Arm Workloads execution failed on ORIN AGX
I have executed the ARM Workload on ORIN AGX ( Ubuntu 22.04.4 LTS) through pip environment but It get failed with below Error
ERROR Module “cgroups” failed to install on target: Failed to mount “cpuset” controller
ERROR Failed to mount “cpuset” controller
Attached complete build log
If anyone has idea about this issue and let me know
run.log (20.3 KB)
Dear @shreyas.kumar.karmahe,
Could you confirm if the used platform is DRIVE AGX Orin?
No It is not Drive AGX Orin but It is Jetson AGX ORIN.Did I triggered the ticket in wrong forum ?
Moved to Jetson AGX Orin forum
Duplicated with ARM Workload execution failed in Jetson AGX Orin using pip envrionment from other system - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
Thank you Siva But I have created one more Ticket with Similar Headlines, Kindly close this ticket from your end because I am unable to close it.
Warm Regards,
Shreyas
We have closed this topic.
