpuset” controller
Attached complete build log run.log (20.3 KB)
If anyone has idea about this issue and let me know
If you use Jetpack 6.0GA(r36.3), it may be certain kernel configs not being enabled. Please check what configs are required and refer to developer guide to rebuild kernel.
Thank you Dane
Actually Below configs are already enabled in the Image.
root@orin-desktop:~# zcat /proc/config.gz | grep -i cpuset
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
root@orin-desktop:~# zcat /proc/config.gz | grep -i cgroup
CONFIG_CGROUPS=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_CGROUP_PIDS=y # CONFIG_CGROUP_RDMA is not set
CONFIG_CGROUP_FREEZER=y
CONFIG_CGROUP_HUGETLB=y
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_CGROUP_PERF=y
CONFIG_CGROUP_BPF=y
And I have executed the the workloads by Enabling (by default it is enabled) , disabling and build as module.
When I used the image by disabling these configs halted due mount issue in booting stage (Screenshot Attached).
Might be similar in nature but pip environment has only dealt with python dependencies only and docker support full OS.
Can you please elaborate on which Path is required to include in the environment ?
/sys/fs/cgroup/ is present
/sys/fs/cgroup/systemd is not present
Sharing below information
root@orin-desktop:/var/log# mount | grep cgroup
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot) Note - here cgroup is not mounted with cpuset
Nothing is there about cpuset
root@orin-desktop:/var/log# mount | grep cpuset
No O/P
}} Trying to mount it manually but failed “mount point does not exist” error
root@orin-desktop:/var/log# mount -t cgroup -o cpuset none /sys/fs/cgroup/cpuset
mount: /sys/fs/cgroup/cpuset: mount point does not exist.
Would suggest try Jetpack 5.1.3 which is Kernel 5.10+Ubuntu 20.04. We don’t have experience about the application. Looks like it doesn’t work on Jetpack 6.0GA(K5.15+Ubuntu 22.04). Suggest try Jetpack 5 for comparison.
I will try with Jetpack 5.1.3 ( Kernel 5.10+Ubuntu 20.04) and check this cgoup and cpuset kconfig information. Apart from that I will execute the same workload too
I have flashed JetPack 5.1.3 using sdkmanager on Jetson ORIN AGX successfully. Below is the details about the system
{{{ root@ubuntu:~# cat /etc/os-release NAME=“Ubuntu” VERSION=“20.04.6 LTS (Focal Fossa)” ID=ubuntu ID_LIKE=debian PRETTY_NAME=“Ubuntu 20.04.6 LTS” VERSION_ID=“20.04” HOME_URL=“https://www.ubuntu.com/” SUPPORT_URL=“https://help.ubuntu.com/” BUG_REPORT_URL=“Bugs : Ubuntu” PRIVACY_POLICY_URL=“https://www.ubuntu.com/legal/terms-and-policies/privacy-policy” VERSION_CODENAME=focal UBUNTU_CODENAME=focal root@ubuntu:~# lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.6 LTS Release: 20.04 Codename: focal root@ubuntu:~# uname -r 5.10.192-tegra root@ubuntu:~# uname -a Linux ubuntu 5.10.192-tegra #1 SMP PREEMPT Mon Feb 19 20:19:53 PST 2024 aarch64 aarch64 aarch64 GNU/Linux root@ubuntu:~#
Then I executed the workloads from pip environment and facing below issue
{{{ ERROR Connection lost: [Errno None] Unable to connect to port 22 on 192.168.1.21
Although I have enabled below configuration on sshd_config file under /etc/ssh/ directory
{{{ PermitRootLogin yes PasswordAuthentication yes
After that I restarted the ssh service (as per my understanding after enabling this is worked properly, even I have tried new ethernet cables)
Kindly let me know, how to proceed further
Does it work if you run it on AGX Orin developer kit? Not sure why it needs ssh login. If you run it on the device directly, it may not be triggered.
SSH is required because we are running the workloads from pip Environment and collecting the results of workloads execution, then copy this to our server.
We have automated the setup, then through pip environment we logged in ORIN AGX SoCs through root user.
But some issue is there, So again I will reflash the image and verify it, is this issue persistent or not ?
